Old 06-07-2017, 04:01 PM   #15
itzaustin
Drives: 2013 FRS 10 series
its likely the overrun fueling timer that adding fuel, that's "fixed" your stalling issue
so those are the settings I changed within the tune that fixed it. I reverted back to the tune that stalls since. then which table should i leave to test? that top right has to do with fuel cut btw. cause Id like to get it not to pop so it doesn't stall just as a temp solution until i get a dyno tune soon. thanks again for all the help man.
itzaustin is offline   Reply With Quote
Old 06-07-2017, 08:03 PM   #16
steve99
Drives: FT86
If you revert any ingnition retard back to normal that will stop the pops and flames
Then you will have to try reverting each table that adds fuel back to normal or towards original to find which ones help with stall
itzaustin (06-07-2017)
Old 06-07-2017, 09:25 PM   #17
itzaustin
alright man thank you for all the help! I'll keep posted on what I find!
DIY turbo setup Amaya Forced Induction 55 07-17-2019 11:22 AM
Best EL setup for NA and turbo Casper_FRS CANADA 14 04-27-2017 01:45 PM
WTB: SBD TURBO SETUP BRZ_HaVoKx Want-To-Buy Requests 5 04-08-2016 10:36 PM
FS: Entire P&L Stage 1 Turbo Setup - Turn key Setup ready to make 400+whp PrimeMotoring Engine, Exhaust, Bolt-Ons 8 10-30-2015 07:36 AM
FS: Entire P&L Stage 1 Turbo Setup - Turn key Setup ready to make 400+whp PrimeMotoring NY / NJ / CT / PA 0 10-20-2014 11:48 AM
