Old 03-17-2015, 11:44 PM   #1
radroach
Drives: car
FI that doesn't cut into the crash beam?
I read about the greddy turbo kit needing to cut into the front crash beam to fit a FMIC, so I'm wondering if there's a good turbo kit out there that retains the stock crash beam / doesn't require you to cut into these parts, or if there are solutions around this?
The Following User Says Thank You to radroach For This Useful Post:
onetime4 (03-17-2015)
Old 03-18-2015, 12:07 AM   #2
xuimod
Drives: 2007 MX-5 Miata, 2015 VW Golf GTI
I think AVO Turbo kit retains crash beam I believe.
For Greddy kit, you could always buy the Drift Armor Drift bar. Its called a Drift bar but its a hefty piece of metal, definitely gives car some protection, not as much at the OEM crash beam though.
xuimod is offline   Reply With Quote
The Following User Says Thank You to xuimod For This Useful Post:
radroach (03-18-2015)
Old 03-18-2015, 12:17 AM   #3
kbye
kbye's Avatar
Drives: 2014 FR-S
There's lots if you search...
AVO
Fullblown
PTuning
P&L
Revworks
Works
Treadstone
kbye is offline   Reply With Quote
The Following 6 Users Say Thank You to kbye For This Useful Post:
clayrush (03-18-2015), Fakk (03-18-2015), JustBoostin (03-18-2015), Koa (03-19-2015), radroach (03-18-2015), rb6freak (03-20-2015)
Old 03-18-2015, 04:49 AM   #4
tjohnson104
Drives: brz
I got my drift armor crash bar today for my install..... terrible fitment... So for the 4 bolts on each side of the car, I could only get 2 on each side to have a bolt through it. I messed around with it for 2 hours... I mean its tight as hell and its not going any where, but come on... they had 1 job to do, and they couldn't even line up the holes correctly..
tjohnson104 is offline   Reply With Quote
The Following 2 Users Say Thank You to tjohnson104 For This Useful Post:
DriftinFRS (03-19-2015), themajesticone (03-19-2015)
Old 03-18-2015, 05:07 AM   #5
midnight23
dying bird under the hood
Drives: 2013 SWP Limited BRZ
had what sounds like the same issue as you but then i noticed there were 2 other bolts to remove once the oem crash bar was off, once those extra bolts were off the drift armor came on nicely.
Build Thread
Instagram
Old 03-18-2015, 05:09 AM   #6
tjohnson104
Drives: brz
yeah it took me a while to see those hidden bolts also, but when I took those off, still the holes dont line up. I have the outer bolts in. But the inner ones dont work for me. The top part isnt even flush,
Old 03-18-2015, 08:35 AM   #7
FirestormFRS
Don't kid yourselfs into thinking that bar is going to react the same way the stock crash member works.
FirestormFRS is offline   Reply With Quote
The Following 4 Users Say Thank You to FirestormFRS For This Useful Post:
CSG Mike (03-19-2015), dpgfunk (03-19-2015), Sportsguy83 (08-28-2015), themajesticone (03-19-2015)
Old 03-19-2015, 04:10 AM   #8
tjohnson104
Drives: brz
I stand corrected. the crash bar fits perfect. I had it upside down... didnt know until the bumper didnt fit. Once fixed all holes line up and everythings good.
Koa (03-19-2015), raven1231 (03-19-2015)
Old 03-19-2015, 06:19 AM   #9
themajesticone
themajesticone's Avatar
Drives: '13 UM86
JRSC C30 91 oct | JDL UEL Header | Tomei Overpipe | Milltek Front Pipe | Milltek Catback | SPL LCA v2 | FA 500 v5 Coilovers 6k/7k | SPC Front Camber Bolts | Enkei RPF1 17x9 +35 | 245/40 Michelin Pilot Super Sport
themajesticone is offline   Reply With Quote
The Following User Says Thank You to themajesticone For This Useful Post:
Old 08-28-2015, 11:44 AM   #10
BlueDubbinTDI
BlueDubbinTDI's Avatar
Drives: 2013 FR-S, 2012 MCS
Are you thinking it's mostly hype? I can't see either option being great in a hard frontal crash, whether it be a gutted oem support beam or the drift bar. I feel like you'd be screwed either way
Old 08-28-2015, 11:47 AM   #11
BRZoomTX
BRZoomTX's Avatar
Drives: '13 BRZ
Front crash bar will definitely help in lower speed collisions. High speed, OEM is designed to crumple to absorb the impact. A stiffer crash bar could lead to more frame damage, however I seriously doubt the drift armor bar is THAT strong to bend the frame before it gives. People really over-do it when it comes to aftermarket crash bars. They work fine.
BRZoomTX is offline   Reply With Quote
Old 08-28-2015, 08:28 PM   #12
FirestormFRS
The OEM bar is designed to spread the force across the entire crash structure of the car. Pretty sure no aftermarket bar has collected the data or did the needed research to make their bar act the same.
Old 08-28-2015, 10:14 PM   #13
BlueDubbinTDI
My thoughts exactly. That's why I'm saving myself $180 and gutting mine in a few weeks. Fingers crossed nothing major happens..but Id hope that with a proper crash beam anyway...
Sold Please delete Alexgalarreta Brakes, Suspension, Chassis 0 12-22-2014 09:04 PM
Hi beam indicator Norkoastal BRZ First-Gen (2012+) — General Topics 4 12-10-2013 12:53 PM
DRL or high beam or both? jacobzking Cosmetic Modification (Interior/Exterior/Lighting) 5 06-09-2013 03:09 PM
HID and high beam use gatorbushmen Cosmetic Modification (Interior/Exterior/Lighting) 4 04-19-2013 04:56 PM
Low beam on indicator? percyng CANADA 5 10-10-2012 04:47 PM
