Old 06-09-2013, 12:47 PM   #1
jacobzking
Drives: White FRS
DRL or high beam or both?
so... where is the DRL? lol there are only 2 bulbs in the headlight. low beam and... i'm assuming high beam. or does the high beam double as the DRL? if so, doe the DRL just switch off when you turn on the low beams? thanks!
update: sota figured it out. its the same bulb. i'm guessing there's a relay or something that prevents it from running at full power when in DRL mode?
jacobzking is offline   Reply With Quote
Old 06-09-2013, 12:51 PM   #2
Narcoden
Narcoden's Avatar
Drives: '13 Ultramarine FR-S
Your High beams are the DRL just at lower power... Yes, they switch off when you turn on your low beams.
Narcoden is offline   Reply With Quote
Old 06-09-2013, 12:52 PM   #3
BlaineWasHere
Grip>Drift
BlaineWasHere's Avatar
Drives: FRS
Does anyone know if it's possible to make the DRLs stay on the with the headlights at DRL power, not highbeam power?
Old 06-09-2013, 12:58 PM   #4
Narcoden
Narcoden's Avatar
You could swap them out for LED's and leave your high beams on. lol!
Old 06-09-2013, 03:02 PM   #5
jacobzking
Drives: White FRS
just put my LED DRLs in. they flickerjust a little. is that normal?
Old 06-09-2013, 03:09 PM   #6
86_ZN6
86_ZN6's Avatar
Drives: 86 ZN6
Not normal
86_ZN6 is offline   Reply With Quote
HID and high beam use gatorbushmen Cosmetic Modification (Interior/Exterior/Lighting) 4 04-19-2013 04:56 PM
Yellow high beam Reflectors MrTranxD Cosmetic Modification (Interior/Exterior/Lighting) 0 01-30-2013 07:36 PM
High beam/LED question Trashed675 Cosmetic Modification (Interior/Exterior/Lighting) 15 01-20-2013 12:46 PM
