Old 03-10-2017, 11:58 AM   #15
finch1750
Undisputed El Presidente
finch1750's Avatar
Drives: Zenki 37J ZN6
What shop are you going to?
I would check with Elite or The Racers Line for a 2nd opinion as they probably have the most experiance with track set-ups including the CRs for the twins in Norcal
Old 03-10-2017, 12:51 PM   #16
ls1ac
ls1ac's Avatar
I have several sets of partially used pads from track days that have worn at different rates, I use a belt sander to remove surface contamination from the best and use them.
You could try pulling them, check for abnormal wear and clean them up and try again.
The Following User Says Thank You to ls1ac For This Useful Post:
FR-Sky (03-11-2017)
Old 03-11-2017, 04:59 AM   #17
FR-Sky
FR-Sky's Avatar
Drives: 2013 FR-S 10 series [755]
I went to elite performance. Eric drove my car and said he changed about 5 set of CR and never had this problem before.
FR-Sky is offline   Reply With Quote
Old 03-11-2017, 05:02 AM   #18
finch1750
finch1750's Avatar
Hmm. Elite knows what they are doing when it comes to track parts. Interesting reasoning but he does have a lot of knowledge.
@CSG Mike do you have any input just based on description of the sound or the reason provided?
Old 03-11-2017, 05:02 AM   #19
FR-Sky
FR-Sky's Avatar
Thats what I am trying to do right now. Thanks for advice!
Old 03-11-2017, 05:07 AM   #20
FR-Sky
FR-Sky's Avatar
Yea..He said nothing I cant do at this point except using it until the degrading surface is gone. Go track and hard braking for a lap or two or find a empty area to hard brake many times until the sound is gone. =/
Old 03-11-2017, 11:43 AM   #21
finch1750
finch1750's Avatar
Ahhh, I get what they are telling you now. Just the wording was a bit confusing. Brakes like that dont stay bedded for long off the track due to the temps being too low as a DD. You could swap back to OEM til track day or just make a couple hard stops a day to try and keep a transfer layer on the rotors to help control the noise. Or just get used to the noise #bcuzracecar
FR-Sky (03-11-2017)
Old 03-11-2017, 01:54 PM   #22
CSG Mike
CSG Mike's Avatar
Hi, recently I changed my brake pad (Project Mu CR) and braking bleed for about 3 weeks ago.
There is a water/gurgling mix with brake friction grinding sound when braking at low speed(around 0-15mph) ,and seems like the brake not as bit as it used to.
I haven't done any bedding, I just drive normally, and possibly couple hard brake during the past 3 weeks.
What is the problem here? Improper bedding? I checked my brake fluid and the level is okay.
Thanks
Try fresh rotors.
Old 03-11-2017, 04:46 PM   #23
wparsons
wparsons's Avatar
For the question about them not having as much bite as your previous pads, when CR's are cold they have a pretty low coefficient of friction, comparable to OEM pads at best. Get them even a little warm and it goes WAY up though, they're like glue compared to OEM once warm.
flickr
FR-Sky (03-12-2017)
Old 03-12-2017, 05:58 AM   #24
FR-Sky
FR-Sky's Avatar
Yea, i figure that out after doing a another bed in.
the car almost stop when i tab the brake pad like 30% while doing 40-60mph
I hear a rattling sound when braking in neutral with A/C on. Is this normal ? awhatzable Scion FR-S / Toyota 86 GT86 General Forum 4 05-21-2015 09:25 PM
Braking Noise hasfoot Issues | Warranty | Recalls / TSB 12 04-25-2015 12:02 AM
Terrible sound under braking... help? PoWn3d_0704 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 12 03-07-2014 10:53 PM
More sounds; metal whirring sound braking to stop in neutral l0aded Issues | Warranty | Recalls / TSB 2 07-13-2013 02:05 AM
Engine Braking Wattage Scion FR-S / Toyota 86 GT86 General Forum 75 01-16-2013 02:51 PM
