Old 10-23-2014, 03:34 PM   #1
norcalpb
norcalpb's Avatar
Strut Tower Bar VS Strut Tower Brace
Looking to stiffen up the front up my car to dial in a little more under steer...
Current suspension setup:
Stock tires
Stock end links x4
Stock rear shock mount
HVT Front Top Hats
Koni Inserts
RCE Tarmac Springs
Hotchkis Front Sway Bar
OEM WRX rear bar w/ whiteline bushings.
1.5' camber x4
0' toe x4
So basically my question is what's better for $150: something like the grimmspeed strut bar or Cusco non adj strut braces?
Thanks in advance.
Old 10-23-2014, 04:33 PM   #2
JohnJuan
JohnJuan's Avatar
Drives: 2013 FR-S, Hot Lava; 2012 Z1000 CBO
Why not drop an extra $50 to get the AEM? It's solid like the GrimmSpeed, but has a brake master cylinder brace built right in.
JohnJuan is offline   Reply With Quote
Old 10-23-2014, 04:51 PM   #3
fatoni
I'm not sure a strut bar is going to do that. What you need is an alignment
Drive upgrades. Don't buy them.
The Following 3 Users Say Thank You to fatoni For This Useful Post:
JohnJuan (10-23-2014), SomeoneWhoIsntMe (10-23-2014), Ultramaroon (10-23-2014)
Old 10-23-2014, 06:15 PM   #4
Gunman
Drives: 2019 Mazda Miata RF
Running the front bar full stiff?
Gunman is offline   Reply With Quote
Old 10-23-2014, 08:49 PM   #5
norcalpb
norcalpb's Avatar
I'm considering the Hotchkis triangle bar, I already have a MBC brace
Front bar is on full stiff.
Do you mean my alignment is off or I need to change camber settings?
Old 10-23-2014, 09:03 PM   #6
fatoni
change your settings. its going to be both more effective and cheaper. an alignment is probably the most powerful tool at your disposal at this point. a sway bar adjustment or going back to the stock rear sway is also a better option in my opinion.
Old 10-23-2014, 09:34 PM   #7
norcalpb
norcalpb's Avatar
Ok gonna probably have them take away camber from the front or something. I will go auto crossing Sunday and see if I really want to change it. Thanks for the answer.
Old 10-23-2014, 09:39 PM   #8
fatoni
go to a track oriented shop and they can get you a cool alignment. you also might want to consider some toe. i didnt look at your specs really but less camber might not be the answer.
Old 10-23-2014, 10:31 PM   #9
Digitalanalog
Drives: '13 BRZ Limited, '95 BMW M3
Why increase understeer for autox? Are you going that fast to benefit from it in the corners?
Digitalanalog is offline   Reply With Quote
GrimmSpeed Strut Tower Brace - Review Gopherboy6956 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 49 12-16-2019 12:33 PM
Anyone using the STi Flexible Strut Tower Brace? ngabdala Suspension | Chassis | Brakes -- Sponsored by 949 Racing 45 08-15-2019 01:59 AM
BRZ/FR-S Strut Tower Brace - Any Interest? GrimmSpeed Suspension | Chassis | Brakes -- Sponsored by 949 Racing 1224 05-10-2015 06:40 PM
"Strut" Your Stuff With A BeatRush Strut Tower Brace // DSG PERFORMANCE Jason@DSG Groupbuys 14 12-31-2013 09:06 AM
DIY - Strut Tower Brace - FT-86 SpeedFactory F1point4 DIY (Do-It-Yourself) Guides 4 10-28-2012 04:30 PM
