#15 | ||
Now while on the forum there has been one failure of the spot welds on this mount, on a car that has seen track time, without any additional failures it really seems more like a manufacturing defect rather than a design flaw. BUT, I've also seen this: ![]() Mount and strut bar completely in tact. Stock reinforcement bar completely buckled. This was from a forward impact, and it didnt affect the spot welds, but completely bent the stock bar. Do you have any idea what kind of forces it would take from a foward (completely compressive) hit to bend that bar? And in order to do so all the force would have had to have been transmitted through the "POS thin metal bracket held on by 4 spot welds." So that bracket is FAR from the weakest link in the system. That's like saying the strut towers wont be able to take the force of the spring and shock load, as well as any fore, aft, lateral forces generated from the tire because it's made out of thin sheet metal. The same thickness as the bracket in fact. Quote:
The people who are making copies are not. And unfortunately many places that are are committing the sin I just posted where you "look at something and decide if it works or not." The copies (and the people who buy the copies) are scaring real research and development away, which is why you keep seeing the same old stuff over and over. Cue that mic drop, Chase Engineering |
| The Following 5 Users Say Thank You to GrimmSpeed For This Useful Post: | Cole (08-23-2016), Createddeleted (08-23-2016), Hyper4mance2k (10-12-2016), solidONE (08-23-2016), Tristor (04-17-2018) |
#16 | |
Drives: 2013 Asphalt FRS
Once again your wrong, you have failed to acknowledge the crumple zones built into the car, that's true engineering. Do really believe that your magic bar stopped all that damage??? You might as well say strapping a pillow to the steering wheel is as good as a air bag.. Like you said frontal impact. The crumple zones reduce the kinetic energy of the impact. Show me a picture of your bar after getting a side impact into the wheel strut area... now the "mic drop" didn't mean to hurt any feeling but come on
Instagram FT86PROJECT9S
Facebook FT86PROJECT9S 710whp |
#17 | |
Hopefully you can see it in a new light once you understand what you're looking at. And no hurt feelings at all, I'm simply here to educate. Chase Engineering |
| The Following 2 Users Say Thank You to GrimmSpeed For This Useful Post: | JazzleSAURUS (08-23-2016), Tristor (04-17-2018) |
#18 | |
1: I stated, that their bar will do what anyone else's will and the brackets are the weakest link. Can we agree on that. This whole thread is about a bar. 2: You decided to go off topic and shift over to the brackets again this thread was about the bars... 3: 2 things you need to accept 1 the brackets are not designed to be used with a cross bar and the correct way to build one would be to attach it to the strut tower directly but your all engineers and know this, attaching anything to the factory brackets could create a negative outcome of the OEM design. I know everyone does it but that doesn't mean its right. 2: the factory brackets are made to tear away in a crash and to help absorb kinetic energy in a crash. If not wouldn't it be cheaper for Subaru to bolt the bar to the strut tower.... You can belittle me all you want or talk down to me all you want I don't care. If your going to educate at least tell the whole story instead of the one that sales...
#19 | |
| The Following User Says Thank You to ModBargains.com For This Useful Post: | GrimmSpeed (08-24-2016) |
#20 |
Frosty Carrot
Drives: The Atomic Carrot
First off, please try to be respectful when criticizing a supplier who actively supports our community (with engineering content, customer support, group buys, and vendor fees).
As a quality engineer, I'll add my 2 cents: - Bolting to that area is relatively risk-free. There's plenty of reinforcement at the strut mounts, and M10 bolts can withstand ~5000 lbs in single shear (Class 8.8). With 2 on each side, I'm pretty certain other components will be failing first. - The difference between stitch/spot welds and running a full bead is minimal. Tack welds are a different story. - The XIIIMotorsports bar looks over-designed, but more structural rigidity is a good thing. - If Grimmspeed isn't getting significant field returns or customer complaints, that's a good indicator of quality. Validation/Simulations are an important part of the R&D process, but field data is king. We all want good quality parts in the aftermarket, and both of these fit the bill. From what I can tell XIIIMotorsports makes some legit bushings/mounts for other vehicles. Their bar looks beefy. There's no reason to suspect that they copied Grimmspeed's design, since this is a mature product sector with FT86Speedfactory and Perrin also having similar "keep it simple" solutions. If I were in the market for a strut brace, I'd support the guys who invested early in their R&D with legit tools (like a FARO arm), data analysis, and taking the time to market the product transparently.
