CANADA Canada
Old 10-10-2012, 12:42 PM   #1
percyng
Drives: White BRZ 6MT
Low beam on indicator?
This might be a stupid question.
I always have 'Auto' on the headlight, but when it is dusk outside I can't tell if the low beam is on or not?
My other cars usually have a indicator on the dashboard that tell you if low beam is on or not. But seems like it doesn't exist for BRZ, is that right?
Is there another way to tell if headlight is on? Other than seeing the reflect from the front vehicle?
Thanks.
percyng is offline   Reply With Quote
Old 10-10-2012, 01:02 PM   #2
CBR600RR
Drives: Raven Black
you could just try turning the lights on - if you then discover that they are already on, then you will know they are on.
Old 10-10-2012, 01:14 PM   #3
truenosan
truenosan's Avatar
Drives: 13 Firestorm FRS
The gauge cluster lights up when you turn on the low beams.
truenosan is offline   Reply With Quote
Old 10-10-2012, 03:14 PM   #4
Slick
Slick's Avatar
Drives: FR-S Firestorm 6MT
He's got a BRZ, probably different with the auto lights than the FRS.
Slick is offline   Reply With Quote
Old 10-10-2012, 03:52 PM   #5
DGMBRZ
DGMBRZ's Avatar
Drives: 2013 Subaru BRZ in DGM
Gauge clusters do light up on the BRZ when the low beams are on. Only way to tell really, unless the fog lights are on too and then the fog light light turns on lol. Assuming you have the limited BRZ.
DGMBRZ is offline   Reply With Quote
Old 10-10-2012, 04:47 PM   #6
truenosan
truenosan's Avatar
Reading comprehension > Me
MT gear indicator WolfsFang Scion FR-S / Toyota 86 GT86 General Forum 19 07-02-2012 10:20 PM
H-86-H side indicator. seannyice81 Cosmetic Modification (Interior/Exterior/Lighting) 2 06-10-2012 10:01 PM
Gear indicator Slick CANADA 18 05-20-2012 10:14 AM
