Old 01-06-2015, 11:56 PM   #1
Stewie
Stewie's Avatar
Drives: '15 - WRB Brz Limited
(Final update 1/17) 300 miles and something's not right...
I picked up a 2015 BRZ limited on 12/31/14. I have just over 300 miles on the car and something doesn't feel right. I noticed it starting this weekend and it felt very prevalent just now on the drive home.
Between 2600 -3100 rpm (+-) it feels like there is a shudder coming from the rear passenger side tire and sometimes an odd vibration from the front passenger side that doesn't appear to be rpm related. I can replicate the rear vibration but not the front.
Has anyone experienced this? I tried searching but couldn't come up with anything. I've already checked the tire pressures and checked to make sure that the lug nuts are tight.
I have an appointment with the dealer tomorrow morning but the whole thing kinda has me bummed. Any possible insight you guys could provide would be appreciated.
Thx
Stewie is offline   Reply With Quote
Old 01-06-2015, 11:58 PM   #2
Stewie
Stewie's Avatar
Just wanted to add that I haven't hit anything, modded anything, or revved the car past 4000 rpm.
Old 01-07-2015, 12:18 AM   #3
MGPAX
Still 17!
MGPAX's Avatar
Drives: 2014 Silver BRZ Limited
I have had the tires get flat spots overnite and vibrate the next day for a bit when they are cold. Also if it's on the same side of the car, may have picked up something off the road maybe?
I know you said it didn't feel like rpm related on the front, but this car transfers vibes, sounds etc very easily.
Hope you find it and it's an easy fix.
PAX
MGPAX is offline   Reply With Quote
Old 01-07-2015, 12:32 AM   #4
Stewie
Stewie's Avatar
PAX
Thanks pax. I hope it's something simple as well.
Anyone else have something similar happen to them?
Old 01-07-2015, 12:40 AM   #5
Ganthrithor
Ganthrithor's Avatar
Drives: '13 BRZ, '06 997, Other Things(TM)
Is it happening at that engine RPM in every gear, or is it speed-related? My first guess would be that the shuddering wheel is just out of balance. I've had that happen on cars before (in my case because of snow / ice accumulation on the wheel, but it's possible someone just screwed up the weights and yours was never balanced correctly). At any rate, that's certainly an easy thing to check-- just have the dealer pull the wheel off and throw it on their machine. It should only take a couple of minutes.
Ganthrithor is offline   Reply With Quote
Old 01-07-2015, 06:30 AM   #6
Stewie
Stewie's Avatar
I'm hoping it's something simple. The thing that's worrying is that it felt like it was getting worse last night. The vibration/shudder felt more prominent.
Old 01-07-2015, 01:30 PM   #7
Lonewolf
Lonewolf's Avatar
Drives: Moped
As others have said, one or more of the tires may have picked something up. If you are not at the dealer yet, turn the wheels side to side and try to examine the tread of the tires as much as you can.
I had something similar to what you were describing happen once to me and there was a fat screw head protruding almost a quarter of an inch above the tread of the tire, but I had not lost any pressure in that tire.
Hoping for something small...
Old 01-07-2015, 03:18 PM   #8
Wilsonk227
Wilsonk227's Avatar
Drives: Super Vehicular Terrain Vehicle
I'm not sure if this is the same as yours but I've noticed whenever I started from a stop and slowly depress the gas. I'd feel a vibration coming from the rear wheels. I'm not sure if the wheels are slipping or if there's other stuff but I don't rev hard too. It does it at like 1500 rpm. This is slow start too so I have no idea.
Maybe it might be something similar? If anyone has any idea of this please let me know too. I'm thinking the rear tires are just slipping?
ig: @MrWiils0n
Wilsonk227 is offline   Reply With Quote
Old 01-07-2015, 03:35 PM   #9
paiceyfan
paiceyfan's Avatar
Drives: 2014 Porsche Cayman S
I agree with the comments on ice and flat spotting due to parking the car for an extended period in very cold temperatures....I lived in New York for eight years and had this issue.
Now on the west coast, I have had something similar happen, not long after receiving the car. In this case, it was gravel from the workplace parking lot causing imbalance in the wheels.
Having the balance checked should cure it, assuming it is not something more extreme.
It's not speed or the attention that matters, it is that unexplainable moment when man and machine become one! At that time, nothing else exists except the path before you.
paiceyfan is offline   Reply With Quote
Old 01-07-2015, 05:57 PM   #10
Pkush
Vibration from rear wheels is something I feel on cold starts. I think it's something with the differential. Seems normal operation to me
Pkush is offline   Reply With Quote
Old 01-07-2015, 06:11 PM   #11
JB86'd
JB86'd's Avatar
Drives: JAWS
I have 11k miles on my car, and I felt this the other night for the first time, when my car sat in the cold for a few hours (it was around 37 degrees, Socal never gets this cold). I even got out and checked if I had a flat tire because it felt so strange. I'm convinced it was either the tires being cold with a flat spot or as Pkush said, the diff being cold. It's since warmed up and haven't noticed it.
Old 01-07-2015, 06:12 PM   #12
Pkush
Yeah it's 0 degrees right now. I feel it every day lol.
Old 01-08-2015, 02:22 AM   #13
Stewie
Stewie's Avatar
I've noticed that too. Whenever i let off the clutch gently and only apply the minimal amount of power via the gas pedal...there's a strange sound coming from what I imagine to be the tranny/flywheel area that can be heard until about 2200-2300 rpm. Does that match what you've experienced?
Old 01-08-2015, 02:24 AM   #14
Stewie
Stewie's Avatar
Good idea and I have a plan. I'll update the thread on what was done/concluded below.
How many miles on your car? Sitha@ft86club Scion FR-S / Toyota 86 GT86 General Forum 333 12-30-2015 05:49 PM
2000 honda civic si 33k miles on body 3k miles with turbo kit Anthony7515 Cars for Sale/Trade 3 07-28-2014 09:10 AM
Who has the most miles? cjsporl1996 Scion FR-S / Toyota 86 GT86 General Forum 44 04-23-2014 07:53 PM
27k miles carbonBLUE Off-Topic Lounge [WARNING: NO POLITICS] 30 03-31-2013 09:21 PM
BRZ/FRS over 5k miles foxhu BRZ First-Gen (2012+) — General Topics 51 02-17-2013 10:39 AM
