Drives: 2014 Subaru BRZ
Another Backup Cam Doesn't Work Thread
Hello,
I bought a Roadshop backup cam and installed it into the BRZ head. The camera worked perfectly for several months. Then the camera stopped working entirely. The diagnostic screen says the backup camera is not detected. I pulled the head and all the connectors and cables look fine. I soldered the connections and they're solid. Went to the dealer and they didn't help. I cut the power wire and confirmed that camera is not getting power from the head. This is in reverse. I was hoping to get a little help before I go further. The next step will be to confirm that the camera runs with an independent power source. Assuming it does, 1) What's a good place to pull power for the camera? I'd rather tap into a tail light or reverse light than connect to another line in the dash. 2) Has anyone heard of a command to disable the backup camera? I was reading this for a Subaru Outback The rear view display has two levels of ON/OFF-ness: 1) Briefly pressing the power button (while in reverse) toggles the display ON/OFF, but it reverts to ON when the ignition is turned off then back on. 2) Holding the power button down for 12-15 seconds (while in reverse) disables the display, and it remains disabled until you repeat the 12-15 sec button press. (see 2011 Owners Manual pages 3-36, 3-37) So this isn't 2011 and it's not an Outback, but still. . . 3) Can anyone tell me which fuse controls the backup camera line? Thanks to all of you in advance. |
Radio wiring harness guru
Drives: 1996 SVX L AWD
Which BRZ head unit model? (find the number printed on the front, as well as the numbers on the mfr's sticker on the top)
Is this really in a Toyota MR2, or do you need to update your profile? (in other words, what car year and model is this?) Subaru BRZ Fujitsu Ten HUs check for the camera each time you turn your key from OFF to ACC. The HU will decide you don't have a camera (and thus disable the camera function) if it does not see the camera video signal during that test. That could be caused by no video signal from the camera, which could be due to any of these reasons:
Narrow down the location of the problem:
Hook it to the reverse light positive.
My 2016 Build thread TRD Exhaust with custom quad tips, TRD Lowering Springs,TRD Quick shifter,LED;DRL, Projectors, and turn signals. Re-badge, 86 Nanny, WinmaxW2 Pads, K&N Drop In, Antenna delete |
Toyota head units (and some of Subaru's) won't work that way -- the HU will fail to see the camera during the HU's boot-up check.
| The Following User Says Thank You to SVXdc For This Useful Post: | stevesnj (06-26-2016) |
Drives: 2013 FRS
Im also having problem but totally opposite from your situation. My camera is getting constant power when gear is in drive. Camera has built in led lights so I can see when its getting power.
Damn i was hoping i could just tap it to reverse light. Sent from my Nexus 6P using Tapatalk |
If I had the 2016 wiring diagram for my car i can find out where the cam gets power from... in the FSM it just shows a connector. Probably 2-3 wires.
| Backup Camera Kit Doesn't Work | Quentin! | Electronics | Audio | NAV | Infotainment | 4 | 08-08-2016 11:24 PM |
| Error Code, Nav doesn't work | slyphen | Issues | Warranty | Recalls / TSB | 2 | 12-04-2015 03:37 PM |
| USB port doesn't work | brianc901 | Electronics | Audio | NAV | Infotainment | 2 | 08-15-2014 05:40 PM |
| Passenger Side Window Doesn't Work | JNovo79 | Issues | Warranty | Recalls / TSB | 5 | 02-18-2014 03:14 PM |
