Drives: 2013 fr-s
Braking Noise
When the brake pedal is pressed a quarter of the way down there is a creaking sound. It sounds a little bit like an old mattress spring or flute depending on the speed.
The creaking sound occurs between 5-50 MPH. There is no noise when I press firmly on the brakes. The noise seems to come from the front left side of the car. The pitch and frequency of the creaking increases with speed. The creaking is loudest and sounds most stretched out at around 20 MPH. There is no special noise that occurs when I accelerate, turn, go in reverse, or brake at speeds higher than ~50 mph. Any ideas on what it could be?
Well I would assume that the screech has nothing to do with replaced components, but solely on your brakes. Nothing major, have them checked out.
Drives: 2005 Toyota Camry
If the hubs were replaced, it could be the front brake dust shield, or the retaining clips/hardware for the front pads.
-alex |
Drives: BR86
Pad impurities ? Dry caliper sliding pins ? Inspect brakes, although some cars are notorious for noisy brakes if lightly applied such as my old zzt231R celica. My 86 doesn't make any such brake noise though :/
Drives: 2013 fr-s
Yea it is a new noise and should not exist. Thanks for the tips. I will update when I find the source of the noise.
Drives: 2013 fr-s
I got it checked out at the dealer, they told me that the left wheel bearing is loose and grinding which makes the noise. I don't see how it could be the bearing when it only makes noise when I brake lightly.
Since the noise is not constant at any driving speed and doesn't come around when I turn do you think it could still be the bearing? I would appreciate any second opinions. |
#7 | |
Drives: SWP BRZ
if you were under warranty, let them fix it. i personally don't think its wheel bearing. could be brake pads, shims, etc related to brake hardwares. |
Drives: 2013 fr-s
I think I will go to another shop to get a second opinion because I agree with you that it is a brake hardware issue.
#9 | |
GBS Mafia Member
Drives: with Snow mode on
Anyone have additional thoughts? It'd be gladly appreciated!
![]() GBS Mafia |
#10 | |
( ͡° ͜ʖ ͡°)
Drives: '13 Whiteout FR-S A/T
We'll see when I get the wheels off and inspect the brake hardware. |
#11 | |
GBS Mafia Member
![]() GBS Mafia |
#12 |
( ͡° ͜ʖ ͡°)
#13 |
Drives: 13 FRS Satin
If it's the squeal I'm thinking of and your brakes are not new, do this:
Drive it fast and do a few really hard brake stops. Mine squealed during the winter months because of dirt, salt and cold. |
| LEDs dim/turn off when braking ? | Matt90 | Cosmetic Modification (Interior/Exterior/Lighting) | 26 | 08-10-2013 06:18 PM |
| Rattling noise under the hood during engine braking at low RPM | Sigh-on-Rice | Engine, Exhaust, Transmission | 60 | 07-28-2013 07:48 AM |
| Experience on braking.. | tintumz22 | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 3 | 04-29-2013 09:57 PM |
| Engine Braking | Wattage | Scion FR-S / Toyota 86 GT86 General Forum | 75 | 01-16-2013 02:51 PM |
