Old 03-22-2016, 11:34 PM   #29
jawn
jawn's Avatar
Drives: 2015 CWP BRZ Limited
These cars will also knock with 93 octane, but you do you, playboy.
jawn is offline   Reply With Quote
The Following User Says Thank You to jawn For This Useful Post:
Cole (03-23-2016)
Old 03-22-2016, 11:45 PM   #30
CatScan
It will also knock on VP-110 and E85. What's your point?
CatScan is offline   Reply With Quote
Old 03-23-2016, 12:07 AM   #31
FRSBRZGT86FAN
FRSBRZGT86FAN's Avatar
Originally Posted by Chanpion View Post
The owner's manual actually says 93 octane and do not exceed 30% ethanol I believe. You can read it yourself.
Yup that's from my snippet I had in the my post
Old 03-23-2016, 12:10 AM   #32
FRSBRZGT86FAN
Originally Posted by CatScan View Post
That's in that book-thing in the glove box, right? Strange how well the car runs on E85. And for 87, I just back the plugs out a few turns to lower the compression. Problem solved.
Here, I shall also respond with a picture:
You do your thing, I'll do mine. You panic if you have to over having to use "crap" gas "every now and then".
What tune do you run when you're doing this 87? The stock tune has a hard time with 91 as it is and you think it's alright to subjecting to knock at 87 for a constant time
Did you run E85 without the OFT tune? IT CAN ONLY RUN WELL WITH A TUNE, unlike running 87 once in a blue moon, E85 on a stock tune will actually destroy a good motor, it's equivalent to running fuel over 105 octane
Regardless, the car probably ran like shit in the first case where you keep running 87 because you don't believe anyone, and you're engine may just fall apart eventually or you'll get a P0326 or P0331 code and go crying to a dealer where they may just have the urge to void your warranty
Old 03-23-2016, 12:25 AM   #33
jawn
jawn's Avatar
The car will pull timing with bad gas. No one's denying this. Can you run 87 gas? Yes, absolutely. The car will pull timing, and IAM will drop. That said, with IAMs as low as 0.2 with 91 octane, why would you bother with anything lower than 91 octane? Where do you live that you can't at least get 91 octane? Why would you intentionally run your car at IAMs that low?
But like I said, you do you, playboy.
The Following 2 Users Say Thank You to jawn For This Useful Post:
FRSBRZGT86FAN (03-23-2016), HunterGreene (03-23-2016)
Old 03-23-2016, 01:02 AM   #34
Hotrodheart
Hotrodheart's Avatar
Or there is always:
What's a manual?
Hotrodheart is offline   Reply With Quote
The Following User Says Thank You to Hotrodheart For This Useful Post:
86kahl (05-02-2016)
Old 03-23-2016, 01:24 AM   #35
finch1750
Undisputed El Presidente
finch1750's Avatar
Drives: Zenki 37J ZN6
Dude is using generalities and other fallacies as arguments like they are gospel, ignoring facts posted by other discounting the argument. OP, use 91 or higher. If you are in bumfuck nowhere plan to stop more often or bring gas cans to protect the life of the engine.
IB4L
Old 03-23-2016, 01:25 AM   #36
finch1750
finch1750's Avatar
Originally Posted by Hotrodheart View Post
What's a manual?
Thats the one without flappy paddles I think
The Following 3 Users Say Thank You to finch1750 For This Useful Post:
86kahl (05-02-2016), Kestrel (03-23-2016), mdm (03-23-2016)
Old 03-23-2016, 01:41 AM   #37
FRSBRZGT86FAN
IB4L
It's not worth it, make the assumption he's a troll and has no clue what he's talking about or doesn't understand how the tunes work. Look at his past posts for perspective:
The Following User Says Thank You to FRSBRZGT86FAN For This Useful Post:
finch1750 (03-23-2016)
Old 03-23-2016, 02:22 AM   #38
finch1750
finch1750's Avatar
Wow. Does this forum give out Darwin Awrds? Cuz this dude is gonna murder his engine. Hopefully he runs the motor while the oil is draining so it all comes out to swap every last drop since he's abusing his car that way...
The Following 2 Users Say Thank You to finch1750 For This Useful Post:
FRSBRZGT86FAN (03-23-2016), go_a_way1 (03-23-2016)
Old 03-23-2016, 03:16 AM   #39
STZ
Drives: '15 WRB BRZ Sport-tech
Jesus dude come on.
The manual is for the car when it's stock. Your car is tuned for E85.
The actual fuck?
To give an analogy of your logic, it would be as if someone asked what size tires he should buy on his stock FRS, everyone says 215/45/17, and you say get 245/45/18, it'll be fine, ignore the manual! Then your justification is a picture of your car with 18 inch rims.
STZ is offline   Reply With Quote
The Following 2 Users Say Thank You to STZ For This Useful Post:
Cole (03-23-2016), FRSBRZGT86FAN (03-23-2016)
Old 03-23-2016, 06:06 AM   #40
Ok Cat. I was going to jump in and say that you are correct in saying that the car can run for short periods on 87 without any real damage but damn it after reading this one I no longer know what your real intentions are.
If serious then you need to stop doing dumb shit like above and listen to the people here.
If joking you need to make sure we understand that it is a joke and stop before taking it too far.
If trolling to just get your jollies from the responses I know a couple of mods that will ban your ass in a second.
finch1750 (03-23-2016), FRSBRZGT86FAN (03-23-2016), go_a_way1 (03-23-2016), HunterGreene (03-23-2016)
Old 03-23-2016, 06:17 AM   #41
No, then his justification would be a pic of somebody else's car picked at random off the internet. The pic he posted is from tune86.com not a picture he took of his own unit. Which he may or may not actually have. http://www.tune86.com/sites/default/...s_image_17.jpg
Old 03-23-2016, 10:55 AM   #42
HunterGreene
Hail Magnet
HunterGreene's Avatar
Seriously, CatScan.
It has priests in it?
E100 vs 99.7% ethanol diodelphi Software Tuning 25 10-31-2014 02:54 PM
93 octane w/ethanol or 91 without existensil BRZ First-Gen (2012+) — General Topics 16 05-24-2014 06:32 PM
Non ethanol gas reesmicm Scion FR-S / Toyota 86 GT86 General Forum 21 08-21-2013 02:14 PM
Ethanol Andrew666 AUSTRALIA 30 08-09-2013 08:13 AM
91 w/o Ethanol, or 93 with 10%? Superhatch Engine, Exhaust, Transmission 21 05-20-2013 10:07 AM
