#29 | |
| The Following User Says Thank You to Ultramaroon For This Useful Post: | Dream20b (12-26-2015) |
#30 |
Y u do dis?
this is a dumb question but which fuse goes to the maf sensor? What's it labled?
Dat Hot Lava Doe
Clearly you have no clue what you are talking about. Everything you said was completely and utterly the ramblings of a babbling idiot regurgitating garbage from his mouth. Everyone here is now dumber from reading your post. Please die now. |
#31 | |
If the red wire is cut and was shorted to ground, yes, that fuse will have blown.
| The Following User Says Thank You to Ultramaroon For This Useful Post: | Dream20b (12-28-2015) |
#32 |
Y u do dis?
Fuse was indeed blown, Also, Fixed. Swapped fuse, wrapped wires in electrical tape, will update when new belt purchased.
Dat Hot Lava Doe
#33 |
Great catch!
| The Following User Says Thank You to Ultramaroon For This Useful Post: | Dream20b (12-30-2015) |
#34 |
Y u do dis?
Buying belt tomorrow.
Dat Hot Lava Doe
#35 |
AutoX-10/10ths every run
I ended up using a piece of smaller diameter coolant hose to create a sheath for the MAF sensor cable harness to protect it from shredding belts on mine. Cut it down the center lengthwise and use a large zip tie at either end to anchor it to something fixed.
| The Following User Says Thank You to whataboutbob For This Useful Post: | Dream20b (12-31-2015) |
#36 |
Y u do dis?
belt has been purchased, And I found that the original anchor was broken so i bought one of those too
Dat Hot Lava Doe
#37 |
Y u do dis?
Update...
Car flickers lights when attempting to start, doesn't start, but cranks. Lights solid in on position.
Dat Hot Lava Doe
#38 | |
Drives: FT86
If you have a voltmeter get someone to keep an eye on battery volts when you crank it should be able to maintain arroind 12v if its dipping to 10 or something then its low or stuffed. Also rescan for error codes, car wont usually start if maf sensor damaged or not connected same with map sensor. |
| The Following 2 Users Say Thank You to steve99 For This Useful Post: | Dream20b (12-31-2015), Ultramaroon (01-01-2016) |
#39 |
Y u do dis?
Car runs and drives after new battery. Charging did nothing
Dat Hot Lava Doe
| The Following 2 Users Say Thank You to Dream20b For This Useful Post: | steve99 (01-01-2016), Ultramaroon (01-01-2016) |
| installing sensor/adapter for oil temp and pressure - how? | pcuerpo | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 20 | 06-29-2018 06:40 AM |
| Where BRZ ATM pressure sensor?? | silviahrc | Engine, Exhaust, Transmission | 3 | 12-12-2015 03:28 AM |
| Beta Testers Wanted- Fuel Pressure Sensor | GSpeed | Tracking / Autocross / HPDE / Drifting | 5 | 08-16-2015 04:03 PM |
| Oil pressure and Oil Temp sensor - where did you mount them and how | philooo | Engine, Exhaust, Transmission | 11 | 05-29-2015 02:41 AM |
| DI pressure sensor calibration? - standalone | ElectronSpeed | Engine, Exhaust, Transmission | 0 | 02-27-2013 11:38 PM |
