Old 05-13-2017, 10:54 AM   #1
SuperTom
SuperTom's Avatar
Drives: C5, GT-86, '24 Colorado TrailBoss
'17 new 86 oil pressure light on with low idle
Just got my new '17 a few weeks ago not even broken in yet. Yesterday low oil pressure light comes on when im sitting at idle.
Idle is kinda low at 600 rpms. If I blip the the throttle the light goes away.
Checked oil hot it is actually a little over the full mark.
Guessing I should try to drain about a half a quart out first and possibly reset the computer since the low idle might be caused by a new intake pipe installed.
Otherwise no issues engine sounds and runs great.
Just checking to see if anyone else has this issue or a fix before I have my car sitting for days at a dealership.
Thanks in advance
-Tom
SuperTom is offline   Reply With Quote
Old 05-13-2017, 11:03 AM   #2
22R
22R
22R's Avatar
Drives: 2012 Camry SE 2017 Toyota 86
I would get it to the dealer and keep a record just incase. Some of the older models had some injector issues and low idle rpm's and check engine was two signs.....I am not saying this is your problem but having a 2 week old one myself it is good to read on here and be pro active just incase.
22R
22R is offline   Reply With Quote
Old 05-13-2017, 11:41 AM   #3
SuperTom
SuperTom's Avatar
22R
Yeah would think bugs would be worked out on these by now but since it is slightly upgraded with new HP there could be new bugs.
Still going to try to get a little oil out since ive read in other car forums too much oil can cause low pressure as well.
And will try to reset the ecu so it learns the new intake .
If these don't work I will have to suck it up and waste my day off in a dealership.
Old 05-13-2017, 11:47 AM   #4
guybo
Huge E85 fan!
guybo's Avatar
Drives: 2016 Scion FRS
Are you a complete moron? You bought the car 2 weeks ago, you get an oil light and you're doing ANYTHING EXCEPT tell the dealership to send a tow truck and haul off their problem? This is a joke right?
Old 05-13-2017, 12:35 PM   #5
22R
22R
22R's Avatar
Though I totally agree with your sentiment. You could state your opinion without coming off so harshly. I know if it was mine I would call dealer and if they told me to drive it in I would get it in writing or they would have to send a wrecker.....Tom may be right and it is the oil level but I wouldn't not give Toyota any leeway if the engine grenades to use against me....Just MO
But Tom you are right that you will need a day off to deal with a dealer
22R
Old 05-13-2017, 01:07 PM   #6
Lonewolf
Lonewolf's Avatar
Drives: Moped
Unnecessarily harsh right there, jeez.
Old 05-13-2017, 01:12 PM   #7
Da Brz
Drives: 2016 Subaru BRZ
These cars are hard to get a good oil reading on. I'd leave it as is and get it to the dealer.
The more you mess with it the more likely it is that they'll blame you.
Da Brz is offline   Reply With Quote
Old 05-13-2017, 05:38 PM   #8
BRZnut
Drives: BRZ DGM Limited
I doubt that having the oil level slightly above the fill line is causing the issue. Mine has been above that line in the past and never had oil light come on at idle but my idle is around 700 rpm. Also, I have read the oil light does not come on unless the pressure is really really low. I'd just get it to the dealer this week since these engines have been known to self destruct from oil starvation issues.(but call them and see if they give you the ok to drive it there)
Old 05-13-2017, 05:54 PM   #9
Ultramaroon
not playing cards
Ultramaroon's Avatar
Old 05-13-2017, 06:05 PM   #10
stevesnj
stevesnj's Avatar
I don't think you're a moron but I'd not drive it and call the dealer to have them pick it up and get a free rental until it's fixed.
My 2016 Build thread
Old 05-13-2017, 09:19 PM   #11
guybo
Huge E85 fan!
guybo's Avatar
Lol everyone gets their panties in a wad
Old 05-13-2017, 09:29 PM   #12
Ultramaroon
not playing cards
you yelled.
Old 05-13-2017, 09:56 PM   #13
humfrz
No ....... you first gave a wedgie ........
humfrz
Old 05-13-2017, 10:03 PM   #14
Do I need to link a certain Unihip thread and let people judge who is a what?
Tire pressure light VABeachBRZ Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 3 08-11-2016 04:12 PM
Low tire pressure light... Premium 615 BRZ First-Gen (2012+) — General Topics 27 01-20-2016 11:54 AM
Idle Oil Pressure Lunatic Engine, Exhaust, Transmission 3 12-16-2015 09:24 AM
Rough Idle, Cel, Skid light... Freeze2196 Issues | Warranty | Recalls / TSB 2 06-09-2015 11:58 PM
CEL, Skid Light, Rough Idle ... SherbFrs Issues | Warranty | Recalls / TSB 8 07-18-2013 06:43 PM
