Old 03-09-2017, 01:13 AM   #1
FR-Sky
FR-Sky's Avatar
Drives: 2013 FR-S 10 series [755]
Water/gurgling sound when braking?
Hi, recently I changed my brake pad (Project Mu CR) and braking bleed for about 3 weeks ago.
There is a water/gurgling mix with brake friction grinding sound when braking at low speed(around 0-15mph) ,and seems like the brake not as bit as it used to.
I haven't done any bedding, I just drive normally, and possibly couple hard brake during the past 3 weeks.
What is the problem here? Improper bedding? I checked my brake fluid and the level is okay.
Thanks
FR-Sky is offline   Reply With Quote
Old 03-09-2017, 03:04 AM   #2
FirstWinter
Drives: Car
You have a video of the noise or a better description? Where's the sound coming from?
FirstWinter is offline   Reply With Quote
Old 03-09-2017, 03:17 AM   #3
FR-Sky
FR-Sky's Avatar
Its coming from driver side when braking at low speed, I can hear the friction on the rotor and some kinda water running sound.
Old 03-09-2017, 03:28 AM   #4
Jajanken86
Jajanken86's Avatar
Drives: Silver FR-S
Gurgling kinda describes the sound my brakes make when I set off in the morning and the rust gets scratched off the rotors
Sent from my iDroid
Jajanken86 is offline   Reply With Quote
Old 03-09-2017, 03:37 AM   #5
FR-Sky
FR-Sky's Avatar
Sent from my iDroid
Lol, I wish it is just morning dust,, but it happens everytime i brake at low speed.
Old 03-09-2017, 04:21 AM   #6
Mr.ac
[insert cool phrase here]
Mr.ac's Avatar
Drives: BRZ Premium
Bleed it again.
It could be possible you didn't close the bleeder valve all the way close, and might have some air trapped in the lines.
Old 03-09-2017, 11:16 AM   #7
renfield90
The Stig's German cousin
We're gonna need video. But my bet is your brakes just sound funny.
Check your coolant level. If there is actual water gurgling it's probably from there.
Old 03-09-2017, 11:26 AM   #8
Check to make sure both pads on the wheel are properly in place and not loose.
Old 03-09-2017, 12:37 PM   #9
finch1750
Undisputed El Presidente
finch1750's Avatar
Drives: Zenki 37J ZN6
Race pads make terrible sounds at low speed when cold. And cold for them can easily happen driving normally since they have higher operating ranges then other pads.
But a vid would help us guess more accurately
Old 03-09-2017, 01:25 PM   #10
FR-Sky
FR-Sky's Avatar
Thanks guys, taking back to the shop today and will update.
The Following User Says Thank You to FR-Sky For This Useful Post:
Tcoat (03-09-2017)
Old 03-10-2017, 03:06 AM   #11
FR-Sky
FR-Sky's Avatar
ok guys.....here is the update....
According to the mechanic, everything was fine...the bleed, rotor, except...
so the issue was...the surface of the brake pad's compound is degrading due to the item is storing too long...that's why the compound on top of the brake pad surface is very hard to bed in which causing the gurgling sound. Also, the mechanic said he had used 5 set of this brake pad and never have this problem. (We didn't buy at the same vendor).
Old 03-10-2017, 08:53 AM   #12
dem00n
Member of the year - 2016
dem00n's Avatar
Drives: Scion FRS
The part of the brake pad compound degrading due to storage sounds like BS, but everything else sounds right.
I have the Winmax W4 and if you list closely with slow braking, you'll get that gurgling sound.
Old 03-10-2017, 09:26 AM   #13
Yes it is BS. If you are buying brake pads that degrade from sitting on a shelf then you need to get them off your car right this second.
Old 03-10-2017, 11:30 AM   #14
renfield90
Lol. NEVER go to this mechanic again - you can't put a price on trust, especially when it comes to your car. Brake pad compounds don't degrade from storing too long. The Project Mu CR is a mix of graphite and various metals, tell me how that's going to degrade or make it hard to bed in if it sits in a box?
He BS'd you because he's not going to make any more money from you on this job, and wants you to go away. How are you going to feel if he actually screws something up, you come back to him to get it fixed and he does the same trick to get you out the door?
Aggressive pads are known for not only sounding funny, but changing their sound through their life depending on the state of the transfer film on the rotors (among other things). I bet if you give them a good hard bedding in they will sound different.
My friend always tells me my pads sound like a spaceship. At this point I've tuned the noise out (or I'm losing my hearing) because I don't notice, it's part of the compromise of running a more aggressive pad.
The Following User Says Thank You to renfield90 For This Useful Post:
strat61caster (03-10-2017)
I hear a rattling sound when braking in neutral with A/C on. Is this normal ? awhatzable Scion FR-S / Toyota 86 GT86 General Forum 4 05-21-2015 09:25 PM
Braking Noise hasfoot Issues | Warranty | Recalls / TSB 12 04-25-2015 12:02 AM
Terrible sound under braking... help? PoWn3d_0704 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 12 03-07-2014 10:53 PM
More sounds; metal whirring sound braking to stop in neutral l0aded Issues | Warranty | Recalls / TSB 2 07-13-2013 02:05 AM
Engine Braking Wattage Scion FR-S / Toyota 86 GT86 General Forum 75 01-16-2013 02:51 PM
