Old 11-18-2016, 12:53 PM   #29
stevo585
Drives: White 2014 BRZ
Originally Posted by Xxyion View Post
This is VERY encouraging. I've been really thinking about boosting my car but my biggest thing holding me back was the reliability. I always kept hearing that if you boost your car you are basically dooming it to only live 20k miles or so. But i think with the fact that almost all cars come with some sort of turbo OEM, reliability has gone way way up as more and more companies are figuring out how to build kits that can last a long time.
Those oem turbo cars are designed generally for the turbo. Although not sure about the FA20DIT in the wrx. Is it mechanically any different than just lower compression?
JDL Turbo kit - Ecutek, HRI tuned.
stevo585 is offline   Reply With Quote
Old 11-18-2016, 11:21 PM   #30
Kiske
Kiske's Avatar
Drives: RX-7 / BRZ
FA20DIT doesn't have port injectors which is a huge advantage for our cars. Makes upgrading super easy and relatively cheap also helps us prevent the carbon build up. The FA20DIT also has lower compression, hypereutectic (not forged) pistons. If I'm not mistaken, the DIT also has a better oil pump.
The one thing every one of these threads bringing up reliability misses on.
More power = less reliable.
More heat = less reliable.
More abused = less reliable.
It's going to be case to case basis. There are people with 450+ still on a stock block and people with 300hp that have windowed there block.
Old 11-19-2016, 01:14 AM   #31
CSG Mike
CSG Mike's Avatar
My FA20DIT, on stock injectors, and stock fuel pump, makes more power than the majority of boosted twins. I'm not seeing the advantage here.
Injection capacity is not a limiting factor on the FA20DIT at this point in time.
Old 11-19-2016, 08:52 AM   #32
AJPG
Drives: 22RE, FA20, 4G63
Perhaps you have a dyno for that?
AJPG is offline   Reply With Quote
Old 11-19-2016, 10:31 AM   #33
Kiske
Kiske's Avatar
Drives: RX-7 / BRZ
I'd hope so, given most of the boosted twins are sub-300whp. lol
Interesting, I haven't followed the new motor in a while I guess. When I had on NASIOC's forums, an issue with maxing out the injectors around 500whp on stock injectors was brought up often. Is this no longer the case Mike?
Old 11-19-2016, 05:12 PM   #34
Matt@Cosworth
Drives: blue - Cosworth SC stage 3.0
Gdi fuel systems as a whole typically are good for about 350Bhp with a single pump
you can run a bit leaner and push this up to 370 with hotter exhausts etc
but the limiting factor is the pump pressure usually
now there are 500Bar Gdi pumps available through bosch msport but often the fuel pump cam profile will need changing to get these to work so not just a bolt on
Matt@Cosworth is offline   Reply With Quote
Old 11-20-2016, 01:34 PM   #35
CSG Mike
CSG Mike's Avatar
I don't have anything on me (I'm at the track), but I went from a 198whp (268 crank) baseline to 292whp (395 hp crank, extrapolated). Torque went from 221lb/ft at the wheels to 309lb/ft at the wheels.
Subaru claims 258 torque from the factory, which is really, really underrated.
I'm nearing the limits of the stock fuel pump, but not injectors.
Old 11-20-2016, 02:02 PM   #36
AJPG
Hope you enjoy your Sunday! I'm also at the track, but today I'm the engine and the driver.
The Following User Says Thank You to AJPG For This Useful Post:
CSG Mike (11-20-2016)
Old 11-20-2016, 08:07 PM   #37
stevo585
So that's stock turbo? Is the bottom end stronger in the DIT?
Old 11-20-2016, 08:46 PM   #38
CSG Mike
CSG Mike's Avatar
Yes.
There's room for more power if I get more supporting mods.
Old 11-23-2016, 09:27 AM   #39
ajc209
Drives: GT86 Cosworth
Yes.
Originally Posted by moto-mike View Post
This is what the rods look like:
The WRX has a slightly different small end, which is not where they break anyway. The middle is pretty much identical and where these rods always fail.
Are you sure?
ajc209 is offline   Reply With Quote
Old 11-23-2016, 12:04 PM   #40
CSG Mike
CSG Mike's Avatar
Originally Posted by ajc209 View Post
Are you sure?
Yes.
Old 11-23-2016, 01:01 PM   #41
Colin86
Drives: 86
Originally Posted by Cal3000 View Post
Tomei UEL Headers
Invidia Front Pipe
N1 Exhaust
deatschwerks 700cc Injectors
deatschwerks 265lph FP
Moto East Zeitronix Flex Fuel Kit
Stock clutch?
Colin86 is offline   Reply With Quote
100k BlaineWasHere Scion FR-S / Toyota 86 GT86 General Forum 59 06-29-2015 01:22 AM
(Final update 1/17) 300 miles and something's not right... Stewie BRZ First-Gen (2012+) — General Topics 45 05-27-2015 06:35 AM
Boosted for 50,000 miles update Cal3000 Forced Induction 22 11-12-2014 10:42 PM
2000 honda civic si 33k miles on body 3k miles with turbo kit Anthony7515 Cars for Sale/Trade 3 07-28-2014 09:10 AM
100k annual Toyobaru production announced! Sport-Tech Scion FR-S / Toyota 86 GT86 General Forum 0 03-19-2012 12:53 PM
