Old 04-21-2015, 01:18 PM   #15
brandonblt2
The Stig's African Cousin
brandonblt2's Avatar
Drives: 2014 wrb brz
Originally Posted by HueyLooie View Post
You guys are awesome!
I suppose i would like to go with the lowering springs option since that seems to be the common suggestion! An inch or two is preferrable, but no more. Can we achieve 2 inches you think? I run a front lip spoiler and side skirts...fyi.
What do lowering springs cost, usually?
What is this wheel gap you speak of? Is that the gap above the wheel and the fender?
And if so, yes, it is what im interested in.
Over an inch and a half puts a lot of stress on your stock struts when just using springs that would lead to needing to replace your struts sooner. So if you want a 2inch drop you would need coilovers. And yes that's what the wheel gap is.
Instagram: brandonblt2
Build Thread: http://www.ft86club.com/forums/showt...86#post2219386
Flickr: brandonblt567
brandonblt2 is offline   Reply With Quote
Old 04-21-2015, 01:28 PM   #16
Jyn
Noob
Jyn's Avatar
Drives: FR-S Mammogram
This thread was worth it based on the OP's response. +1 for you.
Jyn is offline   Reply With Quote
The Following User Says Thank You to Jyn For This Useful Post:
meWant (04-21-2015)
Old 04-21-2015, 01:29 PM   #17
G-awesome
Drives: 2015 Firestorm Scion FRS
just go with lowering springs. It's a cheaper solution compared to coilovers. It'll lower the car from 1" to 1.5" which will close the gap between the fender and wheel. A popular one is the Eibach pro springs kit. Bear in mind you have a front lip and sideskirts so you'll lose even more ground clearance if you lower the car by an inch or two
G-awesome is offline   Reply With Quote
Old 04-21-2015, 04:02 PM   #18
SpeedWi
SpeedWi's Avatar
Drives: 2014 BRZ (SOLD)
Agreed!
Supercharged 2014 DGM Limited
SpeedWi is offline   Reply With Quote
Old 04-21-2015, 04:18 PM   #19
wparsons
wparsons's Avatar
2" is really slammed. You should look at threads to see what look you're after, then get the same amount of drop. There's less than 5" of ground clearance stock, so 2" is almost cutting that in half.
flickr
Old 04-21-2015, 04:23 PM   #20
stevesnj
stevesnj's Avatar
TRD lowering springs, 1" lower and warranty safe.
My 2016 Build thread
The Following User Says Thank You to stevesnj For This Useful Post:
Tcoat (04-21-2015)
Old 04-21-2015, 06:43 PM   #21
HueyLooie
Drives: Scion
Ok we're all good mike. Water under the bridge. I see where you're coming from. Thanks for all the replies all.
HueyLooie is offline   Reply With Quote
Old 04-21-2015, 07:12 PM   #22
vividracing
vividracing's Avatar
Like what others said, lowering springs would be good for you. I have H&R lowering springs and they dropped my car 1" in the front, 1.2" in the back. I love the look but I think I may want to get coilovers to drop it another .5" or so, just for my preferences. It's low but not low enough for me haha.
If you do normal street driving, just be aware that you WILL scrape on some things, and when you park, make sure to stop before the curb or you'll hit it. Same goes for big speed bumps and driveways.
You will have to learn to take such things at an angle instead of straight on, and slow down to get over it as well.
vividracing is offline   Reply With Quote
Old 04-21-2015, 07:17 PM   #23
Marcoscrdo
Marcoscrdo's Avatar
Drives: 13' DGM Built FBM BRZ
Just save for coilovers so it is adjustable and you will be able to run aftermarket wheels.. Ive heard from many owners with springs that after install it almost looks like stock height. Want it to be done right? Be patient and save.
Marcoscrdo is offline   Reply With Quote
Old 04-21-2015, 09:09 PM   #24
Celadrielas
Celadrielas's Avatar
Drives: 2013 Asphalt Fr-S
On wednesday nights we have anywhere from 5-30 of us here local to AZ -- you could ask several of them how they lowered and choices they made and why. We have everyone ranging from the "Casual driver" to the "Spirited" driver and even the "I race weekends" drivers. check our sub forum for details
Old 04-21-2015, 09:15 PM   #25
wparsons
wparsons's Avatar
Coilovers aren't automatically better, not by a long shot. You can easily run aftermarket wheels without coilovers, you just can't run stupidly wide wheels/tires up front. For street use, there's no need to run anything more than 215's or 225's anyway.
Adjustable doesn't mean better, and too many adjustments make it very easy to make it handle/drive worse if you don't know what you're doing.
This is an honest 1" drop on Swift sport springs, verified by measuring fender to hubs (not digging up those pictures, you'll have to trust me).
flickr
Old 04-21-2015, 09:42 PM   #26
dirtymax
Gold Member
dirtymax's Avatar
Drives: 14' SWP BRZ MT limited
http://www.ft86club.com/forums/showthread.php?t=18661
this should give you an idea on what you are looking for. lots of cheap drop springs and cheap rims
dirtymax is offline   Reply With Quote
Total windshield washer amt? SteveGrillo BRZ First-Gen (2012+) — General Topics 21 03-04-2022 10:21 AM
Navdy, a soccer mom device that could eventually be used for track purposes ? Simon99 Electronics | Audio | NAV | Infotainment 2 09-03-2014 01:25 AM
Aesthetic question bdanisi Cosmetic Modification (Interior/Exterior/Lighting) 7 12-31-2012 05:33 PM
total noob with boxer engine NickDude84 Engine, Exhaust, Transmission 35 04-27-2012 08:51 PM
Total noob tire-change question Sport-Tech Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 38 04-17-2012 07:15 PM
