Old 12-16-2015, 08:24 AM   #1
Lunatic
Lunatic's Avatar
Drives: 2015 Raven FRS
Idle Oil Pressure
For people that have added a oil pressure gauge, what oil pressure are you seeing at idle with a hot engine?
Lunatic is offline   Reply With Quote
Old 12-16-2015, 08:28 AM   #2
malave7567
malave7567's Avatar
Drives: (formerly) 2013 Raven FR-S
I had my pressure gauge sensor set-up on a sandwich plate under the oil filter. At idle, completely warmed up, I would usually be at about 19-20 psi.
malave7567 is offline   Reply With Quote
Old 12-16-2015, 09:17 AM   #3
stevesnj
stevesnj's Avatar
Oil pressure range from the Service manual
My 2016 Build thread
The Following User Says Thank You to stevesnj For This Useful Post:
hmong337 (12-16-2015)
Old 12-16-2015, 09:24 AM   #4
Lunatic
Lunatic's Avatar
Thank you.
The Following User Says Thank You to Lunatic For This Useful Post:
stevesnj (12-16-2015)
Idle dip yomny Software Tuning 38 06-14-2016 05:54 PM
best tire pressure gauge (tire pressure question) steveholt Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 19 03-21-2015 10:27 PM
What do you consider low oil pressure? protpibe Engine, Exhaust, Transmission 10 01-14-2014 10:19 PM
Stock clutch+flywheel+pressure plate+ ACT lightweight flywheel & pressure plate PineappleFriedRice Transmission and Driveline 0 11-08-2013 04:54 PM
Oil Pressure.. too low? Dave-ROR Tracking / Autocross / HPDE / Drifting 65 08-24-2013 12:43 AM