If you think you're nerd enough, join in the discussions about Suspension and Aerodynamic modelling!
Wall of Fame - JDL Auto Design, Raceseng, Vishnu Tuning, Penske Shocks, Nameless, Perrin, RaceComp Engineering, Essex/AP Racing, Verus, RacerX Wall of Shame - aFe Takeda, Wilwood, FA20Club Last edited by Shankenstein; 08-24-2016 at 01:22 PM. |
| The Following User Says Thank You to Shankenstein For This Useful Post: | GrimmSpeed (08-24-2016) |
#21 | |
First off I believe respect should be both ways not just one way. When people speak to others as if they are ignorant I lose respect quick. If my opening post was a little to blunt for some and their feelings are hurt I apologize . Now as far as bars go, I could care less who's bar it is, if it's bolted to the brackets it will perform the same.. IF they are built comparably the same. Here is the kicker that really needs to be addressed in my opinion. The brackets are not designed to be used for a crossbar and that's apparent. 1. they are thin 2. they are spot welded with 4 spots. The factory bars are designed to absorb kinetic energy from a crash. Along with the crumple zones. So when you triangulate the bars you just strengthened a safety feature and effectively rendered it useless as it will no longer perform as designed, that's a fact.... Some people don't care, some people don't think about it but all in all it should be known to all this is a safety device modification. Now as far as stitch welding, spot welding and seam welding it is far from a minimal in strength difference but that's another topic. The bolt shear strength doesn't really matter as the welds will fail before the bolts. In all fairness I will say I run a crossbar and it is bolted to the bracket. Also I run the Grimmspeed hood struts.. I have no problem with Grimmspeed...Or any other vendor but I will never lay down and let someone talk to me in a belittling way. Period....I don't hold it against the company that one engineer made some questionable remarks he could have been having a bad day, we all do.....
Facebook FT86PROJECT9S 710whp Last edited by FRS Justin; 08-25-2016 at 01:02 PM. |
#22 | ||||||||
It was the negative comments insinuating that what we do isn't true engineering, and that we have no clue what we're talking about that forced me to leave the conversation instead of further explaining the strength of the brackets. A 3 dimensional formed piece of steel is stronger than its "thin," flat counterpart. And the strength of the bar must be at least comparable to provide significant benefit. That is why my comments about the bracket were relevant, despite your claim that they are not. Again, this is why I left the conversation and will be gone after. I apologize to those who were interested in continued discussion. Quote:
However with that said, respect belongs where respect is due. I'm all for engaging in productive and educating discussions. When we make claims we provide evidence via testing or data. Many choose to ignore that, and that's okay. But to insult our abilities and knowledge as engineers and say that we're ignorant of the structural components and forces involved in vehicles that we make components for is beyond insulting. The anonymity of the internet I think makes people forget they are speaking to real people. I greatly apologize for how off topic this review has gotten, and for that I'll be exiting the conversation. I guess we'll just have to agree to disagree unless you have any data to back up any of your claims. Chase Engineering |
#23 |
Site Moderator
Drives: ichi 86 Project
![]() This thread have been interesting and educational.
