Old 08-10-2014, 03:55 AM   #1
redburn86
Drives: red gts 86
Engine oil viscosity for hot climate
I live in Saudi Arabia the climate is hot the temp is 27°C to 41°C and in the summer it will reach 51°C. So is 0W-20 good enough for this climate because in the user manual they say 0W-20 is proper oil viscosity for the engine.
redburn86 is offline   Reply With Quote
Old 08-10-2014, 04:27 AM   #2
Captain Snooze
Because compromise ®
Captain Snooze's Avatar
Drives: Red Herring
The manual also says "SAE 0W-20 is the best choice for good fuel economy and good starting in cold weather." My bold.
It also says "An oil with a higher viscosity (one with a higher value) may be better suited if the vehicle is operated at high speeds, or under extreme load conditions"
I am suggesting that a higher viscosity would be appropriate in your situation.
Old 08-10-2014, 05:00 AM   #3
redburn86
Drives: red gts 86
Thank's I will add Mobil 1 10W-30 for the next oil change
Old 08-10-2014, 05:11 AM   #4
Captain Snooze
Drives: Red Herring
Seriously, 51°C is just crazy.
Old 08-10-2014, 06:43 AM   #5
redburn86
Drives: red gts 86
Yes seriously the summer is over I think I'm not sure when it begin and when its end but exactly at this moment the temp is 40°C
Old 08-10-2014, 06:51 AM   #6
Captain Snooze
Drives: Red Herring
Do you have an oil cooler fitted?
Old 08-10-2014, 08:11 AM   #7
Fizz
Senior Addict
Fizz's Avatar
Drives: 86 GT
A good quality 0W20 should be capable of handling high heat, but if I were you I'd be fitting an oil cooler as well.
Fizz is offline   Reply With Quote
**Best viscosity for frs and brz** 21_nola_05 Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 14 05-29-2014 11:10 AM
Is there a way to turn on climate control without the AC being on? chenshuo BRZ First-Gen (2012+) — General Topics 48 01-27-2014 01:12 PM
Oil discussion (pressure, grades, viscosity, etc) - repost from Ferrari Chat mav1178 Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 3 08-17-2013 12:46 PM
Climate control Panel for the FRS. Mrqb22 Electronics | Audio | NAV | Infotainment 6 02-13-2013 08:03 PM
Climate control bezel Surok AUSTRALIA 7 10-25-2012 05:34 AM
