Old 08-02-2014, 05:01 AM   #1
Sport-Tech
Sport-Tech's Avatar
Drives: TBD
Exclamation Two reviews of the 2015 up - handling differences noted
Both Autoguide and Autoweek have just posted reviews of the 2015 FR-S - some journos were invited out to the Streets of Willow for a run. They were allowed to drive the '14 and '15 back to back to clarify the changes made to the handling, which they report being quite noticeable. It looks like the '15 has been tuned to be closer to the BRZ setup, giving less mid-corner oversteer and more overall neutrality, with initial understeer being more evident.
Sport-Tech is offline   Reply With Quote
The Following 4 Users Say Thank You to Sport-Tech For This Useful Post:
Fly Guy (08-03-2014), MrAmalto (08-03-2014), nzer (08-02-2014), Ubersuber (08-02-2014)
Old 08-02-2014, 06:53 AM   #2
FRSpappa
FRSpappa's Avatar
Drives: 2014 FR-S Whiteout
Glad I got a 2014, didn't want another under steering car like my old FWD CRX Si...
FRSpappa is offline   Reply With Quote
The Following 2 Users Say Thank You to FRSpappa For This Useful Post:
Chad86 (08-02-2014), yo joshman (08-05-2014)
Old 08-02-2014, 07:12 AM   #3
Superhatch
AIM4APX
Superhatch's Avatar
Drives: 2013 WRB BRZ Limited
We are able to charge harder into the corners in the 2015 FR-S, and if we came in a little too hot, the car would simply understeer (try to go straight) and scrub off speed. A little corrective footwork and we'd be on our way again. The retuned FR-S drives more like a traditional sports car, and felt significantly faster around the track than the 2014 model like its BRZ near-twin, which never had the FR-S' tail-happy nature.
For overall track work, the 2015 becomes a far sharper scalpel.
The 2015 FR-S preserves its tail-happy character, but now it only breaks loose when you really want it to -- not when you're, say, in second gear and trying to concentrate while winding around the tricky, sweeping esses at the back of Streets of Willow, or after climbing the hill and braking hard for the tight, bumpy right-hander. Through these turns, the throttle is easier to modulate.
Sounds like nothing but good changes imo. Unless drifting around every corner in your subdivision was your thing.
"It's very difficult to present technology as an overtly positive sales device to people who want an emotional car" -Chris Harris
Superhatch is offline   Reply With Quote
The Following 4 Users Say Thank You to Superhatch For This Useful Post:
Ashybone (08-12-2014), B L U E S L A T E (08-02-2014), chanomatik (08-13-2014), Rampage (08-02-2014)
Old 08-02-2014, 07:18 AM   #4
s2d4
s2d4's Avatar
What was the actual change? couple of bolts?
Old 08-02-2014, 07:31 AM   #5
Juvenile
Juvenile's Avatar
Drives: 86 GTS
Correct, bigger bolts
Old 08-02-2014, 07:57 AM   #6
jvincent
jvincent's Avatar
They also changed the spring rates in the front and there are different shocks/struts.
Old 08-02-2014, 08:11 AM   #7
DarkSunrise
DarkSunrise's Avatar
Originally Posted by Autoweek
The change is drastic.
This talk of "drastic" handling differences worries me. I'd be fine with slight changes, but anything more than that and I doubt I'd like it.
Personally I always felt the FR-S balance was spot on from the factory. The car was playful on the street with stock all-season Turanzas. And with stickier summer tires, the balance feels really good on the track.
Different damping as well, from what I understand.
2022 BRZ Build
2013 FR-S Build
The Following 3 Users Say Thank You to DarkSunrise For This Useful Post:
Chad86 (08-02-2014), Juvenile (08-02-2014), Pseud0logik (08-12-2014)
Old 08-02-2014, 08:31 AM   #8
wbradley
Sarcastic SOB
wbradley's Avatar
Firmer front springs, different brand of dampers, changed bolts in the front. Sounds like they made it less driftable.
Could be they are seeing consumers moving to the Subaru more or just that they are being conservative again as Toyota usually is. Might be a better calibration for people adding FI for stability and for a fastest lap time perspective.
I still enjoy the playfulness of my ‘13 at its current power level.
On initial release of the twins I think Toyota chose the slight oversteering bias to emphasize the novelty and uniqueness in the market of a non-understeering vehicle. Now the model was due for a mid cycle refresh and this is what was settled on by committee.
