CANADA Canada
Old 09-29-2016, 02:12 PM   #1
Casper_FRS
Drives: 2016 halo frs
Best EL setup for NA and turbo
Hey everyone, I'm new here. I'm looking for best EL header to put on my frs as a NA setup but that's able to easily be converted to turbo build when I'm ready to turbo.
Casper_FRS is offline   Reply With Quote
Old 09-29-2016, 02:49 PM   #2
RedFR-s
Builder/Driver/Enthusiast
RedFR-s's Avatar
Drives: 2013 FR-S 6MT Turbo Firestorm
Typically turbo utilizes complete different headers to mount the turbo (front mount set-up) for most common applications. Any turbo will require a completely new portion of the exhaust (over pipe for the CARB legal one) definitely something different for a rear mount.
If you do supercharger the exhaust system is untouched and any would work.
Andy
1977 Triumph Spitfire 1500 - New Project
2013 Firestorm FR-S 6MT Turbo - Sold
2013 Honda CBR 250 Repsol- Toy
2017 Toyota Tacoma - The Rig
RedFR-s is offline   Reply With Quote
The Following 4 Users Say Thank You to RedFR-s For This Useful Post:
everythingsablur (09-29-2016), go_a_way1 (09-29-2016), Lynxis (09-29-2016), Mr.Impreza (09-29-2016)
Old 09-29-2016, 03:25 PM   #3
Lynxis
Lynxis's Avatar
Drives: 2013 WRB BRZ 6MT
RedFR-s already explained that NA headers can't be used with most turbo setups but didn't answer the question of best NA header. Ace is widely regarded as the best NA EL header and the only EL header capable of eliminating the torque dip. pTuning also makes a proven race header for peak HP gains but it retains the torque dip like all other EL header designs. If you want the best, I'd stick to these 2.
Lynxis is offline   Reply With Quote
The Following 3 Users Say Thank You to Lynxis For This Useful Post:
CSG Mike (10-02-2016), Mr.Impreza (09-29-2016), RedFR-s (09-29-2016)
Old 09-29-2016, 03:42 PM   #4
Casper_FRS
Thanks guys!! Sounds good. I thought greddy or some company made a S pipe after the Header to take out to fit a turbo behind the engine but I could be wrong, can't find it
Old 09-29-2016, 04:20 PM   #5
wparsons
wparsons's Avatar
The JDL EL header can be used as an N/A header or turbo manifold, but it's not going to give N/A gains like the ACE header will. There will be gains, but not as much.
I would just wait if I were you, most turbo kits include the whole manifold and are sold at a discount compared to the individual parts.
flickr
The Following 2 Users Say Thank You to wparsons For This Useful Post:
Old 09-29-2016, 04:21 PM   #6
yelsew
Little Member
yelsew's Avatar
Drives: Bloo - The 13' BRZ
There are turbo kits that can be used with any header of your liking, but they are few. The ones I can think of right now are the Works turbo and the highly recommended P-Tuning turbo kit.
As for the best N/A EL header, this gets interesting. Many regard the ACE header to be the best EL header, but because this system replaces the overpipe, that excludes the two turbo systems I just mentioned above.
<--- My Journal
People just need some #drivermod in their life.
yelsew is offline   Reply With Quote
The Following 2 Users Say Thank You to yelsew For This Useful Post:
Mr.Impreza (09-29-2016), wparsons (09-30-2016)
Old 09-29-2016, 06:53 PM   #7
Casper_FRS
Thanks again! Does the ACE header make good gains with a supercharger as well, I would consider a supercharger as well still sort of undecided, but I want to go the bolt on and tune path First to see the progression then forced induction route
Old 09-30-2016, 10:25 AM   #8
wparsons
wparsons's Avatar
Good supercharger + ACE header and a good tune will make very good power.
Ping @CSG Mike if you want more info on that combination.
flickr
The Following User Says Thank You to wparsons For This Useful Post:
Old 10-02-2016, 03:37 AM   #9
Unless... you had a custom up-pipe made... which also means you can use a twin scroll turbo....
Old 10-02-2016, 03:38 AM   #10
Well... we're 400+WHP on a Mustang dyno, with a Jackson Racing (C30 [smaller]) supercharger, 100mm pulley (stock is 110mm), E85, and Ace header...
Cole (10-04-2016), wparsons (10-02-2016)
Old 10-04-2016, 02:02 AM   #11
ndreim
ndreim's Avatar
Drives: 2014 wrb brz 6MT
P and L header looks like it could be retrofitted with a snail.. I am just speculating though, the custom turbo on that probably won't save you money.
I would honestly just go with catless long tube headers and a tune with some cam timing advance. Less headaches than FI; cooling, leaks, knocks, dilemma between forged/not-forged internals.
If you want serious power just drop a 2jz or LSx in there and skip everything fa20 related (sell your fa20).
porsche exhaust tips +10 horsepower
ndreim is offline   Reply With Quote
Old 10-04-2016, 03:20 AM   #12
kask2_6.0
kask2_6.0's Avatar
Drives: 13 BRZ
As mentioned by @yelsew the Ace header is awesome. If you are staying NA or supercharged then go with the Ace. If you see a turbo in your future ptuning makes an equal length header that works very well NA and also work with their v2 turbo system, which is the best out there for this platform.
Coming soon...
kask2_6.0 is offline   Reply With Quote
The Following 2 Users Say Thank You to kask2_6.0 For This Useful Post:
CSG Mike (10-04-2016), wparsons (10-04-2016)
Old 10-04-2016, 01:28 PM   #13
Coming soon...
Old 10-04-2016, 08:31 PM   #14
kask2_6.0
kask2_6.0's Avatar
Drives: 13 BRZ
http://www.ft86club.com/forums/showthread.php?t=99861
DIY turbo setup Amaya Forced Induction 55 07-17-2019 11:22 AM
WTB: SBD TURBO SETUP BRZ_HaVoKx Want-To-Buy Requests 5 04-08-2016 10:36 PM
FS: Entire P&L Stage 1 Turbo Setup - Turn key Setup ready to make 400+whp PrimeMotoring Engine, Exhaust, Bolt-Ons 8 10-30-2015 07:36 AM
So you think your JDM turbo setup is simple, huh? D K Forced Induction 6 07-27-2015 06:00 PM
FS: Entire P&L Stage 1 Turbo Setup - Turn key Setup ready to make 400+whp PrimeMotoring NY / NJ / CT / PA 0 10-20-2014 11:48 AM