| The Following 3 Users Say Thank You to ichitaka05 For This Useful Post: |
#24 |
Ok let’s do this,
1: After my initial post the first sentence you said was “Presenting opinion as fact is a very dangerous thing to a community. The "POS thin metal bracket held on by 4 spot welds" is a LOT stronger than you think. Just because a bracket is thin, doesn't mean it's weak, especially if it is stamped into a known TESTED structure. 4 spot welds can also hold a LOT more than you think, especially when they are designed with a specific mounting intent to do so. The engineers who designed this car were not born yesterday, and certainly knew what they were doing when that designed a mount that takes loads from both cornering, as well as braking” I find this very rude and condescending, then you close with this jab. “Cue that mic drop, Chase Engineering” Cue the mic drop???? You say this and think I should show respect? Nowhere did I state anything about Grimmspeed, I even gave examples of what I was talking about. Here I will post it again so you can re-read it and maybe understand what im talking about. That’s basically what you told me right. I didn’t understand what I read. “I will tell you right now the Xiiimotorsports bar will do everything anyone elses bar does...... Not for one minutes will you sell me on stronger better faster.. Look what the bar bolts to, a piece of shit thin metal bracket held on by 4 spot welds...... (its only as strong as its weakest link) It's getting real annoying people say how their crap is the best and it's nothing more than a copy of what's been done. How about we invent something new and revolutionary, equipment that works instead of a modified copy.... Look at the new turbo kits mostly copies of something that someone else has already done. roll bars just about a identical copy of what's been done. And half the new shit is worse than the old and dangerous.... Come on People we are better than this........shm” This is directed to everyone, anyone who wants to develop not just you. I’m not going to address every time your feelings were hurt so let’s move on. “I engaged in this discussion providing not only facts, but actual photo evidence backing up my claims about the mounting brackets not "being the weak link." Your photo evidence is not factual at all because it does not, will not, and cannot pertain to this discussion.
“Now as far as bars go, I could care less who's bar it is, if it's bolted to the brackets it will perform the same.. IF they are built comparably the same.” “ That's a lofty claim, do you have any data to back that up, or is that purely anecdotal?” I should ask you the same Please post your results and data on the bars you tested against yours. No butt dynos or it just feels better please… hard data please “So when you triangulate the bars you just strengthened a safety feature and effectively rendered it useless as it will no longer perform as designed, that's a fact...”. I should clarify on this because I didn't write it clearly. Its not useless but is no longer up performing to factory spec. I apologize for the confusion. Again, I'm interested to see any data or information about this. I know that I posted a picture showing the opposite of this, but I'm open to any proof that you have if that is a fact.” Actually the picture shows exactly this. Engineering 101 a triangle is strong right, well the brackets didn't tear away 1: No one can say for sure because the car crash was not in a controlled environment under precise conditions so there is no way really to say. Now when it comes to engineering a part or system everything works together change one thing and you and you changed the whole matrix…. I have over 30 years in the automotive field. I don’t dream this up. I will try my best to gather the info you requested it might be hard but I’m willing to try I have some contacts at Subaru. So in closing does any of this really matter? Is a crossover bar going to fail and cost someone their life? Probably not or better yet most likely not very slim chance. Probably have a better chance of getting in a shark attack. But yes it does change things.
#25 |
Drives: 10 Series #974 6m/t
Smh i put a Cusco strut bar on over two years ago and have never felt a difference lol
| The Following 3 Users Say Thank You to NyC Zn6 For This Useful Post: |
#26 | |
Drives: Whiteout FRS
| The Following 4 Users Say Thank You to shellslinger For This Useful Post: |
#27 |
Drives: 2014 GT86
Wasn't Cusco sticker sufficient for that?
| The Following User Says Thank You to churchx For This Useful Post: | FRS Justin (08-27-2016) |
#28 |
Potato Farmer
Drives: #SLOBRZ
I bought my Grimmspeed bar cause of the development thread on here, they are the only company that worked with the community to develop it, and showed so much of the testing and R&D that went into it!
For a company to do that, it earned a lot of respect in my books! Keep up the good work boys! Cusco I think had their strut brace out before the cars were released.. I also bought mine pretty much for looks, was surprised when I noticed a difference (think its due to the stiff, aftermarket coilovers)
Something something butter..
www.vic86brzclub.com |
| GrimmSpeed Strut Tower Brace - Review | Gopherboy6956 | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 49 | 12-16-2019 12:33 PM |
| Password JDM Ultimate Strut Tower Brace Package Review and Photoexplosion | F1point4 | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 20 | 06-16-2015 03:05 PM |
| Strut Tower Bar VS Strut Tower Brace | norcalpb | BRZ First-Gen (2012+) — General Topics | 8 | 10-23-2014 10:31 PM |
| "Strut" Your Stuff With A BeatRush Strut Tower Brace // DSG PERFORMANCE | Jason@DSG | Groupbuys | 14 | 12-31-2013 09:06 AM |
| FT-86 SpeedFactory Strut Tower Brace Review | F1point4 | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 35 | 01-07-2013 04:31 AM |
