Old 11-25-2014, 01:18 PM   #1
amishdude01
Drives: 14 Brz
Climate Control Issue
Hey everyone, new here. I have the dual climate control option on my BRZ. Every time I turn on the heat or cooling, my AC turns on. I cant figure out how to turn that option off. It seems like the "Auto" mode is stuck on? Any ideas? Thanks!
amishdude01 is offline   Reply With Quote
Old 11-25-2014, 01:24 PM   #2
Stang70Fastback
A.K.A. Starlord
Stang70Fastback's Avatar
Drives: 2015 Series.Blue
It's normal. Remember what "A/C" stands for (Air Conditioning, not just cooling). In this case the car is using the A/C system to de-humidify the air, which keeps the windows from fogging up. It's conditioning the air!
Stang70Fastback is offline   Reply With Quote
Old 11-25-2014, 01:28 PM   #3
amishdude01
Drives: 14 Brz
Is there a way to disable it so that every time I turn on the unit, the ac doesn't automatically come on?
Old 11-25-2014, 01:35 PM   #4
Stang70Fastback
A.K.A. Starlord
Not that I am aware without something drastic like permanently disabling the A/C system. Why don't you want it on? Are you looking for that extra few HP?
Old 11-25-2014, 01:37 PM   #5
amishdude01
Drives: 14 Brz
95% of the time I turn it on, I immediately turn it back off. Im just afraid of damaging something in the process of turning it on and off quickly.
Old 11-25-2014, 01:43 PM   #6
adamg
Drives: brz
adamg is offline   Reply With Quote
Old 11-25-2014, 01:44 PM   #7
amishdude01
Drives: 14 Brz
I tend to over think things......
Old 11-25-2014, 01:50 PM   #8
Stang70Fastback
A.K.A. Starlord
You won't damage anything. Older vehicles had A/C right next to the off position so that you had to pass through A/C mode when you wanted to use the heat or anything, which bumped the compressor and kept it from freezing in an unused position.
Again, though, why do you need to turn it off? Just leave it on and enjoy the nice air...?
Old 11-25-2014, 06:00 PM   #9
brz880
Drives: CSB 6MT
The dealer can change that setting with the techstream tool
brz880 is offline   Reply With Quote
Old 11-25-2014, 07:39 PM   #10
Turbowned
Turbowned's Avatar
Leave it alone. The system is dehumidifying the cabin.
Old 11-25-2014, 07:56 PM   #11
kberkel
kberkel's Avatar
I always hit AUTO and turn the AC off if it wants to come on. The rest of the system continues to function the same.
Not sure if performance drop is same in winter, but I definitely feel it in summer, and only run AC when in cruise control on the highway.
kberkel is offline   Reply With Quote
Old 11-26-2014, 04:21 PM   #12
tomkozski
Drives: 2017 WRB BRZ w/ PP
I turn off the a/c to prevent condensation from forming in the system and causing that moldy smell. Only leave the a/c on when I really need it, like in the summer or when my windows start fogging up.
tomkozski is offline   Reply With Quote
Old 11-26-2014, 04:27 PM   #13
B-R-Z
I love peanut butter
B-R-Z's Avatar
Drives: 2013 SWP BRZ Limited
Why does the AC always come on with auto mode? Normally it's only for defogger and actual cold air conditioning. Kind of annoying.
Old 11-26-2014, 05:13 PM   #14
Bobblehead
Bobblehead's Avatar
Drives: 2013 BRZ (gone) 2016 Ford Fusion SE
The reason the A/C comes on when you press auto is because while its warming the car, its also dehumidifying the air. It does that to keep the inside comfortable, but mainly to keep your windows from fogging up.
Bobblehead is offline   Reply With Quote
Climate Control Magiclow Cosmetic Modification (Interior/Exterior/Lighting) 3 10-05-2014 06:46 AM
Is there a way to turn on climate control without the AC being on? chenshuo BRZ First-Gen (2012+) — General Topics 48 01-27-2014 02:12 PM
Climate control Panel for the FRS. Mrqb22 Electronics | Audio | NAV | Infotainment 6 02-13-2013 09:03 PM
Climate control bezel Surok AUSTRALIA 7 10-25-2012 06:34 AM
Auto climate control Daemione Electronics | Audio | NAV | Infotainment 37 06-05-2012 10:19 PM
