Old 04-29-2013, 10:15 PM   #1
CBR600RR
Drives: Raven Black
Buzzing/vibrating speaker fix
I figured out a way to stop my right and left door speakers from buzzing/vibrating. I pulled out a foam roll-out used for camping and cut the corner off and then cut that little piece into 4 cubes about 1cm x 1cm in size.
If you look at the speaker knee pads right by the bottle holder in the door you can see that there is a little cap in there and you can even pull it back a little bit.
Well I just jammed two of these little foam cubes inbetween this area on each side.
I found that got rid of the vibration/buzzing completely (I don't blare my music, but I do like it loud at times)
Here are a few pics to visualize what I am talking about:
Old 04-29-2013, 10:36 PM   #2
CamryDS
Drives: 2003 Camry Blue | 2013 FR-S White
I see a problem with this -- what happens when the enclosure gets loose? stick another piece of foam there? It looks like it'll just stretch out.
CamryDS is offline   Reply With Quote
Old 05-20-2013, 11:20 PM   #3
Spidey
Spidey's Avatar
Drives: 2013 FR-S, '85 Corolla GT-S Hatch
Has anyone taken the door panels off and come up with a different solution for this? The rattle is extremely annoying. Even using a high pass filter and lowering the bass a bit. This is my only complain on this car. I don't think that's the only spot that vibrates either.
Spidey is offline   Reply With Quote
Old 05-21-2013, 12:11 PM   #4
frslee
Just drive it
Drives: 13' FR-S
I think you can easily remove the door panel and put some stuff where it vibrates/rattles. I've seen people doing this mod, but haven't seen exact picture where they put the stuff.
frslee is offline   Reply With Quote
Vibrating shifter fix! Superhatch Issues | Warranty | Recalls / TSB 51 06-05-2016 10:56 PM
exhaust buzzing 3k to 4k input please! ft86me Engine, Exhaust, Transmission 11 03-24-2013 01:02 AM
FRS-off/rear wheel buzzing... iaclimber4 Scion FR-S / Toyota 86 GT86 General Forum 4 01-31-2013 06:25 PM
Intermittent buzzing from below the steering wheel? brzninja BRZ First-Gen (2012+) — General Topics 12 01-05-2013 10:01 PM
buzzing noise from steering wheel FR-S :DK Scion FR-S / Toyota 86 GT86 General Forum 1 10-07-2012 01:52 AM
