Old 05-13-2017, 10:06 PM   #15
thomasmryan
thomasmryan's Avatar
Drives: hyper blue
Look and see if you knocked the sending unit wire off while you where installing your intake.
thomasmryan is offline   Reply With Quote
The Following User Says Thank You to thomasmryan For This Useful Post:
Tcoat (05-13-2017)
Old 05-13-2017, 10:07 PM   #16
Originally Posted by SuperTom View Post
Yeah would think bugs would be worked out on these by now but since it is slightly upgraded with new HP there could be new bugs.
Still going to try to get a little oil out since ive read in other car forums too much oil can cause low pressure as well.
And will try to reset the ecu so it learns the new intake .
If these don't work I will have to suck it up and waste my day off in a dealership.
What all have you done other than the intake? If measured hot it would look high you need to follow the instructions in the manual on how to check oil. Not likely to cause a low pressure light if just a little over full.
The 15s have very little history of oil issues.
Old 05-13-2017, 10:31 PM   #17
stevesnj
stevesnj's Avatar
Do I need to link a certain Unihip thread and let people judge who is a what?
My 2016 Build thread
The Following 3 Users Say Thank You to stevesnj For This Useful Post:
Summerwolf (05-13-2017), Tcoat (05-13-2017), Ultramaroon (05-13-2017)
Old 05-13-2017, 10:40 PM   #18
alan.chalkley
Drives: 4wd zooks
It all depends if it is fixed free under warranty at the dealer , or if you like burning your own money on an engine that could soon deploy in pieces all over the road!
alan.chalkley is offline   Reply With Quote
Old 05-13-2017, 10:52 PM   #19
SuperTom
SuperTom's Avatar
Drives: C5, GT-86, '24 Colorado TrailBoss
Originally Posted by guybo View Post
Are you a complete moron? You bought the car 2 weeks ago, you get an oil light and you're doing ANYTHING EXCEPT tell the dealership to send a tow truck and haul off their problem? This is a joke right?
did you not read the light only comes on at 600 rpm and is flickering at 700 rpm. If I blip the throttle it goes away.
I will take the others advice and check to make sure something was not plugged in the morning.
SuperTom is offline   Reply With Quote
The Following User Says Thank You to SuperTom For This Useful Post:
Tcoat (05-14-2017)
Old 05-13-2017, 11:07 PM   #20
steve99
Drives: FT86
Mate the oil pressure light is just a switch it come on at extremly low , virtully nil oil pressure something like 2psi or less.
Im rearly hoping its just a faulty sender.
Ring dealer imediatly , dont drive the car.
I wouldnt let on to the dealer you have been driving it for days with that issue as they could likely use that against you if their is any serious damage.
That light should never ever come on in normal operation of the car even at idle and efen at 500 rpm let alone at 600 or 700.
The Following 5 Users Say Thank You to steve99 For This Useful Post:
Clipdat (05-14-2017), guybo (05-14-2017), Sportsguy83 (05-17-2017), Tcoat (05-14-2017), Ultramaroon (05-13-2017)
Old 05-14-2017, 09:41 AM   #21
stevesnj
stevesnj's Avatar
I'm sure such low pressure would make for a noisy valve train and maybe stumbling since the VVT needs oil to properly function? Unless our VVT is electronically adjusted? I never got into the VVT in our cars.I'm thinking it's just a sensor issue as said above.
Old 05-14-2017, 09:56 AM   #22
reeves
Unfortunately this is true. My idle fluctuates and can dip down to 400 RPM at times (once the engine has warmed up). Oil pressure drops to like 3-4 psi and the idiot oil light has never once even blinked on for me.
Old 05-14-2017, 10:34 AM   #23
SuperTom
SuperTom's Avatar
Solved!
thankfully I looked into this before overreacting and screaming at the dealership to come tow my lemon away but the error is mine.
Looks like this pinched vacuum line to the pcv valve? was most likely the culprit.
Also did what I said I was going to last night and reset the ecu. Added some dielectric grease to keep them rust free while the terminals were off.
Also check the oil levels cold and hot.
Cold
Hot after settling 10 mins after.
Took it for a spirited run. Idle is right around 650 rpms with NO LIGHT!
The Following 2 Users Say Thank You to SuperTom For This Useful Post:
Lonewolf (05-15-2017), Ultramaroon (05-14-2017)
Old 05-14-2017, 10:41 AM   #24
22R
22R
22R's Avatar
Drives: 2012 Camry SE 2017 Toyota 86
Glad you have it worked out... Nice looking Vette to BTW. Enjoy the rides
22R
22R is offline   Reply With Quote
Old 05-14-2017, 10:46 AM   #25
SuperTom
SuperTom's Avatar
22R
Thanks glad it was something simple.
offtopic -speaking of Vette. cant understand why my sig pic gets cut off at the bottom. Its the same link I use in corvetteforums and even in the previews here it shows the whole pic.
Old 05-14-2017, 02:04 PM   #26
Looks like this pinched vacuum line to the pcv valve? was most likely the culprit..........
Ah, ha ........ a self inflicted wound .......
Now, don't do that no more ......
Old 05-14-2017, 02:07 PM   #27
Cause ...... this is a FR-S / BRZ forum ....... corvettes are frowned upon .....
Old 05-14-2017, 09:05 PM   #28
humfrz (05-14-2017)
Tire pressure light VABeachBRZ Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 3 08-11-2016 04:12 PM
Low tire pressure light... Premium 615 BRZ First-Gen (2012+) — General Topics 27 01-20-2016 11:54 AM
Idle Oil Pressure Lunatic Engine, Exhaust, Transmission 3 12-16-2015 09:24 AM
Rough Idle, Cel, Skid light... Freeze2196 Issues | Warranty | Recalls / TSB 2 06-09-2015 11:58 PM
CEL, Skid Light, Rough Idle ... SherbFrs Issues | Warranty | Recalls / TSB 8 07-18-2013 06:43 PM
