| Software Tuning Discuss all software tuning topics. |
Drives: 2013 MY14 Toyota gts86 Turbo
AEM Tru Boost Vacuum Line
Hey I have finished installing my Aem Tru Boost gauge into my Turbocharged 2013 Gts86, everything is connected, if it wasn’t the gauge would be showing Error.
I have tapped the vacuum line from the gauge into the brake booster and the gauge is reading double the amount of psi the car is running, my oft reads the correct amount and the gauge is reading double that amount. Where the oftv2 will read about 9/10, the gauge will read -18/-19 Where about can I tap the vacuum line from the boost gauge?I’ve attached the bov vacuum line into the 4 piece connector with the boost gauge. Thanks a bunch! |
#2 |
Drives: brz 2017 hksv2
with oft you mean "boost" value?
boost value is a relative pressure measurement, on brake boost line is manifold absolute pressure, ergo boost + atmospheric pressure |
#3 | |
Drives: WRB BRZ
Edit: main point being that there is no concern with your routing and you can go enjoy the boost. |
| The Following User Says Thank You to Fred E For This Useful Post: | tomm.brz (05-02-2019) |
#4 |
Yeah with oft I meant boost value, I just would have thought it should be reading the same as the oft but then again the oft doesn’t have a vacuum line being tapped into the brake booster line
#5 | |
Looks weird when it’s -18/-19 then goes positive when hitting boost while the oft displays -10 and reaches positive boost “naturally” |
| Where is the safest spot to T a vacuum line? | Wil | Engine, Exhaust, Transmission | 9 | 07-18-2017 09:58 AM |
| Under manifold vacuum line for dedicated BOV source? | xkalelx | Forced Induction | 4 | 01-20-2016 05:09 PM |
| Turbo vacuum line setup | g0odspeed | Forced Induction | 13 | 12-13-2015 12:40 AM |
| Vacuum hose for boost controller | ChrisD | Forced Induction | 6 | 08-13-2015 04:24 PM |
| -30hg/in vacuum and only 1 psi boost | lx93 | Forced Induction | 6 | 06-02-2015 07:31 PM |
