Drives: 2013 BRz Premium
-30hg/in vacuum and only 1 psi boost
hello all!
so just recently sent my Vortech SC back to their factory to rebuild the v3 into the oil fed v2 unit. after 2 months of waiting and finally i got it back. So the shop installed my supercharger and put it all back together, keeping the same pulley size and all that. However... The car is not getting power or much boost at all. according to Torque app, during idle i get about -27hg/in and lift off i get -31. Seems quite low for vacuum as before my car was -20 range. and WOT i get about 1 pound of boost. and the car feels like naturally aspirated power level. Before I was seeing about 9 pounds of boost with my 3.48 pulley. Same tune, same setup, and I am very confused. So the shop pressurized the system and we are sure there is no leak anywhere. i am trying to diagnose and trace down the problem. So, What could cause the symptom of a high number in vacuum and almost no boost?
Drives: 2013 Asphalt FRS
I know they have a cw and a ccw what's the odds they sent you the wrong one and its spinning backwards. Is their a way they could of routed the belt backwards? Bypass line leaking??? good luck
Thupercharged
Are you reading the pressure from the ecu or an aftermarket sensor/gauge
If from the ecu, 27 inches of vacuum is very high for a warm idle, you should be seeing around 20 Correct map sensor installed? Does pressure rise at all with rpm during a pull? Boost leak test done? Bypass valve stuck open?
2013 FRS
Vortech V3 11psi Revworks UEL - PLM Overpipe - MOTIV catted frontpipe - Invidia Q300 2019 Series.Grey STI - Stage1+ SF |
NASA SpecE30 Racer
What gauge are you getting this -30 reading from? My guess is that the calibration is off on it.
- King Tut
Street/Track Car: 2006 Honda S2000 TT3 || Race Car: 1987 BMW 325is SpecE30 || Tow Vehicle: 2014 RAM 1500 EcoDiesel Sold Cars: 2012 BMW M3 || 2013 Subaru BRZ || 2012 Porsche Cayman R || 2009 Chevrolet Z06 || 2009 BMW M3 || 2004 BMW M3 || 2004 Nissan 350Z |
| The Following User Says Thank You to King Tut For This Useful Post: | Cal3000 (06-01-2015) |
Drives: Panda FR-S
Try resetting the Torque app. At times the calibration becomes funky within the app. Some days I'll hit 4psi in boost and some days it will be fine at 9psi. I'm on the 3.48 pulley.
Vortech SC on 9psi Pulley, Invidia Catless Front Pipe, Invidia N1 Catback Exhaust
![]() 242whp/197ft-lb on Mustang Dyno (91 octane water) 284whp/223ft-lb on Mustang Dyno (E85) Delicious Tuning |
Drives: 2013 Ultramarine FR-S
My guess is calibration as well. You can't pull -31 in/hg. -30 in/mg is absolute vacuum...
Drives: 2013 Firestorm FRS
either way something must be wrong if it feels that slow...
| Digital boost gauge w/ vent pod grim speed boost controller | Meetjoeblack | Engine, Exhaust, Bolt-Ons | 0 | 03-09-2015 01:27 PM |
| Vacuum at idle.... | BadBRZ | Forced Induction | 1 | 08-30-2014 12:47 AM |
| Affordable vacuum? | swift996 | Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) | 21 | 04-02-2014 06:21 PM |
| Vacuum help! | Scalzo | Forced Induction | 6 | 06-26-2013 02:12 PM |
| Memorial Deal!!White MaxTow 30 PSI Boost/Vacuum Gauge | Tubano-shop | Interior Parts (Incl. Lighting) | 0 | 05-27-2013 07:47 AM |
