Old 11-11-2014, 11:26 AM   #1
Cal3000
Drives: Panda FR-S
Boosted for 50,000 miles update
I've been boosted for 50k miles and have over 70k miles total on my car. I'm always thinking of the long term effect boost has on our cars. I haven't been to any track days but I do drive the car hard everyday. It's my DD and only car. I have the bare minimum for my car in regards to safety. No catch can/oil cooler etc.
I'm running the Vortech kit with a flex fuel unit. 9 psi max of boost.
My tune transition were:
Visconti tune for ~500 miles= crap. Probably ~210whp(dynojet)
FA20club for ~10,000 miles=better but still junk. ~230whp(dynojet)
Evasive Motorsport Dyno Tune~25,000 miles. 240whp(mustang dyno) ~260whp(dynoject)
Delicious Tuning with Flex Fuel(the best)~15,000 miles. 242whp(thier mustang)~274whp(dynojet) on 91oct. 284whp(mustang)~321whp(dynojet)
One thing everyone worries about is pinging. My car continuously pings under normal driving conditions, even with full e85, which is probably normal. It never pings under WOT, which it shouldn't. Everyone says pinging causes a slow death, if so, my pistons and cylinder walls are approaching their demise soon.
However, so far the car is holding up well. Still runs as smooth as I had it on day 1.
Anyone else with high mileage?
Vortech SC on 9psi Pulley, Invidia Catless Front Pipe, Invidia N1 Catback Exhaust
242whp/197ft-lb on Mustang Dyno (91 octane water)
284whp/223ft-lb on Mustang Dyno (E85)
Cal3000 is offline   Reply With Quote
Old 11-11-2014, 12:34 PM   #2
sirsol66
Drives: 2013 FRS- Hot Lava
That's honestly very impressive, thank you for sharing!
sirsol66 is offline   Reply With Quote
Old 11-11-2014, 03:27 PM   #3
Pbrown
Drives: 2013 Scion FRS Raven
Thank you
My driving patterns are very similar to yours, I'll be going Vortech soon and this just seals the deal. This is a very useful post. I think I'll be getting the oil cooler just to be a little safer.
Pbrown is offline   Reply With Quote
Old 11-11-2014, 04:02 PM   #4
Why are you knocking under closed loop operation?
Old 11-11-2014, 04:20 PM   #5
woode
Boosted Member
woode's Avatar
Drives: 2013 Subaru BRZ
Send a message via MSN to woode
Just to be clear.. pinging as in knock? Are you sure it's not just the direct injection you are hearing?
2013 Subaru BRZ LTD 6MT DGM
2014 Subaru XV Crosstrek Hybrid TRG PG
2011 Honda CBR1000RR
2010 Subaru Impreza WRX PRM SSM
woode is offline   Reply With Quote
Old 11-11-2014, 05:14 PM   #6
DJCarbine
Thupercharged
DJCarbine's Avatar
I thought my ~25K with the vortech kit and small pulley was impressive, aside from changing belts till I found a good size/brand before vortech released the official belt size guide I've had no problems as well even daily driving in sub 25* weather during winter.
I don't get any knocking during closed loop operation, although the injectors and header tick away like nobodies business
2013 FRS
Vortech V3 11psi
Old 11-11-2014, 08:16 PM   #7
Boofneenee
Go-Kart Enthusiast
Boofneenee's Avatar
Drives: Toyota Scion FRS
Originally Posted by VitViper View Post
If you're hearing noise with full E85... you're hearing just that, noise. It's not pinging. I've intentionally run my cars way way past MBT on E85 just for testing purposes (didn't even break anything) and there was never any detonation. Simply put, the knock limit of E85 is so high up there (especially on a DI platform) that you'll throw a rod before you detonate (IE: it's not pinging).
What is MBT?”
FRS
Current mods: K&N air filter, OFT, OFH, berk high flow cat front pipe, Q300 exhaust, lighter wheels
Boofneenee is offline   Reply With Quote
Old 11-11-2014, 08:26 PM   #8
woode
Boosted Member
woode's Avatar
Originally Posted by Boofneenee View Post
What is MBT?”
Maximum Brake Torque or Minimum Best Timing
(one in the same)
Old 11-11-2014, 11:49 PM   #9
Khánh
Khánh's Avatar
Drives: sc00ter
can anyway you post lal of your dyno graphs here for comparison? thanks
Khánh is offline   Reply With Quote
Old 11-12-2014, 12:35 AM   #10
Cal3000
Drives: Panda FR-S
The car has been knocking forever. From factory tune until now. I thought it was normal. Maybe the sensor is sensitive.
Old 11-12-2014, 10:14 AM   #11
Cal3000
Drives: Panda FR-S
So you're just referring to the knock feedback you're seeing this ECU pull? I've been watching what the knock sensor likes to do and it is very sensitive. If you're seeing it pull timing during situations like heavy tip in and such and you're on E85, it's 100% noise.
Hell I had my knock sensor on another vehicle explode with knock counts simply because I had a loose transmission bolt and the washer would jangle like crazy at 3k rpm under cruise.
It happens... seen crazier stuff.
Yeah. It could be just noise. Funny thing is it happens at the most random moments while cruising. I get values up to -4.0 to -5.0 at times. Could be the spark plugs wearing out or getting fouled. I haven't switch them as yet.
Old 11-12-2014, 12:14 PM   #12
Reaper
in orbe terrum non visi
Reaper's Avatar
Drives: violent
Nice update.
Old 11-12-2014, 01:30 PM   #13
sw20kosh
Drives: 2013 Black FR-S
@ 57k total miles now.
Been FI for more than 40k miles.
Have done 12 or so hard track days as FI (some in 100+ deg heat) and 7 or so track days before that as NA . Still going strong (crossing my fingers).
Only thing that has broke:
1. drivers side inner CV joint bearing (apparently common on this platform and not necessarily related to FI)
2. Coil Pack for cylinder 1 threw a code at last event (apparently common on this platform too NA and FI alike)
3. Stock shocks are starting to get worn out from all the tracking
4. Pre-turbo exhaust piping has melted/cracked open passenger side steering rack boot which is just an annoyance. Happened at ~55k miles. Replaced.
5. Pre-turbo exhaust piping has melted passenger sway bar bushing. Replaced.
Not bad I would say?
@mkivsoopra @RehabJeff86 @CSG Mike
Old 11-12-2014, 01:32 PM   #14
RehabJeff86
RehabJeff86's Avatar
Drives: 2013 WhiteOut FR-S
Not bad not bad!! Very impressed with PTuning FI set up!!
Sent from my iPhone using TapatalkfQ
2013 Scion FR-S whiteout
2012 Porsche Panamera S carbon grey
2008 Range Rover Sport SS black - sold
2004 BMW M3 alpine wies - sold
RehabJeff86 is offline   Reply With Quote
Boosted's BRZ Boosted Member's Car Journals 41 11-05-2018 09:32 PM
FS: Boosted 14' FR-S Low Miles Kuros Cars for Sale/Trade 57 04-13-2015 02:07 PM
My Boosted BRZ protpibe Member's Car Journals 84 09-22-2014 03:26 PM
2000 honda civic si 33k miles on body 3k miles with turbo kit Anthony7515 Cars for Sale/Trade 3 07-28-2014 09:10 AM
Boosted BRZ mike the snake Member's Car Journals 3 12-28-2013 11:11 AM
