Old 07-17-2017, 10:46 AM   #1
Wil
Wil's Avatar
Drives: Drives like a crab.
Where is the safest spot to T a vacuum line?
Hi everyone,
Everything is in the title.
If you could provide some picture of the spot you describe as well, that would be very appreciated! I'm not a mechanic unfortunately so the easiest the info is to understand, the better it is for me.
I'm trying to build a custom vacuum-actuated exhaust cutout and am looking for the safest vacuum source.
By safest, I mean something that will not falsify the data the ECU receives.
Thank you in advance!
Have a nice day,
Wil
Wil is offline   Reply With Quote
Old 07-17-2017, 12:07 PM   #2
G-Man
G-Man's Avatar
Drives: 1980 corvette, 2014 Subaru BRZ
curious why you want to go vacuum vs electric?
G-Man is offline   Reply With Quote
Old 07-17-2017, 12:21 PM   #3
Wil
Wil's Avatar
I'm running an electric cutout for the moment and, even if I love it for its great versatility and the sound it allows my car to produce, I'm not a big fan of the sound it when shifting or when no thottle is applied at high rev.
I think a vacuum actuated cutout would makes the engine shine instead of the exhaust itself.
Old 07-17-2017, 01:23 PM   #4
Amputechture
Drives: 2014 BRZ
I have ran vacuum source off of the brake booster line for close to a year now with no issues. There are a number of other spots that are post MAF sensor to reference vac from. If you remove the 'D4-S' engine cover there is a manifold to PCV connection. Underneath the intake manifold there is a nipple also, but that would involve deleting the EVAP purge solenoid....no one really does that unless they are using that harness for boost control.
JDL Auto Design///Turboback///Enkei///Tial///RSR///HRI Tuned
Amputechture is offline   Reply With Quote
Old 07-17-2017, 01:47 PM   #5
go_a_way1
Not Bаnned Anymore
go_a_way1's Avatar
Drives: Heavily Modified FRS
Brake booster after the check valve is a good spot. And under the intake manifold cover there are lines you can also tap but the booster is your best bet if your MT if your AT then there is a spare port under the intake manifold cover you can use.
Old 07-17-2017, 02:19 PM   #6
Wil
Wil's Avatar
Thank you for the blistering quick answers!
So, T'ing the brake booster line would look a little bit like this, right?
Old 07-17-2017, 02:32 PM   #7
Amputechture
Drives: 2014 BRZ
Precisely
Old 07-17-2017, 10:38 PM   #8
Wil
Wil's Avatar
Thank you!
Old 07-17-2017, 11:35 PM   #9
Barefootdan
Barefootdan's Avatar
Drives: 2017 BRZ
Interested in your setup. Could you post some pics and diagrams when completed?
Barefootdan is offline   Reply With Quote
Old 07-18-2017, 09:58 AM   #10
Wil
Wil's Avatar
It's not going to be anytime soon since I'm in Canada (and my car is in Belgium) until middle of August.
I will try to make a DIY tutorial since I couldn't find any information of such setup.
Under manifold vacuum line for dedicated BOV source? xkalelx Forced Induction 4 01-20-2016 05:09 PM
Turbo vacuum line setup g0odspeed Forced Induction 13 12-13-2015 12:40 AM
The safest driving method? Frs x3 Scion FR-S / Toyota 86 GT86 General Forum 67 06-27-2014 10:38 PM
Safest way to get 15%-20% more NA HP and torque vs. stock vagvoba Engine, Exhaust, Transmission 78 05-01-2013 09:33 AM
where is the safest place to park? enjoi23 Scion FR-S / Toyota 86 GT86 General Forum 36 09-12-2012 08:27 PM
