Drives: 2014 BRZ AT
Rear License plate vibrating
I had two 10" subs installed in my BRZ trunk yesterday. They're great, but they are making my rear license plate vibrate. I have a license plate holder/bracket that is metal and carbon fiber.
The vibration will stop if I add screws to the bottom two holes of the plate bracket instead of just the top two holes. But the car doesn't have two holes there so I'm going to drill them in I guess. Does anyone know the proper screw size, and should I also get one of those plastic things that the screw goes into instead of just a raw metal hole? Thanks |
Drives: 13 GBS BRZ
Just stick some 3m foam on the back of the license plate. No drilling, no rattles.
Trust me, I'm the Doctor
Put some dynamatt on the back of the license plate towards the bottom. If it's the plate rattling against the frame, then put the dynamat on the frame.
Daily Driver: 2014 BRZ 6MT Limited ^GT5 Replay Photo Mode^ |
Drives: 2013 FRS
I'd disconnect the subs before I'd tap wood screws into my car. Just do what he said and you're fine.
Sent from my SGH-T999 using Tapatalk 2 |
Drives: '13 DGM BRZ Limited
I would suggest sticking any kind of foam tape on the car instead of the plate. Dirt/dust can get caught on the foam and with vibration would scratch the hell out of the paint. If you stick the foam to the car, the plate will take any damage. You can remove the foam tape and clean it up with cleaners if you need to later. Easier than having to repair scratches.
Drives: 86
#7 | |
Drives: 13 GBS BRZ
Drives: Fr-s 2013 white out
I put 3m foam in the back too cause it rattled now I forgot I had tape there untill this post came up haha
Drives: It alls slivery blue.
I had this problem many many years ago with my Celica Alltrac, I had 4 10's in the back. I folded up a box from a 12 pack of beer and stuffed it under that plate and it fixed it.
Sorry I just found an excuse to tell that story and I had to. haha.
#10 |
ProCrastinationConsultant
i'm planning on doing some closed-cell foam on the back of my plate.. that reminds me, i need to pick some up this weekend to do it..
i can't hear it in the car, so it doesn't bother me as much!
#11 |
Drives: 2013 subaru limited wrb brz
If your brz came with the trunk carpet liner. Just pull the liner off and put dynamat where the liner is and then put the liner back on and the trunk wont rattle. I lined my whole trunk and trunk lid and under the rear deck lid. No rattles anywhere.
![]() Portland 86ers |
#12 |
What I did was keep my paper plates from the dealership & put them behind the state plate. The paper acts as the buffer & isn't at all noticeable as it's hidden completely by frame and plate.
On phone I am. Therefore, if mistakes I make, Frank Oz blame you should.
| Rear license plate screws | Zaneman | BRZ First-Gen (2012+) — General Topics | 8 | 03-22-2014 10:30 PM |
| FR-S rear license plate frame suggestions? | tzhu07 | Scion FR-S / Toyota 86 GT86 General Forum | 58 | 03-12-2014 02:36 PM |
| Rear License Plate Scratch | DBacon1052 | Issues | Warranty | Recalls / TSB | 11 | 09-20-2012 04:06 AM |
| Rear License Plate Frame | ashtray | Cosmetic Modification (Interior/Exterior/Lighting) | 19 | 07-23-2012 01:47 AM |
| rear license plate frame | meekhotglass | Cosmetic Modification (Interior/Exterior/Lighting) | 1 | 06-20-2012 10:08 PM |
