Old 01-29-2018, 12:08 AM   #1
speedyspaghetti
speedyspaghetti's Avatar
Drives: 2016 FR-S
Vibrating gas pedal?
Hey everyone,
I've been experiencing a really weird thing recently - my accelerator vibrates when I hold it at cruising speeds and it makes my foot tingle/feel like it's going to fall asleep. Has anyone else experienced this? Any suggestions? Car has 28k miles, so I could bring it to the dealer, but it seems like one of those issues where they would say "oh we can't feel it" and waste my time.
Thank you!
Daily: 2016 FR-S
Weekend: 2002 Boxster S
Retired: 2007 Mazdaspeed3, 2000 M5
speedyspaghetti is offline   Reply With Quote
Old 01-29-2018, 02:27 AM   #2
Originally Posted by speedyspaghetti View Post
Hey everyone,
Thank you!
Well, that's a new one, for me at least.
Are you sure it's the accelerator pedal assembly itself or what it's attached to, that is vibrating ...??
You might check to see that it's bolted down tight.
If you use the cruise control, does your foot still tingle (careful, that's a trick question ....).
Next ......
I call on @Ultramaroon to see if that old fool is still up. I'm sure he will have some sort of cocka mame theory ......
Old 01-29-2018, 02:38 AM   #3
finch1750
Undisputed El Presidente
finch1750's Avatar
Drives: Zenki 37J ZN6
Hey everyone,
Thank you!
There are no other vibrations in the car? Steering wheel, shifter, etc?
Old 01-29-2018, 08:10 AM   #4
chaoskaze
The Fail Boat
chaoskaze's Avatar
Drives: CWP S.B.
Next ......
humfrz, I wish my grandpa/grandmom goes to sleep as late as you. so they don't wake up 4 in the morning & make me jump when i go pee in the middle of night.
Old 01-29-2018, 10:25 AM   #5
speedyspaghetti
Drives: 2016 FR-S
The shifter vibrates as well.
Daily: 2016 FR-S
Old 01-29-2018, 10:26 AM   #6
speedyspaghetti
Drives: 2016 FR-S
Next ......
I'll have to check the pedal assembly, but it doesn't seem like it's anything else. Steering wheel or seats/chassis don't vibrate, the only thing is that the shifter vibrates a decent amount.
Daily: 2016 FR-S
Old 01-29-2018, 10:29 AM   #7
Did you change tires recently? When I run my snow tires everything vibrates. I get used to it.
Anything change that could impact alignment? Pothole hit, etc?
It may be something along that line where the vibration is just enough to be felt though the smaller fittings such as the pedal mount and shift lever. Could be so many things you may need to slowly work through process of elimination.
Old 01-29-2018, 10:39 AM   #8
stevesnj
stevesnj's Avatar
"You got mud in your tires" Get your tires rotated and balanced.
My 2016 Build thread
Old 01-29-2018, 10:41 AM   #9
8RZ
The Gunshine State
8RZ's Avatar
Drives: '14 BRZ Limited
I wish I sprung for the "foot massager" option.
Current DD: M235i
8RZ is offline   Reply With Quote
Old 01-29-2018, 10:51 AM   #10
We DO NOT want to know what you would do with the vibrating shifter option.
Old 01-29-2018, 10:59 AM   #11
Your car didn't come with one of these ........??
Old 01-29-2018, 11:05 AM   #12
8RZ
The Gunshine State
8RZ's Avatar
Current DD: M235i
Old 01-29-2018, 11:13 AM   #13
Well, chaoskaze, I understand the part about your grandparents getting up at 4 in the morning ....... but I don't understand the rest .......
(and I'm not sure I want to ......)
Old 01-29-2018, 11:19 AM   #14
That was one funny movie ............
Buzzing/vibrating gear stick paulca Issues | Warranty | Recalls / TSB 49 10-12-2017 11:47 AM
Vibrating shifter fix! Superhatch Issues | Warranty | Recalls / TSB 51 06-05-2016 10:56 PM
Rear License plate vibrating primalT Cosmetic Modification (Interior/Exterior/Lighting) 11 05-03-2014 01:20 AM
Exhaust is vibrating a bit.. pgeist Engine, Exhaust, Transmission 3 07-09-2013 02:00 AM
Buzzing/vibrating speaker fix CBR600RR DIY (Do-It-Yourself) Guides 3 05-21-2013 12:11 PM
