Old 07-08-2013, 08:28 PM   #1
pgeist
pgeist's Avatar
Drives: 2013 Black BRZ Limited 6MT
Exhaust is vibrating a bit..
I noticed the other day that my cat back exhaust is vibrating at idle a bit.. enough to cause me to post this lol.
It's not hitting anything.. just visually vibrating (the tips).
Is this normal? Do others experience this?
Will stiffer exhaust hangers solve this, but maybe transfer the vibration into the car? I recently installed a cat delete front pipe, maybe I tightened the connection near the donut gasket too much? (where the spring bolts are, not sure what they are officially called)
Any insight or help is appreciated!
Zeta Stage 2 Drop In + Red Silicone Tubing || Zeta SS Cat Back || DC Sports Cat-Delete Front Pipe || Torque Pro + MiniOBD Bluetooth || Fumoto F-108 Drain Valve || Konig Daylite Gold 17x7 +40 14.2lbs || Anarchy Motive Shift Knob
Future: Catted header, OEM Audio+
pgeist is offline   Reply With Quote
Old 07-08-2013, 08:42 PM   #2
FeaR-S
Drives: Great White
Check the hangers if the bolts were loose you would hear an exhaust leak.
FeaR-S is offline   Reply With Quote
Old 07-08-2013, 09:09 PM   #3
pgeist
pgeist's Avatar
Yea no leak that I can hear.. I guess it's time to upgrade my hangers?
Old 07-09-2013, 02:00 AM   #4
Mild2Wild
Drives: Firestorm FR-S
You might be right that the vibrations could transfer to the car. Exhaust vibration might be better than third brake light rattling or something....
Mild2Wild is offline   Reply With Quote
Loud exhaust / Buddy Club Spec II exhaust help! chiefshayan Engine, Exhaust, Transmission 26 12-06-2019 05:59 PM
Vibrating shifter fix! Superhatch Issues | Warranty | Recalls / TSB 51 06-05-2016 10:56 PM
Exhaust System/Exhaust Manifold Removal and Replacement GrimmSpeed DIY (Do-It-Yourself) Guides 52 11-11-2015 09:30 PM
Perrin Catback Exhaust vs Nameless Performance Exhaust. vignesh Engine, Exhaust, Transmission 201 06-05-2013 09:47 PM
Buzzing/vibrating speaker fix CBR600RR DIY (Do-It-Yourself) Guides 3 05-21-2013 12:11 PM
