Northwest AK, ID, OR, WA
Old 03-16-2015, 01:12 PM   #15
sachu
Drives: rocketship
looks like the RE-11A is being phased out for the RE71R
sachu is offline   Reply With Quote
Old 03-17-2015, 12:11 AM   #16
Rio
Rio's Avatar
Drives: 2014 Scion FR-S ハチ
MPSS!
Rio is offline   Reply With Quote
Old 03-17-2015, 01:31 PM   #17
PNW FRS
PNW FRS's Avatar
Originally Posted by RobertPaulson View Post
I like my michelin pilot super sports, great in wet, phenomenal in dry, and then i run a winter tire on my stock wheels for the 2-4 months we see under 40 weather all time and the odd snow.
another capable tire for our winters is the continental DWS which i run on my second car year around and used to run on my mazdaspeed3 in the winters. more than capable enough to get through an inch or two.
I too run Mich Pilot S.S., and when temps got down to mid-to-high 20's this winter... I ventured out on these tires just to see how they would hold up... and surprisingly.. they did OK considering the temperature. On some sections of roads that had a little icing.. there was the fun "breaking loose" sensation which some careful throttle/steering control (maybe even the rigs TC too) took care of.
So, I didn't end up getting a set of Blizzaks (which I run on my IS 300). Kind of a roll of the dice, but I had the IS to use as backup in case the Pilots didn't work out.
Anyway... bottom line.. not too bad in wet and cold... and of course.. superb in warmer temps (wet or dry).
Edit: BTW.. when it's below 35-40 deg. F.... it is pretty evident that the compound has hardened up on the Super Sports...
2013 Asphalt / MT
Olympia, Washington
PNW FRS is offline   Reply With Quote
The Following User Says Thank You to PNW FRS For This Useful Post:
RobertPaulson (03-17-2015)
Old 03-17-2015, 01:45 PM   #18
RobertPaulson
Hisnamewasrobertpaulson
RobertPaulson's Avatar
Drives: 2017 Golf R
yeah it was 30 this morning when i left my house and i had no issues with the drive, was even able to pass two cars on a round-a-bout.
This is your life and it's ending one minute at a time.
RobertPaulson is offline   Reply With Quote
Old 03-22-2015, 02:07 PM   #19
sachu
Drives: rocketship
Ordered a set of re71r in 245/45/17.
They are new for this year.
BRZ -> FRS Climate Controls Retrofit? kndonlee Cosmetic Modification (Interior/Exterior/Lighting) 21 05-26-2015 02:34 AM
Climate Control Issue amishdude01 BRZ First-Gen (2012+) — General Topics 32 12-17-2014 04:15 PM
Climate Control Magiclow Cosmetic Modification (Interior/Exterior/Lighting) 3 10-05-2014 05:46 AM
Engine oil viscosity for hot climate redburn86 Engine, Exhaust, Transmission 6 08-10-2014 08:11 AM
Climate control Panel for the FRS. Mrqb22 Electronics | Audio | NAV | Infotainment 6 02-13-2013 08:03 PM
