#1 | ||
AIM4APX
Drives: 2013 WRB BRZ Limited
91 w/o Ethanol, or 93 with 10%?
I've been trying to find a solid answer to this question, and found this on a Corvette forum:
http://forums.corvetteforum.com/c6-t...anol-free.html Quote:
From our manual: Quote:
"It's very difficult to present technology as an overtly positive sales device to people who want an emotional car" -Chris Harris
Drives: FR-S 6MT Ultramarine (BeeDrill)
I don't know that 10% ethanol gas would vary by as much as that but I would still be cautious if you're tuning it to be right at the safe limit for what 93 or 94 octane can do. Also, whenever I've looked at the pumps it sometimes says "Up to 10% Ethanol" which says to me that it can vary. I don't know that it would ever get as low as 91 though.
2013 Scion FR-S - Ultramarine 6MT
AIM4APX
Ah, that's a good point. Our company does some work with Ethanol plants, I should ask about this next time one of our guys goes there.
well we only have 90 ethanol free gas here..and that is the highest besides the 100 octane at the airport.
2013 AT FRS...Stock... for now...
#5 | |
#6 | |
AIM4APX
Drives: N/A
If it was 91 w/o Ethanol it would be true due to spec blending. The octane posted is the minimum. But if it's 91 octane w/ 10% ethanol it's actually 90% 89 octane mixed with 10% Ethanol. While 93 octane w/ Ethanol is 90% 91 octane Gasoline with 10% Ethanol which makes it 93 octane.
In general assume it has Ethanol unless otherwise noted. Also "pure" gasoline will be significantly more expensive than Gasohol. I haven't read the actual law on how much Ethanol is considered to be Gasohol but I believe it's about 5% for the Federal requirement. It could vary between states though. Some states require signage if Ethanol is present and some allow Ethanol free gasoline to be sold statewide. Nope, and you probably won't since it's Alaska. But they use Ethanol in Canada. |
Drives: Subaru BRZ
I think the Govt just approved 15% ethanol for cars 2005 and newer.
Drives: Pavement MT GR86
in idaho and montana it's about 10-15 cents more for ethonal free gas and i've never seen it over 91....we used to have 93 with ethonal but now it's all 91. kinda blows since at elevation i'm down on power anyway.
GR86 MT premium
#10 |
Drives: car
If it says 93 octane, it's 93. Normal pump fuel is sold by the octane rating, not by the ethanol %. It might be 10% ethanol or it might vary a little bit, but basically it's gasoline cut with ethanol in some blend to meet the spec.
And yes, when buying nominal E85, the blend varies throughout the year. It's harder to start the car in winter with high ethanol concentrations, especially in cold climates. Also, the vehicle itself is certified on 97RON which is about 92 octane AKI. That's the spec for CARB Phase II fuel and EPA Indolene fuel. Now that doesn't mean the engine wasn't designed with various octane levels in mind. |
#11 |
I'm going to switch back to 94 with 10% ethanol. With it getting warmer out it feels like I'm starting to lose a bit of power up in the rev range and given what I've read on these forums I wouldn't be surprised at all if it's starting to pull a bit of timing. I'd rather get mildly worse mileage but not be pulling any timing.
#12 |
Drives: Raven Fr-S
Ethanol has energy content of ~27 kj/g while gasoline is closer to ~45 kj/g.
So any E10 will have ~43 kj/g energy content. Day to day driving, where you stay below 70% throttle all the time, you will never be in the knock limited region of the spark timing map, so the 91 w/o ethanol will give you ~5 % better gas mileage. If you go WOT a lot of the time on 91 oct, then you will run into the knock region of the map (low speed high throttle, high speed high throttle) and the ECU will pull timing from MBT (max brake torque) timing and you will lose some torque. Here, 93 oct will be most beneficial. I try to keep no alcohol 93 oct in my tank all the time provided the price difference is not more than 10% compared to 93 E10.
#13 | |
Drives: Raven Fr-S
#14 |
Yeah i've heard that before and had a pretty good idea of why......doesn't mean i couldn't get more power from a tune with better gas though.
My only consolation is that it's usually pretty cold which helps with air density and power. kinda sucks to know that every turbo car or truck has an advantage regardless of rated power.
GR86 MT premium
| Gas station that are ethanol free | norsamerican | Scion FR-S / Toyota 86 GT86 General Forum | 66 | 06-04-2016 11:02 PM |
| Ethanol free gas in NOVA | Mach5 | Mid-Atlantic | 9 | 05-02-2013 03:25 AM |
| Gas Stations without Ethanol | norsamerican | BRZ First-Gen (2012+) — General Topics | 8 | 02-22-2013 12:12 PM |
| Where to get non ethanol fuel? | mhigham | Engine, Exhaust, Transmission | 19 | 11-13-2012 11:27 AM |
