Old 10-05-2017, 09:28 AM   #1
paulca
Drives: Toyota GT86 Coupe Red (UK)
Buzzing/vibrating gear stick
I'm really unlucky or something. My 2014 GT86 had the dreaded buzzing/vibrating gear stick at high RPM. I had the whole gear stick changed twice under warranty, but they refused to analyse the root cause.
Now my 2017 is developing the same fault. It will only get worse.
What I think is causing it is that the gear level itself shakes around. If I put the car in first and accelerate slowly I can physically see the gear stick moving back and forward (previous GT86 it stirred around in a circle) which increases in frequency with RPM. At 4-7k it's a vibrating blur. This must be shaking the thing to pieces until it loosens up and starts to rattle and buzz.
The question is, other than take it to a dealer and have them replace the gear stick without addressing the actual root cause what else can I do?
How many of you guys suffer or have suffered from this issue? I can see quite a few in the UK with it. Some have mentioned uprating the bushes fixes it, but when the dealership did my bushes as an attempted fix it only partially worked and the 3rd gear stick in the car was starting to rattle when I sold it back to them.
Trunk = Boot | Hood = Bonnet | Sidewalk = Pavement | Transmission = Gearbox | Stick/shifter = Gear knob/stick | E-brake = handbrake | Windshield = Windscreen | Turn signal = Indicator
paulca is offline   Reply With Quote
Old 10-05-2017, 09:50 AM   #2
StraightOuttaCanadaEh
Wes
Mine rattles but I think that's cause I changed my reverse lockout. Can't recall if it rattled before that. Don't think it did
Old 10-05-2017, 03:18 PM   #3
HKz
Reformed
HKz's Avatar
Drives: '23 GRC, '11 Prius, '04 RAV4
I thought this was common with the twins and one of those mere annoyances. after I put on about 10 K miles, my 16's stick started rattling once in a while only in 2nd gear and only above 5 K RPMs. 20 K miles later and I've noticed that during most of my drives i usually don't get the rattles not to mention it is hard to pinpoint what circumstances/factors are most likely causing it. i've read plenty of other threads where the rattle continued despite replacing the stick/trans.. since this has never caused any actual issues, i've chalked this up to be as much of a "hindrance" as our crickets.
HKz is offline   Reply With Quote
Old 10-05-2017, 03:24 PM   #4
I don't think mine has ever made a sound. If it did I never noticed. Now I will be listening for it and it will bug the crap outta me if it does. Thanks a lot guys, you ruined Christmas!
Old 10-05-2017, 03:42 PM   #5
humfrz
Same here. My shifter lever doesn't move/vibrate, or at least I'm preoccupied watching the road and don't notice it, and it doesn't make any sounds, at least that I can hear.
And, NO, I'm NOT going to start looking or listening for it .......
humfrz
Old 10-05-2017, 04:34 PM   #6
Spuds
The Dictater
Spuds's Avatar
Drives: '13 Red Scion FRS
humfrz
Probably wouldn't hear it anyway...
Old 10-05-2017, 06:48 PM   #7
Decep
Drives: 2013 FR-S Series 10
You would definitely hear it, you dont have to pay attention to hear it.
I test drove a used one that suffered from this, it was super annoying.
Old 10-05-2017, 06:53 PM   #8
humfrz
Huh ....??
humfrz
Old 10-05-2017, 07:36 PM   #9
D5teph
Automotive Enthusiast
D5teph's Avatar
Drives: Zenki 86
After I switched my shift knob, I started hearing the rattles especially during 5k RPMs. Sucks but I got used to it lol.
D5teph is offline   Reply With Quote
Old 10-05-2017, 07:41 PM   #10
The problem lies in that now I will probably hear it even if it isn't there.
Old 10-05-2017, 08:22 PM   #11
HKz
Reformed
HKz's Avatar
hey as long as the gear engagement feels good and nothing breaks while wot then I'm happy
Old 10-05-2017, 08:26 PM   #12
Lakitu
Lakitu's Avatar
Drives: 2017 Halo 86
Thankfully I've got no rattling. Just strange smells on my hands and clothes after driving.
Lakitu is offline   Reply With Quote
Old 10-05-2017, 08:33 PM   #13
driftguy
driftguy's Avatar
Drives: In between cars... 2018 Ninja 1000
I think most manual transmission gear knobs will vibrate at some sort of RPM. I count myself lucky that I have not noticed or it's not nearly as intrusive as it is for those in this thread. Perhaps a weighted knob could help, but determining the root cause would be ideal. FYI I have a 2013 with just over 50k miles.
driftguy is offline   Reply With Quote
Old 10-05-2017, 09:11 PM   #14
Especially on a RWD where the shifter is directly attached to the tranny. FWD and most AWD shifters are connected by cables and rods that isolate a lot of the vibration from the shifter so people that are not used to them notice it more.
Vibrating shifter fix! Superhatch Issues | Warranty | Recalls / TSB 51 06-05-2016 10:56 PM
Torque dip sound: rattling / vibrating mike_ekim1024 Software Tuning 6 11-06-2013 02:17 PM
Exhaust is vibrating a bit.. pgeist Engine, Exhaust, Transmission 3 07-09-2013 02:00 AM
Buzzing/vibrating speaker fix CBR600RR DIY (Do-It-Yourself) Guides 3 05-21-2013 12:11 PM
Gear Stick HELP FaNtaSy Engine, Exhaust, Transmission 12 03-17-2013 11:03 PM
