Old 02-22-2013, 09:29 PM   #1
SteveGrillo
Drives: Brz
Total windshield washer amt?
Ran out of washer fluid today, and bought a gallon to add. Added it, and have no idea what the volume is, since it seems like it could take more.
What's the size??
SteveGrillo is offline   Reply With Quote
Old 02-22-2013, 09:48 PM   #2
GNS
Drives: .
Pour until it overflows
GNS is offline   Reply With Quote
Old 02-22-2013, 10:40 PM   #3
dem00n
Member of the year - 2016
dem00n's Avatar
Drives: Scion FRS
You should work at a bar.
Old 02-22-2013, 10:43 PM   #4
Draco-REX
Corner Junkie
Draco-REX's Avatar
Drives: 13 BRZ, 11 STI, 99 RS
What's the size??
Over 1 gallon... maybe 4 liters? It holds more than any car I've owned. Surprised me when I emptied an entire bottle into it one day.
Old 02-22-2013, 11:41 PM   #5
TommyFive
Drives: 2013 WRB BRZ-P, 2002 Focus LX
Easily the biggest annoyance of my Focus is that it holds less than 1 gallon. I buy a bottle of washer fluid, and for a month after I have the remaining 1/8th of the bottle sloshing around in my trunk.
Knowing the BRZ in my future deals with this problem makes me very happy.
TommyFive is offline   Reply With Quote
Old 02-23-2013, 08:34 AM   #6
BRZfan
BRZfan's Avatar
Drives: 2013BRZ Premium St Silver Metallic
Originally Posted by TommyFive View Post
Easily the biggest annoyance of my Focus is that it holes less than 1 gallon. I buy a bottle of washer fluid, and for a month after I have the remaining 1/8th of the bottle sloshing around in my trunk.
From what I have read regarding the 'less than one gallon capacity' of the washer fluid is that it was designed that way so that one always had an"emergency" amount left over. This 'design' attribute may vary from one car to another. OR, of course, it might just simply be because of space limitations.
BRZfan is offline   Reply With Quote
Old 02-23-2013, 08:55 AM   #7
Hardrock4445
Hardrock4445's Avatar
Only add .5 gallon, because racecar!
Mods: Perrin CAI, JDL EL header, DC sports Catless front pipe, top speed auto pro-1 cat-back, H&R sport line springs, Headlight blackout, "Demon eyes"
Hardrock4445 is offline   Reply With Quote
Old 02-23-2013, 08:59 AM   #8
SteveGrillo
Drives: Brz
I wonder if it is 4 liters. I looked again in the manual and it is not obvious. If anyone finds it, I'd love to know. Of course (if I had a spare gallon) I could add more until it overflows!
Old 02-23-2013, 12:25 PM   #9
SloS13
Drives: 2013 FR-S whiteout
You might be enthusiastic about your new car if - you post on a forum asking your windshield washer capacity.
SloS13 is offline   Reply With Quote
Old 02-23-2013, 07:40 PM   #10
jmaryt
Drives: 2012 honda civic ex
yes! "three finger" shots every time!
jmaryt is offline   Reply With Quote
Old 02-24-2013, 02:58 AM   #11
ashtray
As Seen On The Internet
Drives: 2003 WRX, 2013 BRZ, 442
So I have a 3l jug and a 5l jug but I need to fill the windshield washer tank to exactly 4l or else it will explode. What to do?! :p
Actually that it has over a gallon tank surprises me. When car companies try to make a car light as possible they can go to extremes by making the bolts as short as needed, wiring harnesses with no extra slack, lightweight battery, lighter rims, etc. The easiest thing to do would be to put in a 1/2l tank for washer fluid! 4l tank - they're not even trying for lightweight! (car also has a spare tire and tools - though located at the rear and low down, so it's not a bad thing really)
But how big is the tank? Who cares. You put a gallon in. You know you have a gallon of washer fluid to use! Could have a 7 gallon tank - doesn't mean I'd fill it. 1 gallon should last you a while, even through winter.
As for the person with 1/8th a bottle sloshing around in their trunk - do you live out of your car? Can you not put it next to the windex bottle under your kitchen sink? Do you not realize you can top off the tank after you've used the washer a few times and don't need to wait until its empty to refill?
Oh, and - #firstworldproblems. :p
ashtray is offline   Reply With Quote
Old 02-24-2013, 07:10 AM   #12
BRZfan
BRZfan's Avatar
ASHTRAY asks:
I believe this is a simple arithmetic challenge.
Given that the the reservoir tank is empty.
Given that the tank capacity is 4l.
Given that both containers are full totaling 8l.
Given that one has no other empty containers.
You then have have enough for two fills. (2 X 4l)
One solution would be:
Fill the tank with just about half of the 5l container and continue to fill the 5l container, little by little, with the 3l container until the three gallon container is empty. You should then have 4l in the tank and 4l in the 5l container for the next fill.
Old 02-24-2013, 05:14 PM   #13
rhoyle
Drives: BRZ SWP 6MT
1. Fill 3L container
2. pour contents of 3L container in reservoir
3. Fill 3L container
4. Pour contents of 3L container in 5L container
5. Fill 3L container
6. Pour 3L container into 5L container until full
7. Pour remaining 1L into reservoir
8. Marvel at your problem solving skills.
rhoyle is offline   Reply With Quote
Old 02-24-2013, 05:36 PM   #14
rhoyle
Drives: BRZ SWP 6MT
Originally Posted by BRZfan View Post
ASHTRAY asks:
"Just about half" will get you blown up!
Washer Mod? 636 Engine, Exhaust, Transmission 64 02-20-2018 04:08 PM
Robispec total cooling solution group buy robispec Groupbuys 103 11-21-2013 12:41 PM
Dealers only getting 7 cars total this year? Chauntalei BRZ First-Gen (2012+) — General Topics 23 05-13-2012 09:54 PM
total noob with boxer engine NickDude84 Engine, Exhaust, Transmission 35 04-27-2012 08:51 PM
Total noob tire-change question Sport-Tech Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 38 04-17-2012 07:15 PM
