Old 07-28-2016, 07:24 PM   #15
gramicci101
Off Topic
You don't break out the time delay reflectometer to see where the break in the wire is?
The Following 2 Users Say Thank You to gramicci101 For This Useful Post:
Tcoat (07-28-2016), Ultramaroon (07-28-2016)
Old 07-28-2016, 09:03 PM   #16
Nah. I lick my hand and run it down the wire until it tingles. Much lower tech.
Don't try that guys it will not work
Old 07-28-2016, 10:56 PM   #17
You don't break out the time domain reflectometer to see where the break in the wire is?
fify
...but SHIT! Outside of my VQ peeps, you're the first person to ever mention one!
gramicci101 (07-29-2016)
Old 07-28-2016, 11:22 PM   #18
justatroll
justatroll's Avatar
Drives: Full race 4cyl boxer
fify
We tried to use a TDR on the Deep Impact spacecraft 1553 bus to find broken wires.
It probably would have worked even though the max length in the bus was only ~50 feet, but we had too many breaks in the shield grounds.
Arguing with an engineer is like wrestling with a Pig in the mud. You are never going to win and after a couple of hours you realize that he likes it.
justatroll is offline   Reply With Quote
Old 07-28-2016, 11:25 PM   #19
Packofcrows
hey you, yeah you <3
Packofcrows's Avatar
Drives: 2014 37J FR-S
Originally Posted by krayzie View Post
That really work?
Old 07-28-2016, 11:43 PM   #20
Yeah, makes it impossible to tweak it in. They may have improved over the years but the ones we had back in the 80s were pretty tricky. It's a bit of an art.
justatroll (07-29-2016)
Old 07-29-2016, 12:59 AM   #21
krayzie
Drive From Home
krayzie's Avatar
Drives: BRZ STI Performance
Originally Posted by Packofcrows View Post
That really work?
Yea this contact cleaner works great actually, not cheap and hard to find (at least in Canada).
krayzie is offline   Reply With Quote
Old 07-29-2016, 12:59 AM   #22
gramicci101
Off Topic
fify
It's been 15 years since I used one, and then only rarely. It was more of a pain than it was worth when troubleshooting aircraft. There were so many bulkhead disconnects that you could just use a multimeter and shoot sections at a time for continuity.
Old 07-29-2016, 01:17 AM   #23
Right?! Ok, so how many issues did you encounter that weren't caused by overzealous periodic maintenance?
I'll guess maybe 1%.
Old 07-29-2016, 01:26 AM   #24
gramicci101
Off Topic
Ha, you'd have to know the airframe. I worked avionics on F-16s; mostly flight control, fire control, and radar threat warning systems. Most of the maintenance issues were caused by pilots overstressing the systems. Sometimes at 9 g's things just break.
The Following User Says Thank You to gramicci101 For This Useful Post:
Ultramaroon (07-29-2016)
Old 07-29-2016, 01:38 AM   #25
Considerably more interesting than fixing an endless parade of worn intermittent coax connectors dripping with CPC. Blecch.
Old 07-29-2016, 01:55 AM   #26
gramicci101
Off Topic
It was very interesting. There was some routine stuff, but a lot of it was troubleshooting issues. And as the planes got older it was no longer bad parts, it was bad wires between the parts. It was also very high stress, and I couldn't get out and work on someone's F16, so I cross-trained.
Another Backup Cam Doesn't Work Thread ChrisJ Electronics | Audio | NAV | Infotainment 5 07-01-2016 10:09 PM
Driver side Window button Quvit92 Scion FR-S / Toyota 86 GT86 General Forum 16 01-09-2015 06:55 PM
driver side Windows cant contrl by driver side button athlon816 Issues | Warranty | Recalls / TSB 12 12-13-2014 10:06 AM
USB port doesn't work brianc901 Electronics | Audio | NAV | Infotainment 2 08-15-2014 05:40 PM
Passenger Side Window Doesn't Work JNovo79 Issues | Warranty | Recalls / TSB 5 02-18-2014 03:14 PM
