Old 01-20-2016, 07:37 AM   #1
xkalelx
xkalelx's Avatar
Drives: 2013 BRZ black
Under manifold vacuum line for dedicated BOV source?
Picture stolen from @Sniper2606
Since I'm using the EVAP harness to control the EBCS, can I delete the EVAP solenoid, plug the hardline that leads the EVAP solenoid, and use the manifold port on the bottom side for a vacuum/boost source? Did a search but just kept finding threads about putting clamps on and leaving EVAP as-is.
What does the EVAP solenoid do when no voltage is applied? NO or NC? Is it OK that the solenoid sees boost anyway?
TIA
xkalelx is offline   Reply With Quote
Old 01-20-2016, 07:56 AM   #2
crazyfrenchbiker
Hot Lava 6MT
crazyfrenchbiker's Avatar
Drives: Hot Lava FR-S
It's normal close, but that line will pop off at 10+ psi.
You can definitely use it as a vacuum source.
I've deleted mine, just to simplify things and reduce a bit of weight.
crazyfrenchbiker is offline   Reply With Quote
Old 01-20-2016, 09:57 AM   #3
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Drives: 2006 Honda S2000
Go ahead and delete it and use that port as a vacuum source if you want.
Old 01-20-2016, 01:07 PM   #4
xkalelx
xkalelx's Avatar
Cool, thanks guys. That's what I thought. What feeds the EVAP solenoid anyway? a charcoal canister?
Old 01-20-2016, 05:09 PM   #5
crazyfrenchbiker
Hot Lava 6MT
Yup, above the gas tank.
Turbo vacuum line setup g0odspeed Forced Induction 13 12-13-2015 12:40 AM
Magazine dedicated to Twins sftateofmind BRZ First-Gen (2012+) — General Topics 1 04-01-2015 01:02 AM
what if you dedicated $2,000 brichard0625 Engine, Exhaust, Transmission 28 04-07-2013 01:13 AM
Dedicated race series? Swift Tracking / Autocross / HPDE / Drifting 48 10-30-2012 09:41 PM
Dedicated to those who are in a YARIS! do to them having issues with there FRS/BRZ 86'ing Issues | Warranty | Recalls / TSB 23 09-15-2012 04:57 PM
