Old 07-08-2013, 04:44 PM   #1
l0aded
Addicted
l0aded's Avatar
Drives: 2013 Asphalt FR-S 6MT
More sounds; metal whirring sound braking to stop in neutral
I have read in multiple areas that keeping the clutch engaged is bad as it lowers the life of the throwout bearing. So as a result I try to keep my car in gear until when coming to a stop and putting it in neutral just before the car stops (to save my brakes as well). I have been hearing a sound intermittently/occasionally when braking to a stop in neutral I would guess around 10mph just before coming to a full stop.. It sounds like something is free spinning and making more noise than it should and lasts about 1-2 seconds before going away. Anyone else experience this? Is it a problem or another one of our transmissions lovely features?
It's hard to get a sound cap as it happens every so often (enough to be worriesome though).
l0aded is offline   Reply With Quote
Old 07-10-2013, 12:29 AM   #2
Iamthebatman
Drives: Black Subaru BRZ
When the noise happens, watch your tachometer. Most likely your revs are dropping by a couple hundred right as the noise occurs. This is an engine idle issue, it for some reason only happens when slowing down in neutral. A few owners have reported this issue to their dealer and gotten their ECU reflashed, sometimes it helps sometimes not. Good luck!
Iamthebatman is offline   Reply With Quote
Old 07-13-2013, 02:05 AM   #3
l0aded
Addicted
l0aded's Avatar
Thanks for this. Does anyone have any more info regarding the ECU reflash? Is it the same one from back in October of last year (that newer models should have now?).
Clanking metal sound from rear!!!! 808Raven Issues | Warranty | Recalls / TSB 7 09-21-2017 10:09 AM
whining/whirring noise during high load/rpm clutch engagement 7thgear Issues | Warranty | Recalls / TSB 105 06-19-2017 11:04 AM
At stop lights, do you stay in gear or go into neutral? boredom.is.me Scion FR-S / Toyota 86 GT86 General Forum 77 07-25-2014 09:23 PM
Neutral to 1st clunking sound wallace03 Issues | Warranty | Recalls / TSB 3 01-10-2013 09:50 PM
Car rattle at neutral. IloveBaldEagles Issues | Warranty | Recalls / TSB 3 12-23-2012 06:55 PM
