Old 05-23-2012, 05:25 PM   #29
pkny
Drives: Firestorm FR-S 6MT
I don't think it would be that difficult, most of it is just trim panels. Haven't tried it yet though because I want to retain the one that is in the current location and it doesn't appear you can make it split into two with a hub. Still need to try a powered up.
A powered hub won’t resolve your problem. If the stock unit did not supply enough current to a downstream device, a powered hub would help, but that was not the case. Actually, the stock unit should provide 500mA current to the USB port in order to make a USB massage storage device works. I am pretty sure the problem is the lack of USB hub class support from the unit. The manual should state what type of USB class the unit can support. I will check it later.
pkny is offline   Reply With Quote
Old 05-23-2012, 05:53 PM   #30
pkny
Found it. P.57 from the manual:
USB portable audio player/
USB memory compatibility
• USB version: 2.0, 1.1 and 1.0
• USB data transfer rate: full speed
USB Class: MSC (Mass Storage Class) device
• Protocol: bulk
• File system: FAT32 and FAT16
• Supply current: 500 mA
NOTES
-Partitioned USB memory is not compatible with this unit.
-Depending on the kind of USB portable audio player/USB memory you use, this unit may not recognize the USB audio player/USB memory or audio files may not be played back properly.
-This unit can play back files in the USB portable audio player/USB memory
that is USB Mass Storage Class. However, copyright protected files that are stored in above-mentioned USB devices cannot be played back. (If the iPod is connected to this unit, file playback condition depends on the iPod specifications.)
-You cannot connect a USB portable audio player/USB memory to this unit via a USB hub.
-Not all multimedia portable devices are compatible.
So, no USB hub support. Quick check on Bespoke manual (p.66). No USB hub support either.
The Following User Says Thank You to pkny For This Useful Post:
civicdrivr (05-24-2012)
Old 05-23-2012, 08:33 PM   #31
K2
First 8600
K2's Avatar
Drives: Gen2 GR86
How does this play out when you're using it? Do you have any nav-through-the-music functions or is it strictly folders?
Actually I just have it on the RANDOM setting (Press and hold Rand (button 5) till you hear a beep) so it plays a random file from any of the folders (pg 18-19 in the audio system manual).
K2 is offline   Reply With Quote
Old 05-23-2012, 08:56 PM   #32
• Protocol: bulk
NOTES
Pays to RTFM I guess. That was my last resort this coming weekend. <grin>
In theory, I could move the cable from the console to the glovebox, assuming its long enough but that really isn't want I want. Oh well, looks like I'll just "settle" for the way it works now, or stream from my phone.
Old 05-23-2012, 08:56 PM   #33
Originally Posted by civicdrivr View Post
Left/right skips, up/down changes the folder.
I hit another button the other day and it showed all the folders that I could scroll through using the volume knob, but I dont remember what button that is and I dont read manuals
Most likely the List button.
Old 05-23-2012, 08:59 PM   #34
Yea, that's the way I usually use the iPod. Either that or I start at the top of my list and play all the way through the "All" in order. Last time I did that (using an OmniFi player in my Astro) it took 35,000 miles to hear every song on our family's collection. Fun discovering and rediscovering songs though. Given we have everything from AFI to zzTop in just about every category of music, it can be a challenge.
I have a self-imposed rule when doing this that I have to listen to at least half of any song before I skip it, no matter how painful!
Old 05-24-2012, 11:26 AM   #35
K2
First 8600
K2's Avatar
Drives: Gen2 GR86
I'll allow myself to skip a song if it's played already that day.
"Pioneer, why you play "Boris the Spider" four times today?"
The Following User Says Thank You to K2 For This Useful Post:
Dadhawk (05-24-2012)
Old 05-24-2012, 12:57 PM   #36
jdrxb9
jdrxb9's Avatar
Drives: ND2, formerly BRZ (MT/CBS)
Does not look like the std BRZ Nav unit is going to be any better - from p244 in the manual:
Mass memory support: Supports USB mass storage class.
