Old 10-28-2012, 11:39 AM   #1
F1point4
Photo Specialist
F1point4's Avatar
Drives: 2013 Toyota 86 DGM 6MT
FT-86 SpeedFactory Strut Tower Brace Review
Today we are looking at a strut tower brace from @FT-86 SpeedFactory. As always the transaction was effortless.
Initial Thoughts
Our cars use a MacPherson strut system (spring and damper are combined) in the front, so there is inherent flex in the strut towers. Usually speaking this contributes to body roll in high speed cornering. I believe that any upset in the chassis could make you slower, simply because the car has to correct itself coming out of corners. A brace, if designed properly will transfer weight laterally and reduce flex.
To be effective, you have to tie the two strut towers and firewall together and the brace must be rigid. This bar, although two pieces, is rigid, unlike some braces which have pivot points. Ideally you'd want this to be one piece, but I believe it was two simply because of the darn AC hose.
Looking at the OEM brace vs this, I can visually see an improvement. The FT-86 SpeedFactory bar is greater in diameter. It is also hollow like the OEM brace. The brace is steel and all joints are TIG welded in the USA. The finish is great; it's powder coated and doesn't "Bling" out the engine. Overall it doesn't add much weight, but I like how force can be transferred laterally through the horizontal bar and name plate. I think it's priced reasonably to the competition given the materials, finish, and country of origin.
Installation was fairly easy. I didn't have to jack up the car and a few hand tools were required. The AC line still runs fairly close to the horizontal bar. I took precautionary measures with some pipe insulation.
Check out the DIY here
http://www.ft86club.com/forums/showthread.php?t=20862
Driving Feedback
I put a few hundred miles driving under various situations. When doing high speed manuevers the car simply feels flat. Already driving fairly aggressive, I didn't want to find the new limit where body roll is introduced. Keep in mind my car is not stock (understatement), yet I can feel the difference.
During daily driving, you'll be hard pressed to notice anything. I think it does help with response time accelerating out of rolling right hand turns; the car doesn't have to do much to balance itself. That's still daily driving, haha. I believe the purpose of this is for aggressive situations, and it's good to know your car is ready for it when you need/want it.
I'll update this when I can test out the fitment with the @GrimmSpeed Master Cylinder Brace
Summary and Photos
Overall I'm happy
+ Hella functional - Solid brace, larger than OEM, connects the strut towers and firewall together
+ construction in USA
+ Aligns with my character and goals - Not blingy at all
+ It does improve handling at high speeds
- Still two parts (darn AC hose)
- It might be better if it went around the three strut bolts.
- Fit of certain catch Oil catch cans maybe difficult
? Does it fit with master cylinder braces,. we'll find out soon!
Sea of photos ahead
20121022-FT86SpeedFactoryStrutTowerBrace-01 by VictorN07, on Flickr
Welds
20121022-FT86SpeedFactoryStrutTowerBrace-02 by VictorN07, on Flickr
Finish
20121022-FT86SpeedFactoryStrutTowerBrace-03 by VictorN07, on Flickr
Rear
20121022-FT86SpeedFactoryStrutTowerBrace-04 by VictorN07, on Flickr
Joints are welded/ mounting brackets
20121022-FT86SpeedFactoryStrutTowerBrace-05 by VictorN07, on Flickr
20121022-FT86SpeedFactoryStrutTowerBrace-06 by VictorN07, on Flickr
Horizontal Bar Joint
20121022-FT86SpeedFactoryStrutTowerBrace-07 by VictorN07, on Flickr
20121022-FT86SpeedFactoryStrutTowerBrace-08 by VictorN07, on Flickr
Comparison to OEM
20121025-FT86SpeedFactoryStrutTowerBrace-09 by VictorN07, on Flickr
The OEM brace is thinner, but the OEM brace is one piece
20121025-FT86SpeedFactoryStrutTowerBrace-10 by VictorN07, on Flickr
20121025-FT86SpeedFactoryStrutTowerBrace-11 by VictorN07, on Flickr
20121025-FT86SpeedFactoryStrutTowerBrace-12 by VictorN07, on Flickr
Horizontal brace on car. The holes are slightly larger.
20121025-FT86SpeedFactoryStrutTowerBrace-14 by VictorN07, on Flickr
Firewall brace on car. Note the hole sizes. We reuse OEM hardware
20121025-FT86SpeedFactoryStrutTowerBrace-15 by VictorN07, on Flickr
Firewall mount. There is a bolt and a nut on each side
20121025-FT86SpeedFactoryStrutTowerBrace-16 by VictorN07, on Flickr
Installed. Took this before I added the insulation tape to the AC hose
20121025-FT86SpeedFactoryStrutTowerBrace-17 by VictorN07, on Flickr
Closeup
20121025-FT86SpeedFactoryStrutTowerBrace-18 by VictorN07, on Flickr
F1point4 is offline   Reply With Quote
Old 10-28-2012, 12:30 PM   #2
vubaru
Now with Boost!
vubaru's Avatar
Drives: 2013 SWP BRZ Ltd.
