Drives: 2013 FRS 10 series
Alright guys, bringing up an issue im having. I read about it in an older thread but thought id ask as it didn't help too much. So i installed my turbo setup and it went good. Got an etune from shiv that he just finished up said everything looked great. Only one issue im having that he didn't address and has yet to get back on is that when im coasting along and decide i want to stop and put my clutch In my rpms will drop, stutter, and then the car goes lean and stalls out. sometimes it may catch itself but rarely. So i have to be very specific and brake to a certain point before i cant stop. I read that it is injector scaling or ol/cl fueling. Any advice on what I should scale or change would be fantastic so i can drive normal again. Thanks! p.s will provide any logs or whatever is needed if someone wants to help!!!
If the tune worked fine for a while, then later you got this problem its unlikely to be tune related.
Its most likely a intake/vacuum leak. Check all the hoses on intake are clamped including those underneath the intake manifold. Check you bov for leaks aparantly the early model bov supplied with sbd kits do leak causing the problem you have. Maybe try sealing of bov port and see if stalling problem persists. check catch cans for leaks also try posting in the sbd facebook group |
#3 | |
#4 | |
try altering the "Overrun Fueling RPM Resume Threshold " table in romraider and give the engine fuel back a little earlier (ie higher rpm) |
Alright here how it is now, just curious as to how much to change it by
#6 | |
This was just a suggestion you may also have to look at desired mass airflow or other tables However just try making small changes, Does it stall out when cold ? or only when fully warmed up ? if it only stalls out when fully warmed up just alter the purple 1525 to say 1700. you may also want to try bumping your base idle 50 rpm from maybe 700 to 750 |
#7 | |
Drives: UK GT86
Idle issues tend to be fueling related. Check fuel trims etc. You could try adjusting the idle stability control.
.: Stealth 86 :.
#9 | |
Hopefully its git decient fuel trins as its gad cystom tune.. but skso a possibility. If its got big port injectors might be worth running full DI injection to 0.3 load maybe ? If the injdctor latency is a bitt off ? |
#10 | |
#11 | |
Changing the overun fueling should not effect fuel trims, id ssy is cause the ecu gets reset when you flashed updated tune and its just fuel trims relearning. If its got stock injectors and fuel trims are good then thats good u likely to be cause. I still think it might be bov leaking slightly especially as you say it leans out and stslls in your first post if its not the new type bov raceport i think the older ones a few people has issues with slight leaks causing idle problems |
#12 |
Drives: UK GT86
Add a couple of percent to idle region of the MAF....
.: Stealth 86 :.
#13 | |
#14 | |
its likely the overrun fueling timer that adding fuel, that's "fixed" your stalling issue |
| DIY turbo setup | Amaya | Forced Induction | 55 | 07-17-2019 10:22 AM |
| Best EL setup for NA and turbo | Casper_FRS | CANADA | 14 | 04-27-2017 12:45 PM |
| WTB: SBD TURBO SETUP | BRZ_HaVoKx | Want-To-Buy Requests | 5 | 04-08-2016 09:36 PM |
| FS: Entire P&L Stage 1 Turbo Setup - Turn key Setup ready to make 400+whp | PrimeMotoring | Engine, Exhaust, Bolt-Ons | 8 | 10-30-2015 06:36 AM |
| FS: Entire P&L Stage 1 Turbo Setup - Turn key Setup ready to make 400+whp | PrimeMotoring | NY / NJ / CT / PA | 0 | 10-20-2014 10:48 AM |
