Old 07-26-2016, 06:24 PM   #1
Aphaux
Aphaux's Avatar
Drives: Silver 2013 BRZ
Driver side trunk button doesn't work.
Driver side interior trunk button does nothing when pushed or held. Fob release works, actual trunk release works, but the driver's button does not. I already ruled out the valet button.
Checked all fuses, didn't find any blown. But it' isn't listed anywhere on the panels or in the book. I just can't figure it out.
2013 brz w/28k miles.
Aphaux is offline   Reply With Quote
Old 07-26-2016, 07:13 PM   #2
Summerwolf
Panda Trueno
Summerwolf's Avatar
Drives: No twin now.
http://www.ft86club.com/forums/showthread.php?t=16865
Old 07-26-2016, 07:24 PM   #3
krayzie
Drive From Home
krayzie's Avatar
Drives: BRZ STI Performance
Read user's manual lol!
krayzie is offline   Reply With Quote
Old 07-26-2016, 07:28 PM   #4
Silver Cervy
*Some really cool title*
Silver Cervy's Avatar
On the inside of the trunk there's a little button on the side that will disable any electronic methods of opening the trunk. You most likely pressed it by accident (or somebody else did), but just press it again and it will turn off.
Silver Cervy is offline   Reply With Quote
Old 07-26-2016, 07:50 PM   #5
extrashaky
Drives: 2014 BRZ Limited
For the people who apparently missed it:
The Following 5 Users Say Thank You to extrashaky For This Useful Post:
Dadhawk (07-27-2016), FRSBRZGT86FAN (07-29-2016), PandaSPUR (07-27-2016), Tcoat (07-26-2016), Ultramaroon (07-26-2016)
Old 07-26-2016, 09:08 PM   #6
Beat me to it!
Apha, check the wires on the switch. The default setting is switch closed so if a wire came off it is now open. There was a guy on here that had a wire come off and he chased the problem for weeks before he found it.
Aphaux (07-27-2016), PandaSPUR (07-27-2016), Ultramaroon (07-26-2016)
Old 07-27-2016, 06:42 AM   #7
Aphaux
Aphaux's Avatar
Originally Posted by Summerwolf View Post
Told ya man, checked that several times. Fob works, button above license plate works, cockpit button does not.
The Following User Says Thank You to Aphaux For This Useful Post:
Summerwolf (07-27-2016)
Old 07-27-2016, 06:44 AM   #8
Aphaux
Aphaux's Avatar
I did man! lol I may be a beginner on the forum but not in life haha.
Nowhere on or in the car does it state the driver side trunk release even has a fuse, only a button and a description of what it does.
krayzie (07-27-2016)
Old 07-27-2016, 09:27 AM   #9
krayzie
Drive From Home
krayzie's Avatar
Old 07-27-2016, 04:51 PM   #10
Thanks for the LARGE PRINT version .........
humfrz is online now   Reply With Quote
Old 07-27-2016, 05:12 PM   #11
Beat me to it!
Apha, check the wires on the switch. .............
Yep, sounds like you may have to take the switch out for a look see.
Old 07-28-2016, 04:31 PM   #12
Aphaux
Aphaux's Avatar
Fixed it, switch was unplugged. Thanks for the help!
Tcoat (07-28-2016)
Old 07-28-2016, 05:54 PM   #13
Yaaaaaa!!............ @Tcoat ,solves another mystery ..........
Tcoat (07-28-2016)
Old 07-28-2016, 07:20 PM   #14
Order of electrical issue trouble shooting:
1) Does the battery have enough juice? If no charge. If yes step 2.
2) Is there a blown fuse? If yes replace fuse (and the oft forgotten find out why blew). If no move to step 3.
3) All connections on both ends of circuit in place, clean and firm? In no then hook back up. If yes step 4
4) Are there any obvious breaks in or pinched wires? If yes repair or replace wire. If no step 5.
5) Are you even able to find and fix the problem? Probably not, so curse and mutter, kick the tire, go grab a beer and take it to somebody else in the morning. Or, come on here and ask what it might be and then start back at number one.
Aphaux (08-29-2016), humfrz (07-28-2016)
Another Backup Cam Doesn't Work Thread ChrisJ Electronics | Audio | NAV | Infotainment 5 07-01-2016 10:09 PM
Driver side Window button Quvit92 Scion FR-S / Toyota 86 GT86 General Forum 16 01-09-2015 06:55 PM
driver side Windows cant contrl by driver side button athlon816 Issues | Warranty | Recalls / TSB 12 12-13-2014 10:06 AM
USB port doesn't work brianc901 Electronics | Audio | NAV | Infotainment 2 08-15-2014 05:40 PM
Passenger Side Window Doesn't Work JNovo79 Issues | Warranty | Recalls / TSB 5 02-18-2014 03:14 PM
