Old 12-04-2014, 01:31 AM   #1
athlon816
athlon816's Avatar
Drives: brz
driver side Windows cant contrl by driver side button
the window of passager side cannot contrl by driver side button and the light of passager side window button is flash slowly...:confused:.....any software problems? any one know
athlon816 is offline   Reply With Quote
Old 12-04-2014, 02:03 AM   #2
king83c10
king83c10's Avatar
Drives: 2013 FRS
Go to the passenger side of the car with the door closed roll the window all the way down and then back up, then hold the button for about 5 seconds once the window is up. The button should stop blinking and you will regain control from the driver side.
king83c10 is offline   Reply With Quote
Old 12-04-2014, 02:05 AM   #3
athlon816
athlon816's Avatar
Drives: brz
thanks a lot...
Old 12-04-2014, 02:05 AM   #4
athlon816
athlon816's Avatar
Drives: brz
just want to know what is the function for? how is causing ?
Old 12-04-2014, 02:12 AM   #5
king83c10
king83c10's Avatar
Drives: 2013 FRS
Happens to me when my window gets frozen up. I believe it protects the window linkage or motor from breaking under these situations.
Old 12-04-2014, 02:15 AM   #6
athlon816
athlon816's Avatar
Drives: brz
oh yes, recently the weather has became -1,.and may be forzen
Old 12-04-2014, 02:21 AM   #7
king83c10
king83c10's Avatar
Drives: 2013 FRS
On these cars the outer window seal tends to freeze up. I just wait for it to thaw out or you can use a thin plastic scraper to release the ice from the seal.
Old 12-04-2014, 08:47 PM   #8
Scaldy
Scaldy's Avatar
Drives: 2013 red FR-S mt
Thank you for this thread. It all makes sense now! phew
Scaldy is offline   Reply With Quote
Old 12-05-2014, 06:20 PM   #9
starron
Drives: FRS 10 Series
I have the exact same problem but the method king83c10 provides does not work for me. The passenger side button wouldn't stop blinking after 5 even 10 second or holding.
any other suggestions or I should bring it back to the dealer to check?
starron is offline   Reply With Quote
Old 12-05-2014, 09:31 PM   #10
Scaldy
Scaldy's Avatar
I had to put both windows down/up and hold both for 5 seconds before it fixed. Hope that helps.
Old 12-07-2014, 12:22 AM   #11
navanodd
Drives: 2013 BRZ Sport-tech WRB
http://www.ft86club.com/forums/showt...21#post2017021
navanodd is offline   Reply With Quote
Old 12-09-2014, 06:31 PM   #12
starron
No luck with all the methods suggested above. Actually my doors were taken apart for putting vinyl on under the mirror area. I believe there is something to do with it.
Should I bring it back to the vinyl shop see if they can fix it or will my dealer take care of it for me free of charge?
Old 12-13-2014, 10:06 AM   #13
BlackMonarch
Drives: Red BRZ
This is the condensation sensor in the door, which upon temperatures near freezing, as well as detecting moisture, will prevent the windows from rolling down and damaging the motor in the door\breaking the glass\etc.
BlackMonarch is offline   Reply With Quote
DRL not dim on driver's side jsvegas Cosmetic Modification (Interior/Exterior/Lighting) 5 06-30-2014 10:01 PM
New FRS driver side headlight $200 retrosmiths Exterior Parts (Aero, Lighting, Etc.) 2 08-04-2013 12:06 AM
WTB: smoked side marker (driver side) vincent201089 Exterior Parts (Aero, Lighting, Etc.) 2 07-29-2013 04:29 AM
WTB BRZ driver side headlight zex Canada Classifieds 0 07-21-2013 05:19 PM
4 pin connector driver side charley026 Cosmetic Modification (Interior/Exterior/Lighting) 0 03-30-2013 01:27 PM
