Old 04-17-2015, 10:44 PM   #15
wparsons
wparsons's Avatar
Originally Posted by Maxwell View Post
I read your post. I cannot assume what you said is correct without proof.
Go read it again...
Originally Posted by wparsons
I don't think anyone has 100% confirmed, but the consensus is that both cars got new shocks but the spring rates are unchanged.
I'm never going to confirm it because I've already said that I don't think anyone has 100% confirmed it.
If you want a definite answer, call your local dealership and ask about part numbers between 2013/2014 and 2015.
flickr
Old 04-24-2015, 01:17 PM   #16
Hyper4mance2k
Alexandrino_Auto
Hyper4mance2k's Avatar
Drives: series.Blue
So I looked up the part numbers and Subaru lists the same shock number for 2013-2015 (20310 Front & 20365 rear); however, I just replaced my 2014 Limited with a 2015 S.B, and they drive totally different. The 2015 feels much better dampened. It's not nearly as bouncy. In fact it's so much better that my Bilsteins and Swift Spec R's are just sitting in a box for the time being. I'm not even going to bother installing them until I know I'm headed to the track.
edit: it could also be that my S.B only has 8k on it and my Ltd was approaching 24k when I swapped to Bilsteins.
The Shadetree Project: I turn wrenches
Hyper4mance2k is offline   Reply With Quote
Old 04-24-2015, 02:20 PM   #17
cdrazic93
Junior
cdrazic93's Avatar
Drives: a car
DEAR GOD SIR, may i trouble you for some shock dynos? Im sure RCE would be more than willing to troubleshoot that for you
Old 04-24-2015, 02:37 PM   #18
Hyper4mance2k
Alexandrino_Auto
Drives: series.Blue
There's nothing to troubleshoot. I'm just noting that my 2015 rides better than my 2014. I commute 130 miles a day, so a decent ride is important. I'm not saying the Bilsteins are bad, but they're not as comfortable as stock on long trips.
The Following User Says Thank You to Hyper4mance2k For This Useful Post:
Mr.Impreza (01-21-2016)
Old 04-24-2015, 02:39 PM   #19
cdrazic93
Junior
cdrazic93's Avatar
Drives: a car
There's nothing to troubleshoot. I'm just noting that my 2015 rides better than my 2014. I commute 130 miles a day, so a decent ride is importnat. I'm not saying the Bilsteins are bad, but they're not as comfortable as stock on long trips.
Its hard to imagine the variance in the new shocks for rebound and compression, it could be one of those OEM+ upgrades people look for knowing the dyno graph.
Old 04-24-2015, 02:50 PM   #20
ryoma
ryoma's Avatar
I always felt that my 2015 BRZ rode extremely well. It was my first BRZ so I couldn't compare it to any others, but I felt that the suspension was extremely firm and not bouncy at all. I was surprised at how firm it was from the factory, it was almost as good as my old MR2 with GC coils and Koni's. The handling was similar to my brother's STI on Feals. though, I haven't really pushed the car to its limits and will check that out next month at the track.
Old 04-28-2015, 02:19 AM   #21
Naco
Naco's Avatar
Drives: 2015 Steel FR-S MT
From my understanding, it was just the FRS front struts that were changed to be the BRZ spec struts. Toyota wanted to remove some of the tail-happiness that the 2012-14 models had.
As far as adding TRD springs to a '15, I would indeed be a bit wary. The TRD springs were designed to work with the older front struts (read: less dampening). This is why Swift had FRS Spec and BRZ Spec springs for the '12-14 models. The '15 front struts will work well with anything that was BRZ specific or was applicable to both cars (RCE, RSR, etc).
17x9 RPF1 wrapped in 245/40 RE-71R = Mo Low Required
Naco is offline   Reply With Quote
Old 04-28-2015, 02:54 AM   #22
Hyper4mance2k
Alexandrino_Auto
Drives: series.Blue
You, sir, are incorrect. The FRS & BRZ have the same dampers, they had different front spring rates. Way to infer what the manufacturer does based on casual observation of the aftermarket. Correlation does not imply causation.
Panman (05-01-2015)
Old 04-28-2015, 07:57 AM   #23
wparsons
wparsons's Avatar
^^ Slight correction, both spring rates were different between FRS and BRZ's.
FRS F/R: 2.3k/3.8k
BRZ F/R: 2.7k/3.5k
I found with the stock springs the car was over damped, especially up front. It really feels like they went a bit heavy on the damping even with the stiffer of available rates, and since they shared damping rates it needs to work with both the spring rates.
flickr
Old 04-28-2015, 04:06 PM   #24
Hyper4mance2k
Alexandrino_Auto
Drives: series.Blue
It's not a correction, it's an addition to my statement. I never made the claim that the rears weren't different. I was just letting him know the error in his ways because I'm constantly shocked at the amount of misinformation posted on this site, despite the correct information being posted 2 clicks away.
wparsons (04-28-2015)
Old 05-01-2015, 12:23 AM   #25
Maxwell
Maxwell's Avatar
Drives: 2015 Subaru BRZ Limited 6MT
The TRD springs are not shown to be compatible with the 2015 FR-S on Toyota's official parts site. I find that odd due to the fact that the 2015 RS 1.0s have TRD springs installed.
Maxwell is offline   Reply With Quote
Old 05-01-2015, 12:32 AM   #26
AustinG
Drives: '15 Halo FR-S, '95 240SX Turbo
The TRD springs are shown to be compatible with the 2015 FR-S on Toyota's official parts site. I'm wary about putting them on my 2015 BRZ.
I recently became friends with someone who has the TRD springs on his BRZ. He's happy with them, however he has a 2014 model.
I may be wrong, but I thought the 2015 RS 1.0's had the TRD springs installed already.
AustinG is offline   Reply With Quote
Old 05-01-2015, 12:34 AM   #27
Maxwell
Maxwell's Avatar
Thumbs up
They do.
Old 05-01-2015, 12:36 AM   #28
AustinG
Whoops. Totally read this as FRS. -___-
suspension springs struts
2013 VS 2015 BRZ Suspension changes fasteddy Suspension | Chassis | Brakes -- Sponsored by 949 Racing 28 03-30-2017 04:07 PM
2015 Engine differences nikitopo Engine, Exhaust, Transmission 112 02-15-2016 06:27 PM
Anyone have specs on differences btw 2014 and 2015 FR-S jeepmor Suspension | Chassis | Brakes -- Sponsored by 949 Racing 0 09-25-2014 04:54 AM
Two reviews of the 2015 up - handling differences noted Sport-Tech Scion FR-S / Toyota 86 GT86 General Forum 56 08-13-2014 01:22 PM
Quantitative report of BRZ/GT86 suspension differences Sport-Tech BRZ First-Gen (2012+) — General Topics 48 05-19-2013 01:00 PM
