Old 03-15-2015, 03:06 PM   #225
wparsons
wparsons's Avatar
Originally Posted by donoman View Post
The problem with $6k is that there are kits around 1000, 2000, 3000 that are implied not able to do the job.
Forgive me if I'm wrong but there are just 5 parameters:
-spring rate
-hi speed rebound
-low speed rebound
-hi speed compression
-low speed compression
Are the $6k kits adjustable out of the range of the $2k kits ??
There is so much more to it than that, it's not even funny.
There's also the damping curves (both high and low speed), etc, etc, etc.
flickr
cdrazic93 (03-15-2015)
Old 03-15-2015, 03:34 PM   #226
CSG Mike
CSG Mike's Avatar
Originally Posted by jsimon7777 View Post
So like I said, start with better bones if you're going to drop 5k plus on suspension. Well, that's my preference at least. Not really aiming this at you, Mike. Just quoting you.
By that logic, I spend more time in Ferraris and Lamborghinis at the track than I do in BRZs.
I shouldn't waste my time doing any R&D activities for the BRZ, since the Ferraris are a better platform, right?
wparsons (03-15-2015)
Old 03-15-2015, 03:59 PM   #227
SilverFRS
Drives: Silver FRS
How do the new Tein Flex Z compare for street ride comfort versus Ohlins or Bilstein B16? CSG Mike?
SilverFRS is offline   Reply With Quote
Old 03-15-2015, 04:05 PM   #228
Captain Snooze
Because compromise ®
Captain Snooze's Avatar
Drives: Red Herring
Tein make dampers that cost around $700. They also make dampers that cost around $14k. I am suggesting they are not interchangeable.
You have omitted the tolerances and complexity to which more expensive dampers are made.
Old 03-15-2015, 04:27 PM   #229
cdrazic93
Junior
cdrazic93's Avatar
Drives: a car
-spring rate
-hi speed rebound
-low speed rebound
that's just the basics. It gets so much more complicated, and it becomes exponentially more complicated with the quality of materials. The Penske shock thread would be a good read for you, the Penske engineer explained a few things that sets the Penske shock out from the group of high end suspension.
Old 03-15-2015, 04:59 PM   #230
cjd
cjd's Avatar
Drives: 2017 BRZ
By that logic, why did you spend so much on your car? There are $15k cars...
I don't know about you, but I figured out what I wanted in a car and set out to find one that satisfied as many of the wants as I could. There are a range of options, all over the place on price, and I purchased what I felt best fit. It doesn't do everything I'd like, but I probably need 2 cars to really do that anyway...
Old 03-15-2015, 05:13 PM   #231
donoman
donoman's Avatar
Drives: '13 FR-S
My FRS is great. I like it so much that I wish I would have gotten a BRZ Limited with leather and all the fixins. I bought it because I wanted a daily driver. It gets 30mpg, it's fun to drive, and should prove to be reliable.
When I want to rip, I have a 911 and a Z4M coupe. Great cars but not daily drivers. My wife drives a z4 2.5i that I think is a great DD but we wanted something with more space than a 2-seater. That's why the '86 is great.
Go ahead and spend $6K on your suspension to try to improve your ride quality, maybe you earn more than me and can spare it. I'm proposing that there are cheaper alternatives and $6K is well out of the range to improve the ride in a STREET CAR.
donoman is offline   Reply With Quote
The Following 2 Users Say Thank You to donoman For This Useful Post:
abraxis (03-16-2015), CSG Mike (03-15-2015)
Old 03-15-2015, 05:16 PM   #232
Shankenstein
Frosty Carrot
Shankenstein's Avatar
Drives: The Atomic Carrot
Well, they're sealed, twin-tube struts that are designed for mass-production. Disposable dampers and interchangeable parts. The Flex Z is an awesome bang-for-your-buck option, much like Megan, Fortune, and BC. The size of Tein's operation probably allows them to automate most of the production (except assembly) and keep a reasonable standard of quality.
Ohlins and Bilstein are serviceable monotubes. Expect better tolerances, surface coatings and base materials. Ohlins uses aluminum bits, and Bilstein uses steel with a hefty plating. All of 3 options will suffer from the elements... but they have different approaches to survival.
http://www.evolutionm.net/forums/evo...ml#post9454023
If you think you're nerd enough, join in the discussions about Suspension and Aerodynamic modelling!
Wall of Fame - JDL Auto Design, Raceseng, Vishnu Tuning, Penske Shocks, Nameless, Perrin, RaceComp Engineering, Essex/AP Racing, Verus, RacerX
Wall of Shame - aFe Takeda, Wilwood, FA20Club
Shankenstein is offline   Reply With Quote
Old 03-15-2015, 05:31 PM   #233
cjd
cjd's Avatar
Drives: 2017 BRZ
Right. See, $6k is affordable in a way adding a 911 and Z4M would just not be... I'd end up spending more than $6k annually just to park them.
But, for a street car, the FRS is a bit much still - a nice iQ would have been just about right. Anything more is just too much, since you have something else when it's time for fun.
*shrug*
Old 03-15-2015, 05:37 PM   #234
donoman
donoman's Avatar
Drives: '13 FR-S
I almost bought a Prius plug-in. I just could not do it.
Old 03-15-2015, 05:59 PM   #235
SilverFRS
Drives: Silver FRS
I am aware of quality and mfg differences, looking for input about daily street driving comfort between Tein Flex Z, Ohlins & Bilstein B16, basically what this thread was originally about.
Old 03-15-2015, 09:38 PM   #236
EAGLE5
Dismember
EAGLE5's Avatar
Drives: 2013 Red Scion FR-S
You should do R&D where you'll make the most money. I'm pretty sure that's on the twin side of things. I don't expect you're selling many 5k+ setups for the twins, but I do expect you're selling quite a few between 1k and 3k.
Old 03-15-2015, 09:39 PM   #237
EAGLE5
Dismember
EAGLE5's Avatar
Check out the Fiat 500e. Tons of fun.
Old 03-15-2015, 10:28 PM   #238
CSG Mike
CSG Mike's Avatar
I'm pretty sure you'd change your mind if you actually experienced a well set up car.
I'll be in NorCal next weekend with a JRZ equipped BRZ. You're more than welcome to catch a ride.
wparsons (03-16-2015)
making seniors look bad, uberstupid
For those who ride, there's a group ride happening tomorrow if you're interested. Yamaha_R6 Northwest 3 03-07-2014 09:32 PM
Simple mods to improve handling while improving looks? Jinzen Scion FR-S / Toyota 86 GT86 General Forum 11 06-07-2013 11:48 AM
What's your other ride, winter ride etc. wtout86 Other Vehicles & General Automotive Discussions 13 12-07-2012 12:36 AM
Does the ride quality change with time?? BRZnut BRZ First-Gen (2012+) — General Topics 22 12-01-2012 08:26 PM
