Old 06-26-2012, 01:19 PM   #1
kndonlee
BRZ -> FRS Climate Controls Retrofit?
So I really wanted to get the dual climate in my FR-S. It seems that the parts should be order-able through Subaru to be fitted with OEM quality into the FR-S.
Anyone have potentially relevant diagrams and part numbers for the dual climate control options? It was a slight loss coming from an A3, but the wifey runs in a completely different world of temperature than me...
kndonlee is offline   Reply With Quote
Old 06-26-2012, 01:59 PM   #2
MemphisR
Memphis
MemphisR's Avatar
Drives: 1989 MR2 S/C, 2014 Scion FR-S
This question has been asked about forty times already. I was one of those people... lol Just check one of the other posts. it seems like they will not be compatible due to the fact that the FR-S has no dual climate control and most likely wont work. But again check some of the other posts. You might get lucky and prove me wrong. I kinda gave up on that idea. Now I just care about BRZ headlights in an FR-S
"It's ok... It's not structural."- Mikey
MemphisR is offline   Reply With Quote
Old 06-26-2012, 03:38 PM   #3
kndonlee
Bummer.. I figured it'd have been asked a million times already. Just didn't see it. I shall search again.
The other aspect is that the JDM gt-86 has the dual climate control, so it keeps me hopeful. It might be expensive as hell to do it, but it may be possible...
Old 06-26-2012, 09:43 PM   #4
MemphisR
Memphis
MemphisR's Avatar
It would more than likely just be easier to buy a BRZ limited and then convert is to an FR-S.
Old 06-26-2012, 09:54 PM   #5
ichitaka05
Site Moderator
ichitaka05's Avatar
Drives: ichi 86 Project
This.
It takes hellova a lot more time, $ & effort to install DCC into FR-S.
It's better spent extra $2~$3k spending on BRZ
Old 06-27-2012, 09:29 PM   #6
kndonlee
This.
Bummer, I already have an FR-S...
Regardless, changing out bumper, lights, suspension is probably "easier" but I don't think DCC should be so much of a pita that it would be more effort than it is worth. From what I can think of...
Climate Control Unit
Temp Sensors
Different piping assembly
Front Button/Dash Assembly
Appropriate Wiring harnesses
As far as searching has gone, I haven't really come upon any discussions that go into the details of why DCC into the FR-S is not worth the trouble.
IMHO, DCC sounds a lot less worse than suspension, bumper + paint & matching & non-original VIN body-part + lights...
Old 06-27-2012, 09:34 PM   #7
ichitaka05
Site Moderator
ichitaka05's Avatar
Temp Sensors
It's not my words. From what Moto-san (MotoP) heard from Tada-san, it's a lot of hassle to do it.
BUT that shouldn't stop you from doing it. If you actually do, please do some write-up, so we know what, how, & $ to do it.
Old 06-28-2012, 05:15 AM   #8
kndonlee
I'll have to look into it. Anyone know someone with access to parts diagrams? Would be a much simpler task to critique with access to that information
Old 06-29-2012, 05:10 PM   #9
rcm47
rcm47's Avatar
Drives: 13’ FRS (traded), 18’ CWP BRZ tS
I cant wait to see someone do this. I believe its possible if you have the money to do it.
rcm47 is offline   Reply With Quote
Old 06-30-2012, 12:03 PM   #10
kndonlee
Yea, I need help with someone who has access to the parts diagrams so I can figure out what parts to buy and fit in. I'm thinking it could be as much of a pita as needing to replace/take apart the complete front dash and redo the piping... Or maybe if we're lucky as simple as wiring up a couple of harnesses, actuators, sensors and calling it a day.
If the chief engineer is saying that it's not worth the effort of getting DCC, then I'd presume that the effort required would be closer to the former option...
I called a local subaru dealer and they stated that they wouldn't have the parts diagrams for another 2-4 weeks... Any other Subaru dealer guys with access/information?
Old 06-30-2012, 12:09 PM   #11
kndonlee
Found someone who did it for a Mk5 VW. Looks like a complete dash tear apart is needed for the dub. I bet similar will be needed for the FRS.
http://furmanka.blogspot.com/2008/12...imatronic.html
Old 06-30-2012, 12:21 PM   #12
kndonlee
I'd also be guesstimating that the cost to do this may be in the ~1000 ish range?
I'm thinking:
$150 dash
$650 climatronic unit
$30x2 for temp sensors
$100-200 for other random pieces to complete the kit...
Old 06-30-2012, 12:46 PM   #13
Proud of BOXER
Drives: 74 Toyota Celica ST
The problem that no one has mentioned is that Subaru (who builds this car) typically makes different harnesses for different options. I had an 08 Forester XT Sports, which I wanted to add heated seats, which wasn't an option. The harnesses aren't there. I also wanted to add heated mirrors. Harness wasn't there.
So it's highly likely that you would have to completely swap the harness (THE WHOLE HARNESS, everything in the cabin) to swap over the Auto Climate Control.
Proud of BOXER is offline   Reply With Quote
Old 06-30-2012, 08:07 PM   #14
kndonlee
That would be a very unfun dual climate control addition...
Steering wheel radio controls brillo Electronics | Audio | NAV | Infotainment 6 12-26-2014 10:03 PM
Morimoto Retro-Quik Xenon Retrofit System for FR-S Xenocide117 Cosmetic Modification (Interior/Exterior/Lighting) 63 07-18-2014 07:37 PM
Auto climate control Daemione Electronics | Audio | NAV | Infotainment 37 06-05-2012 09:19 PM
Retrofit heated seats to Premium? blalor BRZ First-Gen (2012+) — General Topics 4 05-31-2012 07:50 AM
Steering wheel controls / Stock Player? StevenDavisPhoto Electronics | Audio | NAV | Infotainment 7 01-27-2012 03:18 PM