Nice post. How thick is the nameplate metal? You bring up an interesting point that an advantage of this system vs. another (e.g. Cusco) is the additional lateral force that might be transferred through that nameplate.
Another advantage vs. Cusco would be the price, too... those "Engine Power Braces" are like $400 alone, lol.
Would a standard strut tower bar like the Cusco OS fit over top of this?
Also given the placement of the nameplate it looks like this won't fit if you have something like a Crawford AOS (bolts on on the firewall right behind where the nameplate is iirc), which I have sitting in a box next to me
vubaru is offline   Reply With Quote
Old 10-28-2012, 12:33 PM   #3
YoKeutla
Drives: Scion FRS
Fantastic photos, as always, Victor! Thanks for the write up!
Sponsored By: FT-86 SpeedFactory - http://ft86speedfactory.com
Cheers!:happy0180:
YO
YoKeutla is offline   Reply With Quote
Old 10-28-2012, 01:26 PM   #4
Ash
Drives: 86 GTS
Looks great! i cant wait to see the attempt for the master cylinder braces. Ide love to thank this post but i have no idea how to.. haha
*edit* actually, i just got the thanks button
Ash is offline   Reply With Quote
Old 10-28-2012, 02:52 PM   #5
FT-86 SpeedFactory
FT-86 SpeedFactory's Avatar
These can be purchased without the name plate as well.
Thanks again to Victor for the photos and write up.
FT-86 SpeedFactory is offline   Reply With Quote
Old 10-28-2012, 03:36 PM   #6
TTGT
TTGT's Avatar
Drives: 2013 Whiteout FRS
custom name plates???
TTGT is offline   Reply With Quote
Old 10-28-2012, 03:59 PM   #7
JoeBoxer
JoeBoxer's Avatar
Drives: Whiteout FR-S
There is a group buy going for a MC brace on turninconcepts website if you haven't ordered the grimmspeed already.
JoeBoxer is offline   Reply With Quote
Old 11-01-2012, 10:25 PM   #8
F1point4
Photo Specialist
F1point4's Avatar
Got to install the Grimmspeed master cylinder brace. It works perfectly with this strut tower brace!
20121101-GrimmspeedMCB_SpeedFactoryBrace-02 by VictorN07, on Flickr
20121101-GrimmspeedMCB_SpeedFactoryBrace-01 by VictorN07, on Flickr
Old 11-01-2012, 10:37 PM   #9
jstans84
Drives: Scion FR-S
I would be interested in it if it said GT86 instead of FT86.
jstans84 is offline   Reply With Quote
Old 11-02-2012, 02:09 PM   #10
AJ PwR
AJ PwR's Avatar
Drives: R35 R56 CZ4A ZC6
Send a message via ICQ to AJ PwR Send a message via AIM to AJ PwR Send a message via MSN to AJ PwR
Nice piece. Do you sel the triangle portion separately ? Will that work with Cusco STB ?
AJ PwR is offline   Reply With Quote
Old 11-02-2012, 02:21 PM   #11
gmookher
nice pictures-you must be shooting with a nice setup or good glass for that color in that lighting...ED nikon>?
gmookher is offline   Reply With Quote
Old 11-03-2012, 05:24 AM   #12
F1point4
Photo Specialist
F1point4's Avatar
Thanks, I try to shoot in good lighting or heavily diffuse any flash used. I throw everything through Lightroom for final effects. My kit right now is
Nikon D700
Nikon 24 1.4G, 35 1.4G, and 70-200 2.8 VRII
Nikon SB600 (lol)
Cars aren't my only focus, but it happens to be currently
Old 11-07-2012, 10:20 AM   #13
FT-86 SpeedFactory
We do sell it separately. Will clear the Cusco STB.
Old 11-07-2012, 04:22 PM   #14
xcelir8brz
Drives: 2013 BRZ Limited
sub'd.
xcelir8brz is offline   Reply With Quote
ft-86 speedfactory, review, strut tower brace
New Release - FT-86 SpeedFactory - Strut Tower Bar / Tri-Bar FT-86 SpeedFactory Suspension | Chassis | Brakes -- Sponsored by 949 Racing 28 10-25-2013 04:42 PM
**NEW PRODUCT** FT-86 Speed Factory - Strut Tower / Engine Brace Bars FT-86 SpeedFactory Brakes, Suspension, Chassis 35 06-04-2013 09:27 PM
DIY - Strut Tower Brace - FT-86 SpeedFactory F1point4 DIY (Do-It-Yourself) Guides 4 10-28-2012 04:30 PM
SRT Strut Tower Triangulation Bar Swift Racing Technologies Brakes, Suspension, Chassis 34 10-24-2012 05:15 AM
