Old 09-10-2017, 08:01 PM   #85
BRZ17
Drives: 2017 BRZ Limited w/Performance Pack
I know how brakes work. I've been around all forms of race vehicles.
I figured out what rotors I need.
BRZ17 is offline   Reply With Quote
Old 10-04-2017, 04:10 PM   #86
007BRZ
007BRZ's Avatar
Drives: 2017 BRZ Yellow Spec Ed 1of500
2017 Hawk Ceramic Part numbers
See My Post on the Hawk Ceramics Part numbers
007BRZ is offline   Reply With Quote
Old 10-07-2017, 04:51 PM   #87
BRZ17
The pads wasn't the issue. Rotors rusting is or I should say was the issue. I bought a set of aftermarket dimpled and slotted 2017 WRx STi rotors(redrilled myself) and cleaned up the OEM pads. The car will stand on the front bumper now. I've made fifteen hard stop at speed with no fading.
Old 10-11-2017, 01:06 AM   #88
Randoman5
Read through this whole thread to find this. That is not affordable. The rotor and pad prices are bonkers.
Really seems like the best choice is Essex. I live in the North so I'll take em off in the winter so I can run 16" snows.
Originally Posted by valtore101 View Post
Looks like they are listed as a bit cheaper than
this on Subaru's website.
FRONT:
Calipers: $699 ea
Rotors: $433 ea
Pad Kit: $299
Total: $2563
REAR:
Calipers: $649 ea
Rotors: $409 ea
Pad Kit: $240
Total: $2356
Randoman5 is offline   Reply With Quote
The Following User Says Thank You to Randoman5 For This Useful Post:
strat61caster (10-11-2017)
Old 10-13-2017, 08:21 AM   #89
Grady
Grady's Avatar
The best choice if buying is to make sure it has the performance package. All that for $1K...... But wait there is more, You also get accepatble wheels that do not need replaced. (At least for me, I like the PP wheels) I am 99% positive they will hold 245/40R17 PSS just fine. And if you buy now they will throw in some better struts that do not need to be replaced the day you drive off the lot for free.
Old 10-13-2017, 12:52 PM   #90
Clipdat
Proud of BOXER
Clipdat's Avatar
Drives: Subaru Boxer
You want to put 245s on a 7.5" width wheel? Have fun with that.
Originally Posted by humfrz
I'm old and lazy
Old 10-13-2017, 03:47 PM   #91
Grady
Grady's Avatar
I will! You going to have to have a little more technical knowledge than “have fun with that” to help.
Old 10-13-2017, 03:53 PM   #92
Clipdat
Proud of BOXER
Clipdat's Avatar
http://www.tyresizecalculator.com/ch...rim-size-chart
I'm old and lazy
The Following 2 Users Say Thank You to Clipdat For This Useful Post:
strat61caster (10-13-2017), tintumz22 (10-13-2017)
Old 10-13-2017, 03:54 PM   #93
DustinS
DustinS's Avatar
Drives: 2013 Ultramarine FR-S
245/40/17 PSS Tirerack
Minimum 8" wheel w/ Recommended 8.5" width. 7.5" is a bit too narrow for that size tires.
The Following User Says Thank You to DustinS For This Useful Post:
Old 10-14-2017, 10:29 AM   #94
Grady
Grady's Avatar
Ok you have all pointed to infor that I have already been thru. Moving a bead in .250 per side to me is not that much change. If you measure my wheels and tires now the tread at least .500 less that the rim. The specs on this tire is 1.1 wider than stock. With those mesurements that puts it around square. BMW put a 245 on a 7.5 inch rim stock. When you search tribal knowledge you get about a 70% it will fit to a 30% you will die. Of those numbers the 70%, 10% had done it with no issues, 0% stated they did not. Out of the 30%, 0% had any knowlage other than manufacturer recommendations.
Anyway lets get back to Brembo talk.
Like I stated before, If you are buying new there is no reason not to spend the 1K on the performance package. To me that was a deal killer.
The Following User Says Thank You to Grady For This Useful Post:
CSG Mike (10-14-2017)
Old 10-14-2017, 12:20 PM   #95
CSG Mike
CSG Mike's Avatar
Have you considered the CSG Brembo?
http://counterspacegarage.com/produc...-red-gt86.html
Randoman5 (10-16-2017)
Old 10-14-2017, 12:22 PM   #96
CSG Mike
CSG Mike's Avatar
You can do it, but you'll get a very vague feel out of the steering wheel, and you'll get a ton of sidewall movement, resulting in sloppy response and a very quick overheating of your tire due to sidewall flex.
Not recommended unless it's for a very specific application and that's the only way you can be competitive.
Grady (10-17-2017), strat61caster (10-14-2017)
Old 10-16-2017, 10:46 AM   #97
Randoman5
I'll have to take a closer look. The Brembos are gorgeous but it's tough to beat the sexy ass 2-piece rotors that also only cost $165 bucks to replace.
Old 10-16-2017, 10:54 AM   #98
Icecreamtruk
Drives: Track preped NA FRS
I have run 245 PSS in a 7.5" wheel (17" and +45 offset, so very close to PP wheels). Dont do it, its awful, the car doesnt feel responsive at all, there is a lot of flex in the tire, I was marginally faster (like less than 1sec) than I was on the 215 Primacys. If you want a "soft cadillac ride" on the street, then yes, thats what it might feel like, but if you expect better performance out of them, I'd say stick with 215-225 in a 7.5" wheel (PSS is still a decent choice for street, but I'd pass them for track driving).
Icecreamtruk is offline   Reply With Quote
The Following User Says Thank You to Icecreamtruk For This Useful Post:
Grady (10-17-2017)
CSG Brembo Brakes LenA Suspension | Chassis | Brakes -- Sponsored by 949 Racing 29 07-12-2024 10:05 AM
Real STI BREMBO package upgrade - DIY Trap63 DIY (Do-It-Yourself) Guides 40 06-15-2022 09:25 PM
EVO 7 BREMBO FRONT BRAKES ON BRZ? NOTORIOUS.BRZ Suspension | Chassis | Brakes -- Sponsored by 949 Racing 3 01-26-2016 12:24 AM
Evo X brembo brakes Justkiz Suspension | Chassis | Brakes -- Sponsored by 949 Racing 1 08-12-2013 02:00 AM
R35 Brembo Brakes - Full set 2013GTRNate Suspension | Chassis | Brakes -- Sponsored by 949 Racing 8 10-06-2012 10:08 AM
