Old 06-26-2013, 08:49 PM   #1
SherbFrs
CEL, Skid Light, Rough Idle ...
I'm here again ... with a problem whit my Scion FRS
I'ts been almost a month since my CEL and the dealer is not able to fix it. They change the ECU, intake gasket was leaking so they change it. Made couple of test and know they told me that a ABS sensor was faulty. I told to check the rough idle but didn't bother too much. Every week i got to the dealer with the car and no improvement. So anyone got some idea ? Tomorow i gonna call toyota canada again to complaint about the poor service of the Tech and i will change dealer.
SherbFrs is offline   Reply With Quote
Old 06-26-2013, 08:55 PM   #2
whitefrs
Love Boost!!!!!!!!
whitefrs's Avatar
Drives: Whiteout Scion FR-S
any cel codes?
i have rough idle at start up.
Old 06-26-2013, 08:56 PM   #3
topazsparrow
Drives: slow
Any way to pull the codes? You can get 10 dollar bluetooth odbII adapters on ebay (I bought two!). There's a free android app called Torque you can use to read the codes on.
I've read in the past that the CEL + slip light combo points towards a crank sensor. They're a fairly common failure point on these cars from what I've read. There's a TSB or two on it as well.
topazsparrow is offline   Reply With Quote
Old 06-26-2013, 09:10 PM   #4
SherbFrs
15 may 2013
#VIN 7032XX
P0171, P117B Sensor short-circuit so they change the Mass Air Flow Sensor
SU003-00425 ... And guess what ... nothing happen.
Since then i don't have the other code.
Old 06-26-2013, 09:30 PM   #5
whitefrs
Love Boost!!!!!!!!
whitefrs's Avatar
15 may 2013
#VIN 7032XX
Wait
I had that code
And it was my spark plugs and DI seals
Old 06-26-2013, 09:40 PM   #6
whitefrs
Love Boost!!!!!!!!
whitefrs's Avatar
Old 06-26-2013, 09:49 PM   #7
SherbFrs
DI seals as been change in december 2012. check my older thread
http://www.ft86club.com/forums/showthread.php?t=23810
i think i was in the first that this problem occur back in november 2012.
they spend 1 month to fix this issue.
I gonna check the spark plugs tomorow. Did you got some backfire when your DI seals was burn ?
Old 06-26-2013, 09:59 PM   #8
whitefrs
Love Boost!!!!!!!!
whitefrs's Avatar
nop just car was shaking like a MOFO but no misfires codes just the codes you are showin now
Old 07-18-2013, 06:43 PM   #9
SherbFrs
check my new post for progess
http://www.ft86club.com/forums/showt...62#post1079962
ECU replaced. Still has slight misfire, rough idle xomp Issues | Warranty | Recalls / TSB 1 11-01-2012 08:53 AM
Response from Scion about rough idle problem ichitaka05 Scion FR-S / Toyota 86 GT86 General Forum 10 10-09-2012 10:41 PM
Looks like CEL/Rough Idle is getting a lot more attention. wawro569 Scion FR-S / Toyota 86 GT86 General Forum 11 10-06-2012 12:24 AM
Rough Idle & CEL *video JiB Issues | Warranty | Recalls / TSB 5 10-04-2012 10:28 PM
CEL and Rough Idle Issue Autonews.com article Yruyur Issues | Warranty | Recalls / TSB 11 10-04-2012 03:34 PM
