#85 |
Drives: 2017 BRZ Limited w/Performance Pack
I know how brakes work. I've been around all forms of race vehicles.
I figured out what rotors I need. |
#86 |
Drives: 2017 BRZ Yellow Spec Ed 1of500
2017 Hawk Ceramic Part numbers
See My Post on the Hawk Ceramics Part numbers
#87 |
The pads wasn't the issue. Rotors rusting is or I should say was the issue. I bought a set of aftermarket dimpled and slotted 2017 WRx STi rotors(redrilled myself) and cleaned up the OEM pads. The car will stand on the front bumper now. I've made fifteen hard stop at speed with no fading.
#88 |
Read through this whole thread to find this. That is not affordable. The rotor and pad prices are bonkers.
Really seems like the best choice is Essex. I live in the North so I'll take em off in the winter so I can run 16" snows. |
| The Following User Says Thank You to Randoman5 For This Useful Post: | strat61caster (10-11-2017) |
#89 |
The best choice if buying is to make sure it has the performance package. All that for $1K...... But wait there is more, You also get accepatble wheels that do not need replaced. (At least for me, I like the PP wheels) I am 99% positive they will hold 245/40R17 PSS just fine. And if you buy now they will throw in some better struts that do not need to be replaced the day you drive off the lot for free.
#90 | ||
Proud of BOXER
Drives: Subaru Boxer
You want to put 245s on a 7.5" width wheel? Have fun with that.
#91 |
#92 | |
Proud of BOXER
| The Following 2 Users Say Thank You to Clipdat For This Useful Post: | strat61caster (10-13-2017), tintumz22 (10-13-2017) |
#93 | |
Drives: 2013 Ultramarine FR-S
Minimum 8" wheel w/ Recommended 8.5" width. 7.5" is a bit too narrow for that size tires.
| The Following User Says Thank You to DustinS For This Useful Post: | strat61caster (10-13-2017) |
#94 |
Ok you have all pointed to infor that I have already been thru. Moving a bead in .250 per side to me is not that much change. If you measure my wheels and tires now the tread at least .500 less that the rim. The specs on this tire is 1.1 wider than stock. With those mesurements that puts it around square. BMW put a 245 on a 7.5 inch rim stock. When you search tribal knowledge you get about a 70% it will fit to a 30% you will die. Of those numbers the 70%, 10% had done it with no issues, 0% stated they did not. Out of the 30%, 0% had any knowlage other than manufacturer recommendations.
Anyway lets get back to Brembo talk. Like I stated before, If you are buying new there is no reason not to spend the 1K on the performance package. To me that was a deal killer. |
| The Following User Says Thank You to Grady For This Useful Post: | CSG Mike (10-14-2017) |
#95 | |
http://counterspacegarage.com/produc...-red-gt86.html |
| The Following User Says Thank You to CSG Mike For This Useful Post: | Randoman5 (10-16-2017) |
#96 | |
Not recommended unless it's for a very specific application and that's the only way you can be competitive. |
| The Following 2 Users Say Thank You to CSG Mike For This Useful Post: | Grady (10-17-2017), strat61caster (10-14-2017) |
#97 | |
#98 |
Drives: Track preped NA FRS
I have run 245 PSS in a 7.5" wheel (17" and +45 offset, so very close to PP wheels). Dont do it, its awful, the car doesnt feel responsive at all, there is a lot of flex in the tire, I was marginally faster (like less than 1sec) than I was on the 215 Primacys. If you want a "soft cadillac ride" on the street, then yes, thats what it might feel like, but if you expect better performance out of them, I'd say stick with 215-225 in a 7.5" wheel (PSS is still a decent choice for street, but I'd pass them for track driving).
| The Following User Says Thank You to Icecreamtruk For This Useful Post: | Grady (10-17-2017) |
| CSG Brembo Brakes | LenA | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 29 | 07-12-2024 10:05 AM |
| Real STI BREMBO package upgrade - DIY | Trap63 | DIY (Do-It-Yourself) Guides | 40 | 06-15-2022 09:25 PM |
| EVO 7 BREMBO FRONT BRAKES ON BRZ? | NOTORIOUS.BRZ | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 3 | 01-26-2016 12:24 AM |
| Evo X brembo brakes | Justkiz | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 1 | 08-12-2013 02:00 AM |
| R35 Brembo Brakes - Full set | 2013GTRNate | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 8 | 10-06-2012 10:08 AM |
