Old 10-21-2018, 03:14 PM   #1
Yousend
Drives: 2014 FR-S
Intermittent overheating on one brake
Ever since I installed my winter tires (on OEM wheels) my brakes have been overheating intermittently. First day I got the tires, I was in stop and go traffic, then when I reached about 50kmph for the first time, I started feeling heavy vibration that disappeared after I slowed down. So I shrugged it off as a tire balancing issue. Brought them back, got them balanced again.
From Thursday until Saturday, everything went fine. Today I drove for about 20minutes then right as I'm about to arrive at my destination I feel the car shake. We assumed it was the road since it happened so abruptly. When we left, it happened again except it sounded like I had a flat tire. We stop, check tire pressure everything is fine. Nothing looks fishy yet.
We resume again, get on the highway, everything is fine. Get off the highway onto the service road and it happens again, it shakes but no "flat tire" sound. We stop in a parking and inspect the car. There's smoke coming out of the rear right wheel well. There's slight discoloration on the rotor on bottom part, the one attached with bolts. No issues with the discs, they're not warped.
What could the issue be? I have driven multiple times longer distances without issues since I first experienced the issue. It seems really random. I replaced the pads and rotors in September.
https://imgur.com/a/5SecrGk
Yousend is offline   Reply With Quote
Old 10-21-2018, 03:26 PM   #2
humfrz
Well, if I had to guess, I would guess that the caliper on the right rear wheel is sticking.
I'd suggest you have it inspected and replaced if necessary.
I'd do that sooner than later.
humfrz
Mr.ac (10-22-2018)
Old 10-21-2018, 04:12 PM   #3
Yousend
Drives: 2014 FR-S
humfrz
I will have my brother inspect it on Tuesday at his work, but I'm concerned for now. I added an image of the one that was smoking.
Old 10-21-2018, 04:27 PM   #4
humfrz
OK, but, between now and when your brother does the inspection, I'd suggest you not drive the car unless its necessary.
After you drive it to your brothers work, after you arrive, I'd check all the rims and or calipers to see it that one is hotter than the rest.
humfrz
Yousend (10-21-2018)
Old 10-21-2018, 05:00 PM   #5
churchx
churchx's Avatar
Drives: 2014 GT86
I'd also in beginning of drive would try to drive at lower speeds in 1st & 2nd gear (for noises to not drown in louder engine/road/tire noise at speed) with windows down, sometimes one can hear when one of brakes drags.
The Following User Says Thank You to churchx For This Useful Post:
Old 10-21-2018, 08:16 PM   #6
guybo
Huge E85 fan!
guybo's Avatar
Drives: 2016 Scion FRS
Did you take the wheels off and inspect yet? Check BOTH sides and make sure none of the brake lines are bent or crushed or pinched or anything.
Old 10-22-2018, 05:59 AM   #7
Yousend
Drives: 2014 FR-S
I did not have a chance to take the wheel off yet. My work is less than 3km away, so I walked to work today. I had a small errand to run last night and when I drove, there was a sound from the rear passenger side as if something got dislodged. I am suspecting something may have been between the brake pads and rotors.
I will have my brother check the lines tomorrow make sure they're not pinched. Last week we assumed it was a balancing issue so he probably did not check the lines when rebalancing.
Note: He did not balance and install the wheels on Wednesday, his coworkers did so I will have him check to make sure they did not touch the lines for whatever reasons.
Old 10-22-2018, 09:06 PM   #8
ls1ac
ls1ac's Avatar
Not with my car now, but is the E-brake inside the center working like a drum brake?
If so. stuck cable?
Old 10-23-2018, 01:22 PM   #9
DarkPira7e
Rust bucket enthusiast
DarkPira7e's Avatar
This happened to me the first year I owned the car in temps under 30 degrees f. E-brake sticks, stop using it if you are. See if that helps
Old 10-24-2018, 03:47 PM   #10
Yousend
Drives: 2014 FR-S
Finally did, there was a crack in the rotor and the drum is not round anymore, it's a bit bent. I hope once it is replaced it will fix the vibration issue.
https://imgur.com/a/jJtiPJG
The Following User Says Thank You to Yousend For This Useful Post:
guybo (10-26-2018)
Old 10-24-2018, 05:17 PM   #11
ls1ac
ls1ac's Avatar
You will still need to check the cable as a stuck cable could have overheated the drum section and caused the crack.
The Following User Says Thank You to ls1ac For This Useful Post:
Yousend (10-25-2018)
Any solutions to overheating coilpacks? Turbo Tracking / Autocross / HPDE / Drifting 11 12-21-2018 11:36 PM
whole lot of weirdness/possible overheating shaynek Issues | Warranty | Recalls / TSB 7 08-01-2018 06:56 PM
Overheating stick shift sj30jet Engine, Exhaust, Transmission 8 06-12-2017 01:03 PM
BRZ overheating Notso BRZ First-Gen (2012+) — General Topics 67 06-25-2016 12:01 PM
intermittent parking brake light trippinbillies40 Issues | Warranty | Recalls / TSB 8 03-15-2016 03:59 PM