I predict the original FR-S will hold a place similar to the original Mata as far as longterm desirability.
Old 08-02-2014, 08:48 AM   #9
BlueDubbinTDI
BlueDubbinTDI's Avatar
Drives: 2013 FR-S, 2012 MCS
Everyone is just gunna drop it on coils anyway who gives a fuck
The Following 13 Users Say Thank You to BlueDubbinTDI For This Useful Post:
akyp (08-02-2014), Ashybone (08-12-2014), boonFRS (08-03-2014), CAMBAM_6 (08-12-2014), campy (08-02-2014), Creole (08-03-2014), FRSBRZGT86FAN (08-03-2014), Liebot (08-03-2014), PHLonomenal (08-02-2014), Sideways&Smiling (08-02-2014), Superhatch (08-02-2014), Thornley (08-02-2014), VeezyF (08-16-2014)
Old 08-02-2014, 09:11 AM   #10
campy
No rice, no life
campy's Avatar
Drives: 2013 Asphalt FR-S
It is.
And isn't that the point of this car? It's supposed to be a bit loose and crazy. It was designed to be fun, and the excessive tail-happiness is part of that. I'm sure the 2015 can get faster lap times than the 2013, but is it coming at the cost of making this a more civilized, less silly car? If there's one thing I've learned from racing, it's that the fastest lap times feel the slowest.
If I want the best lap times, I'd get a Porsche or a Miata. If I want a fun everyday car that's still very competent on the track or autocross, I'll pick the FRS.
campy is offline   Reply With Quote
The Following 9 Users Say Thank You to campy For This Useful Post:
Ashybone (08-12-2014), Bristecom (08-02-2014), HI (08-02-2014), MrAmalto (08-02-2014), PHLonomenal (08-02-2014), stock (08-03-2014), Superhatch (08-02-2014), tennisfreak (08-02-2014), xxBrun0xx (08-12-2014)
Old 08-02-2014, 09:35 AM   #11
jamomatt
jamomatt's Avatar
Drives: Toyota 86
Yup. Those who are just going to use it as a street car probably couldn't care less. Those that need it for more are gonna change to coilovers anyway.
jamomatt is offline   Reply With Quote
Old 08-02-2014, 09:59 AM   #12
PHLonomenal
PHLonomenal's Avatar
Drives: Whiteout 2014 Scion FR-S
I actually don't know what to make of these changes. Seems like they're trying to dial out what brought us all here. IDK, some ppl will love the new and others will covet the old. Time will only tell how these model years will be regarded by enthusiasts.
I had an M3 once...and barely missed it. Barely
"what I'm driving here...is an ending." Jeremy Clarkson
PHLonomenal is offline   Reply With Quote
The Following User Says Thank You to PHLonomenal For This Useful Post:
Chad86 (08-02-2014)
Old 08-02-2014, 10:02 AM   #13
ZionsWrath
Thanks
ZionsWrath's Avatar
What brought me here was a functional trackable street car. OEM decent handling. Relative light weight. RWD. Functional interior (fold flat seats) for going to track.
In fact I think I searched something like "4cyl rwd coupe fold flat seats" before this car was released and brought me to the concept.
Being sideways on every roundabout was not on my priority list.
Old 08-02-2014, 10:03 AM   #14
Dezoris
Dezoris's Avatar
95% of the owners of this car wont be able to tell the difference as the changes are mostly noticable at the limit.
The Following 5 Users Say Thank You to Dezoris For This Useful Post:
continuecrushing (08-12-2014), Kido1986 (08-02-2014), Mad1723 (08-03-2014), P@ul (08-03-2014), strat61caster (08-03-2014)
Nissan to enter 2015 24 Hours of Le Mans + 2015 FIA WEC mav1178 Other Vehicles & General Automotive Discussions 1 05-23-2014 10:47 PM
Best handling car? gt8613 FR-S / BRZ vs.... 154 10-07-2013 09:57 PM
brz ,frs differences nickr Suspension | Chassis | Brakes -- Sponsored by 949 Racing 5 08-27-2013 10:12 AM
A Testimony To The FR-S's Handling skoodge Scion FR-S / Toyota 86 GT86 General Forum 25 06-08-2012 06:36 AM
CDN vs US FR-S differences Sport-Tech CANADA 77 04-19-2012 02:24 PM
