#15 | ||
If you want a definite answer, call your local dealership and ask about part numbers between 2013/2014 and 2015.
#16 |
Alexandrino_Auto
Drives: series.Blue
So I looked up the part numbers and Subaru lists the same shock number for 2013-2015 (20310 Front & 20365 rear); however, I just replaced my 2014 Limited with a 2015 S.B, and they drive totally different. The 2015 feels much better dampened. It's not nearly as bouncy. In fact it's so much better that my Bilsteins and Swift Spec R's are just sitting in a box for the time being. I'm not even going to bother installing them until I know I'm headed to the track.
edit: it could also be that my S.B only has 8k on it and my Ltd was approaching 24k when I swapped to Bilsteins.
The Shadetree Project: I turn wrenches
#17 | |
Junior
Drives: a car
#18 |
Alexandrino_Auto
Drives: series.Blue
There's nothing to troubleshoot. I'm just noting that my 2015 rides better than my 2014. I commute 130 miles a day, so a decent ride is important. I'm not saying the Bilsteins are bad, but they're not as comfortable as stock on long trips.
#19 |
Junior
Drives: a car
Its hard to imagine the variance in the new shocks for rebound and compression, it could be one of those OEM+ upgrades people look for knowing the dyno graph.
#20 |
I always felt that my 2015 BRZ rode extremely well. It was my first BRZ so I couldn't compare it to any others, but I felt that the suspension was extremely firm and not bouncy at all. I was surprised at how firm it was from the factory, it was almost as good as my old MR2 with GC coils and Koni's. The handling was similar to my brother's STI on Feals. though, I haven't really pushed the car to its limits and will check that out next month at the track.
#21 |
Drives: 2015 Steel FR-S MT
From my understanding, it was just the FRS front struts that were changed to be the BRZ spec struts. Toyota wanted to remove some of the tail-happiness that the 2012-14 models had.
As far as adding TRD springs to a '15, I would indeed be a bit wary. The TRD springs were designed to work with the older front struts (read: less dampening). This is why Swift had FRS Spec and BRZ Spec springs for the '12-14 models. The '15 front struts will work well with anything that was BRZ specific or was applicable to both cars (RCE, RSR, etc).
17x9 RPF1 wrapped in 245/40 RE-71R = Mo Low Required
#22 | |
Alexandrino_Auto
Drives: series.Blue
#23 |
^^ Slight correction, both spring rates were different between FRS and BRZ's.
FRS F/R: 2.3k/3.8k BRZ F/R: 2.7k/3.5k I found with the stock springs the car was over damped, especially up front. It really feels like they went a bit heavy on the damping even with the stiffer of available rates, and since they shared damping rates it needs to work with both the spring rates.
#24 |
Alexandrino_Auto
Drives: series.Blue
It's not a correction, it's an addition to my statement. I never made the claim that the rears weren't different. I was just letting him know the error in his ways because I'm constantly shocked at the amount of misinformation posted on this site, despite the correct information being posted 2 clicks away.
#25 | |
Drives: 2015 Subaru BRZ Limited 6MT
#26 | |
Drives: '15 Halo FR-S, '95 240SX Turbo
I may be wrong, but I thought the 2015 RS 1.0's had the TRD springs installed already. |
#27 |
#28 |
| Tags |
| suspension springs struts |
| 2013 VS 2015 BRZ Suspension changes | fasteddy | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 28 | 03-30-2017 04:07 PM |
| 2015 Engine differences | nikitopo | Engine, Exhaust, Transmission | 112 | 02-15-2016 06:27 PM |
| Anyone have specs on differences btw 2014 and 2015 FR-S | jeepmor | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 0 | 09-25-2014 04:54 AM |
| Two reviews of the 2015 up - handling differences noted | Sport-Tech | Scion FR-S / Toyota 86 GT86 General Forum | 56 | 08-13-2014 01:22 PM |
| Quantitative report of BRZ/GT86 suspension differences | Sport-Tech | BRZ First-Gen (2012+) — General Topics | 48 | 05-19-2013 01:00 PM |