Does not support USB hubs or multi card readers.
jdrxb9 is offline   Reply With Quote
Old 05-26-2012, 01:17 PM   #37
Jayde
Jayde's Avatar
For anyone using an iPod/iPhone through the USB port for music, I've been looking for a shortened cable since I plan to keep the device in that little cubby next to the port. Well, it seems I might have found one. Here's the link:
http://www.cablejive.com/istubz
And it comes in black too, so it's less obvious then the Apple white!
Jayde is offline   Reply With Quote
The Following 2 Users Say Thank You to Jayde For This Useful Post:
Dadhawk (06-03-2012), RMStringer (01-03-2013)
Old 05-26-2012, 02:13 PM   #38
civicdrivr
civicdrivr's Avatar
Drives: 2018 Golf R
Nice find. Looks just long enough to be able to stuff the ipod in the little pocket in the dash.
Parting out HERE
civicdrivr is offline   Reply With Quote
Old 06-12-2012, 12:07 PM   #39
cmspooner
cmspooner's Avatar
Drives: 2013 SWP Limited BRZ - Manual
Any idea on how large of a drive the stereo can read?
cmspooner is offline   Reply With Quote
Old 06-12-2012, 01:21 PM   #40
sure74
sure74's Avatar
Drives: 2016 Toyota 4Runner Trail Premium
How about using the outlet in the glovebox to supply power only to the console usb port for charging and redirect the usb from the back of the unit to the iPod?
Should only need a [ame="http://www.amazon.com/Griffin-Powerjolt-Dual-Universal-Micro/dp/B0042B9U8Q/ref=sr_1_1?rps=1&ie=UTF8&qid=1339521041&sr=8-1"]generic USB charger[/ame] for the outlet, a [ame="http://www.amazon.com/Cables-Go-28106-Cable-Meter/dp/B000R4L4CM/ref=sr_1_1?s=electronics&rps=1&ie=UTF8&qid=1339521 083&sr=1-1"]USB A m to m cable[/ame] and a [ame="http://www.amazon.com/USB-Adapter-Female-To/dp/B000BSHJK0/ref=sr_1_11?ie=UTF8&qid=1339521512&sr=8-11"]A Female/B Female Adapter[/ame] to get the console live.
Should only need a [ame="http://www.amazon.com/SANOXY-USB-Female-Male-Adapter/dp/B000GHUIF4/ref=sr_1_2?ie=UTF8&qid=1339521406&sr=8-2"]A Female to B Male Adapter[/ame] plus the cable from the iPod to get that going.
That should solve both issues.
sure74 is offline   Reply With Quote
The Following User Says Thank You to sure74 For This Useful Post:
Dadhawk (06-12-2012)
Old 06-12-2012, 01:39 PM   #41
Should only need a generic USB charger for the outlet, a USB A m to m cable and a A Female/B Female Adapter to get the console live.
Should only need a A Female to B Male Adapter plus the cable from the iPod to get that going.
Most excellent idea! You win a Hawk Feather Of The Day for that one! I'll have to give that careful consideration.
Old 06-12-2012, 05:22 PM   #42
jdrxb9
jdrxb9's Avatar
FYI, I got the 7cm 'iStubz' and found it to be too short to nicely reach a 4th gen ipod nano in the cubby.
I added one of these: http://www.angledcables.com/usb-20-e...le--4-inc.html and it is better, but still not perfect.
I also think the re-route suggested by sure74 sounds like a good idea.
The Following User Says Thank You to jdrxb9 For This Useful Post:
Jayde (06-12-2012)
NAV Radio suggestions Dadhawk Electronics | Audio | NAV | Infotainment 20 07-31-2013 02:25 PM
Aha Radio in the Subaru BRZ Chronogps BRZ First-Gen (2012+) — General Topics 3 02-21-2012 05:52 PM
Aha Radio Streaming to BRZ borge12 BRZ First-Gen (2012+) — General Topics 25 01-18-2012 09:47 AM
does this car get a radio/CD player ? beirouty Electronics | Audio | NAV | Infotainment 12 12-03-2011 11:06 PM
No AC/Radio option? blur Scion FR-S / Toyota 86 GT86 General Forum 53 04-10-2010 06:54 AM
